2555|4
5979
“玩板”+ 共享单车控制板-时钟芯片PCF8563 [复制链接]
板子左边一个GPS,右边一个GPRS,难度稍微有点大,柿子还是要捡软的捏,先把时钟芯片PCF8563 搞定吧
首先用stm32cube做好管脚配置,PCF8563使用的是I2C1接口
然后从网上找了个PCF8563的驱动:
#include "main.h"
#include "pcf8563.h"
I2C_HandleTypeDef *hi2c_pcf8563;
uint8_t Pcf8563Buffer[7];
void WriteBitToControlRegister(uint8_t ControlRegister, uint8_t BitNumber, uint8_t Value)
	uint8_t tmp;
	if(Value>1) Value = 1;
	if(ControlRegister>1) Value = 1;
	if(BitNumber>7) Value = 7;
	HAL_I2C_Mem_Read(hi2c_pcf8563, PCF8563_ADDRESS, ControlRegister?PCF8563_REG_CONTROL_STATUS1:PCF8563_REG_CONTROL_STATUS2, 1, &tmp, 1, PCF8563_I2C_TIMEOUT);
	tmp &= ~(1<<BitNumber);
	tmp |= (Value<<BitNumber);
//	ControlRegister?(Value &= 0b10101000):(Value &= 0b00011111); // Put zeros where zero is needed
	HAL_I2C_Mem_Write(hi2c_pcf8563, PCF8563_ADDRESS, ControlRegister?PCF8563_REG_CONTROL_STATUS1:PCF8563_REG_CONTROL_STATUS2, 1, &Value, 1, PCF8563_I2C_TIMEOUT);
void PCF8563_TEST1Enable(uint8_t Enable)
	WriteBitToControlRegister(PCF8563_REG_CONTROL_STATUS1, PCF8563_CONTROL1_TEST1, Enable);
void PCF8563_STOPEnable(uint8_t Enable)
	WriteBitToControlRegister(PCF8563_REG_CONTROL_STATUS1, PCF8563_CONTROL1_STOP, Enable);
void PCF8563_TESTCEnable(uint8_t Enable)
	WriteBitToControlRegister(PCF8563_REG_CONTROL_STATUS1, PCF8563_CONTROL1_TESTC, Enable);
void PCF8563_InterruptEnable(uint8_t Enable)
	WriteBitToControlRegister(PCF8563_REG_CONTROL_STATUS1, PCF8563_CONTROL2_TI_TP, Enable);
void PCF8563_AlarmFlagEnable(uint8_t Enable)
	WriteBitToControlRegister(PCF8563_REG_CONTROL_STATUS1, PCF8563_CONTROL2_AF, Enable);
void PCF8563_TimerFlagEnable(uint8_t Enable)
	WriteBitToControlRegister(PCF8563_REG_CONTROL_STATUS1, PCF8563_CONTROL2_TF, Enable);
void PCF8563_AlarmInterruptEnable(uint8_t Enable)
	WriteBitToControlRegister(PCF8563_REG_CONTROL_STATUS1, PCF8563_CONTROL2_AIE, Enable);
void PCF8563_TimerInterruptEnable(uint8_t Enable)
	WriteBitToControlRegister(PCF8563_REG_CONTROL_STATUS1, PCF8563_CONTROL2_TIE, Enable);
void PCF8563_ClkoutFrequency(CLKOUT_Freq Frequency)
	uint8_t tmp;
	if(Frequency>3) Frequency = 3;
	HAL_I2C_Mem_Read(hi2c_pcf8563, PCF8563_ADDRESS, PCF8563_REG_CLKOUT, 1, &tmp, 1, PCF8563_I2C_TIMEOUT);
	tmp &= ~(3<<PCF8563_CLKOUT_CONTROL_FD0);
	tmp |= (Frequency<<PCF8563_CLKOUT_CONTROL_FD0);
	HAL_I2C_Mem_Write(hi2c_pcf8563, PCF8563_ADDRESS, PCF8563_REG_CLKOUT, 1, &tmp, 1, PCF8563_I2C_TIMEOUT);
uint8_t bcd2dec(uint8_t BCD)
	return (((BCD & 0xF0)>>4) *10) + (BCD & 0xF);
uint8_t dec2bcd(uint8_t DEC)
	return ((DEC / 10)<<4) + (DEC % 10);
int dayofweek(int Day, int Month, int Year)
    int Y, C, M, N, D;
    M = 1 + (9 + Month) % 12;
    Y = Year - (M > 10);
    C = Y / 100;
    D = Y % 100;
