3917|16
最近在学Ardence RTX实时系统软件,有很多不懂的地方,下面是一个定时器程序,不太明白? [复制链接]
   最近在学Ardence RTX实时系统软件,有很多不懂的地方,下面是一个定时器程序,不太明白?请路过大虾们帮忙看看。
下面是源代码,包括两个文件,一个头文件,一个源文件。如下所示:
// RTX_TIME_SLEEP.h - Header file
// This file was generated using the RTX 6.5.1 Application Wizard.
#include
#include
#include
// function prototype for periodic timer function
void
RTFCNDCL
TimerHandler(
                void *   nContext
void print();
.c文件
// RTX_TIME_SLEEP.c - C file
#include  "rtx_time_sleep.h"
#include "windows.h"
#include "stdio.h"
#include "rtapi.h"
LARGE_INTEGER Period; // Timer period
LARGE_INTEGER StartTime; // Start time of sampling run
ULONG TimerCounter = 0; // Counts entries to timer handler
void
_cdecl
wmain(
       int     argc,
       wchar_t **argv,
       wchar_t **envp
    // for periodic timer code
    LARGE_INTEGER  x;
    HANDLE         hTimer;     // timer handle
    //  RTX periodic timer code:
    //  TO DO: Set default timer period to your desired time.
    //         The period needs to be an even multiple of the HAL
    //         period found in the control panel.
    //         This example uses a period of 500 micro seconds.
    Period.QuadPart = 500;
        if (!RtSetThreadPriority( GetCurrentThread(), RT_PRIORITY_MAX-1))
      printf("WARNING: Can't set to highest RTAPI priority.\n");
    // Create a periodic timer
    if (! (hTimer = RtCreateTimer(
                                  NULL,            // security
                                  0,               // stack size - 0 uses default
                                  TimerHandler,    // timer handler
                                  NULL,            // NULL context (argument to handler)
                                  RT_PRIORITY_MAX, // priority
                                  CLOCK_2) ))      // RTX HAL timer
        // TO DO:  exception code here
        // RtWprintf(L"RtCreateTimer error = %d\n",GetLastError());
        ExitProcess(2);
    if (! RtSetTimerRelative( hTimer,
                              &Period,
                              &Period))
        ExitProcess(2);
        Sleep(50);
   // Stop and delete the timer.
   RtCancelTimer( hTimer, &x);
   RtDeleteTimer( hTimer);
    ExitProcess(0);
void
RTFCNDCL
TimerHandler(
              PVOID    unused
    // TO DO:  your timer handler code here
        TimerCounter++;
        print();
void print()
        printf("%d\n",TimerCounter);
我的问题是,为什么必须加入Sleep()函数(即上面红色标记代码处),才能让上面创建的定时器函数调用程序调用TimerHandler()函数,不加的话,它就不执行。不像是windows 中的自己的定时器,它会自动每隔设定的时间去执行定时器指定的要调用的函数。大虾们请帮我看看,怎么改,才能让定时器自动调用TimerHandler()函数,就像windows中的一样,还有那个蓝色处的那两个参数是什么意思?理解的不是很清楚。谢谢,不知哪位大虾有没有这方面的资料,例程是最好了,发给我看看,我的邮箱是wliang@emails.bjut.edu.cn   希望路过的大虾们多多指教
此帖出自产业风云论坛
LZ 没有认真看rtx生成的代码,创建定时器后,不sleep怎么都不用50us都执行完整个程序并在最后delete了定时器了 rtx是没有界面的,可以使用共享区进行进程间通信,具体多看看rtx提供的例程  详情 回复 发表于 2010-2-5 16:00
to 楼主:
   不执行Sleep(50);主线程就执行下去把定时器删除了,并ExitProcess();
   一般的做法是定义好需要的定时器或线程,使用多线程机制,然后执行SuspendThread(GetCurrentThread())将主线程挂起。(如果线程无法退出,使用Task管理器)。
   MFC与RTX的接口通过其提供的API实现,共享机制一般通过共享内存实现,RTX负责实时计算与硬件控制,Windows实现界面。最新的RTX可以支持VS2005编程,我使用C#,C++,RTX混合编程,C#做界面,C++做桥梁;
   实现硬件中断必须具备几个条件:设备转到RTx下控制,正确挂接中断;Ardence 网站上有Com的源码,改一下就可以用了。
此帖出自产业风云论坛
你会rtx吗?你看懂了上面代码吗?
此帖出自产业风云论坛
引用 9 楼 wuliang11 的回复:
你会rtx吗?你看懂了上面代码吗?
你懂 c 语言么,你懂计算机么,你懂编程么?
  1. 用RTX库编写的定时程序,计时误差不超过10us。
  2. //
  3. // RTEX1.H
  4. //
  5. #include
  6. #include
  7. #include
  8. // defines for interrput handler code
  9. // TO DO: set the bus interrput vector
  10. #define ISA_BUS_VECTOR 7
  11. // defines for port I/O calls
  12. // For this example, port set to speaker
  13. // TO DO: set your own values
  14. #define CT_PORT_BASE ((PUCHAR) 0x61)
  15. #define CT_PORT_RANGE 1
  16. unsigned long counts;
  17. // function prototype for periodic timer function
  18. void
  19. RTFCNDCL
  20. TimerHandler(
  21. void * nContext
  22. );
  23. // function prototype for interrupt handler
  24. void
  25. RTFCNDCL
  26. InterruptHandler(
  27. void * nContext
  28. );
  29. //
  30. // RTEX1.C
  31. //
  32. #include "RTEX1.h"
  33. #include
  34. #include
  35. void
  36. _cdecl
  37. wmain(
  38. int argc,
  39. wchar_t **argv,
  40. wchar_t **envp
  41. )
  42. {
  43. // for periodic timer code
  44. LARGE_INTEGER liPeriod; // timer period
  45. HANDLE hTimer; // timer handle
  46. unsigned char key;
  47. // for interrupt handler code
  48. HANDLE hInterrupt; // interrupt vector handle
  49. int nContext; // context
  50. unsigned long intcounts;
  51. // for port I/O code
  52. UCHAR cX; // character read from port
  53. counts=0;
  54. intcounts=0;
  55. // RTX periodic timer code:
  56. // TO DO: Set default timer period to your desired time.
  57. // The period needs to be an even multiple of the HAL
  58. // period found in the control panel.
  59. // This example uses a period of 5000 micro seconds.
  60. liPeriod.QuadPart = 50000;
  61. // Create a periodic timer
  62. if (! (hTimer = RtCreateTimer(
  63. NULL, // security
  64. 0, // stack size - 0 uses default
  65. TimerHandler, // timer handler
  66. NULL, // NULL context (argument to handler)
  67. RT_PRIORITY_MAX, // priority
  68. CLOCK_2) )) // RTX HAL timer
  69. {
  70. //
  71. // TO DO: exception code here
  72. // RtWprintf(L"RtCreateTimer error = %d\n",GetLastError());
  73. ExitProcess(1);
  74. }
  75. if (! RtSetTimerRelative( hTimer,
  76. &liPeriod,
  77. &liPeriod) )
  78. {
  79. //
  80. // TO DO: exception code here
  81. //
  82. // RtWprintf(L"RtSetTimerRelative error = %d\n",GetLastError());
  83. ExitProcess(1);
  84. }
  85. // RTX interrupt handler code
  86. // RtAttachInterruptVector associates a handler routine with
  87. // a hardware interrupt.
  88. // Note: level triggered interrupts are not supported in the
  89. // Win32 environment
  90. hInterrupt = RtAttachInterruptVector(
  91. NULL, // thread attributes
  92. 0, // stack size - 0 uses default
  93. InterruptHandler, // handler routine
  94. (void *) &nContext,// context
  95. 1, // priority
  96. Isa, // interface type
  97. 0, // bus number
  98. ISA_BUS_VECTOR, // bus interrupt level
  99. ISA_BUS_VECTOR ); // bus interrupt vector
  100. if (! hInterrupt)
  101. {
  102. //
  103. // TO DO: exception code here
  104. // RtWprintf(L"RtAttachInterruptVector error = %d\n",GetLastError());
  105. ExitProcess(1);
  106. }
  107. // RTX port I/O code
  108. // Enable direct I/O access of CT ports from user context
  109. if (! RtEnablePortIo(CT_PORT_BASE,
  110. CT_PORT_RANGE) )
  111. {
  112. //
  113. // TO DO: your exception code here
  114. // RtWprintf(L"RtEnablePortIo error = %d\n",GetLastError());
  115. }
  116. // Use RTX port I/O functions to read and write to port.