    N = ((13 * M - 1) / 5 + D + D / 4 + 6 * C + Day + 5) % 7;
    return (7 + N) % 7;
void PCF8563_SetDateTime(RTCDateTime *DateTime)
	uint8_t tmp[7];
	if(DateTime->Second > 59) DateTime->Second = 59;
	if(DateTime->Minute > 59) DateTime->Minute = 59;
	if(DateTime->Hour > 23) DateTime->Hour = 23;
	if(DateTime->Day > 31) DateTime->Day = 31;
	if(DateTime->Month > 12) DateTime->Month = 12;
	if(DateTime->Year> 2099) DateTime->Year = 2099;
	tmp[0] = dec2bcd((DateTime->Second) & 0x7F);
	tmp[1] = dec2bcd(DateTime->Minute);
	tmp[2] = dec2bcd(DateTime->Hour);
	tmp[3] = dec2bcd(DateTime->Day);
	tmp[4] = dayofweek(DateTime->Day, DateTime->Month, DateTime->Year);
	tmp[5] = dec2bcd(DateTime->Month);
	tmp[6] = dec2bcd(DateTime->Year - 2000);
	HAL_I2C_Mem_Write(hi2c_pcf8563, PCF8563_ADDRESS, PCF8563_REG_TIME, 1, tmp, 7, PCF8563_I2C_TIMEOUT);
void PCF8563_CalculateDateTime(RTCDateTime *DateTime)
	DateTime->Second = bcd2dec((Pcf8563Buffer[0]) & 0x7F);
	DateTime->Minute = bcd2dec(Pcf8563Buffer[1]);
	DateTime->Hour = bcd2dec(Pcf8563Buffer[2]);
	DateTime->Day = Pcf8563Buffer[3];
	DateTime->DayOfWeek = bcd2dec(Pcf8563Buffer[4] + 1); // too keep weekdays in 1-7 format
	DateTime->Month = bcd2dec(Pcf8563Buffer[5] & 0x1F);
	DateTime->Year = 2000 + bcd2dec(Pcf8563Buffer[6]);
#ifdef PCF8563_USE_DMA
void PCF8563_ReceiveDateTimeDMA(void)
	HAL_I2C_Mem_Read_DMA(hi2c_pcf8563, PCF8563_ADDRESS, PCF8563_REG_TIME, 1, Pcf8563Buffer, 7);
#else
void PCF8563_GetDateTime(RTCDateTime *DateTime)
	HAL_I2C_Mem_Read(hi2c_pcf8563, PCF8563_ADDRESS, PCF8563_REG_TIME, 1, Pcf8563Buffer, 7, PCF8563_I2C_TIMEOUT);
  PCF8563_CalculateDateTime(DateTime);
#endif
void PCF8563_Init(I2C_HandleTypeDef *hi2c)
	hi2c_pcf8563 = hi2c;
	PCF8563_ClkoutFrequency(CLKOUT_FREQ_1HZ);
	PCF8563_STOPEnable(0);
写了个简单的测试代码:
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_I2C1_Init();
  MX_USART1_UART_Init();
  MX_USART2_UART_Init();
  MX_USART3_UART_Init();
  /* USER CODE BEGIN 2 */
  PCF8563_Init(&hi2c1);
  r.Hour = 12;
  r.Minute = 30;
  r.Second = 0;
  PCF8563_SetDateTime(&r);
  printf("====pcf8563 test====\n\r");
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
	PCF8563_GetDateTime(&r);
	MessageSize = sprintf(Message, "%02d:%02d:%02d\n\r", r.Hour, r.Minute, r.Second);
	HAL_UART_Transmit(&huart2, Message, MessageSize, 1000);
	LED1_Toggle;
    HAL_Delay(1000);
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
SIM800C目前也是有点反应,能够收到和响应AT命令,还在摸索中。。
此内容由EEWORLD论坛网友chenzhufly原创,如需转载或用于商业用途需征得作者同意并注明出处
AT有反应了?666   详情 回复 发表于 2020-3-16 20:54
点赞(1) 关注
个人签名生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙
做一个简单的人,踏实而务实,不沉溺幻想,不庸人自扰
423
lz测试一下卡,看看是否还有流量
423
有网友说3个脚是升压电路,这里还有点问号
423
点赞支持!
423
AT有反应了?666