  117. // See User's Guide chapter 3, "Using RTX Functionality" for
  118. // description of functions.
  119. //
  120. // Below is an example of a call to read/write to a port.
  121. RtWprintf(L"Turning on the speaker for 3 seconds.\n");
  122. cX = RtReadPortUchar(CT_PORT_BASE) | 0x03;
  123. RtWritePortUchar(CT_PORT_BASE, cX);
  124. cX ^= 0x03;
  125. while(1)
  126. {
  127. if(counts>=100*intcounts)
  128. {
  129. if(kbhit())
  130. {
  131. if((key=getch())==VK_ESCAPE)
  132. break;
  133. }
  134. printf("%d\n",counts);
  135. intcounts++;
  136. }
  137. }
  138. RtWritePortUchar(CT_PORT_BASE, cX);
  139. //
  140. // TO DO: your program code here
  141. //
  142. ExitProcess(0);
  143. }
  144. //
  145. // Functions called from RTEX1.c
  146. //
  147. #include "RTEX1.h"
  148. //
  149. // RTX periodic timer handler function
  150. // Refer to the RTX Samples directory for examples
  151. // of periodic timers
  152. //
  153. void
  154. RTFCNDCL
  155. TimerHandler(
  156. PVOID context
  157. )
  158. {
  159. // TO DO: your timer handler code here
  160. counts++;
  161. }
  162. //
  163. // RTX interrupt handler function
  164. // Refer to the RTX Samples directory for examples
  165. // of interrupt handlers
  166. //
  167. void
  168. RTFCNDCL
  169. InterruptHandler(
  170. void * nContext
  171. )
  172. {
  173. // TO DO: your interrupt handler code here
  174. }
复制代码
此帖出自产业风云论坛
不加 sleep,程序顺序执行就退出了,系统在退出时会自动关闭所有它可以回收的资源,其中就包括定时器。
此帖出自产业风云论坛
当然,你这个程序自己就已经删除了定时器。
此帖出自产业风云论坛
uping
此帖出自产业风云论坛
恩。。路过。。同问。。。upup
此帖出自产业风云论坛
那怎么做才能不删除定时器呢,另外想问下,如何才能在将具有rtx功能的程序作成一个界面形式.相当于mfc中的对话形式
此帖出自产业风云论坛
实时系统做 MFC 对话框...
莫名其妙...
那只是 wince / embedlinux 嵌入式系统干的事儿...
此帖出自产业风云论坛
我说的是系统的界面,还有上面即便没有删除定时器资源,同样不执行定时器回调函数,一次也不执行,要是顺序执行,最少也该执行一次吧,为什么一次也不执行.
此帖出自产业风云论坛
  1.     //  RTX periodic timer code:
  2.     //  TO DO: Set default timer period to your desired time.
  3.     //        The period needs to be an even multiple of the HAL
  4.     //        period found in the control panel.
  5.     //        This example uses a period of 500 micro seconds.
  6.     Period.QuadPart = 500;
复制代码
你不是设置为 500ms 后执行吗?
貌似用不到 500ms 后面的程序就已经删除了定时器、退出程序运行了。
定时器都已经删除了,程序都退出了,还怎么执行...
执行什么...
此帖出自产业风云论坛
大家有没有用过RTX下串口编程?
我仿照RTX Serial API写的一个程序怎么也进不了中断。
希望大家多交流
此帖出自产业风云论坛
我也在学RTX,大虾们有空的探讨下,QQ:281337116~~
此帖出自产业风云论坛
RTX可以做成界面的,我已经做成功了的。如果你的CPU和显卡够快,几个ms绘一次图是可以保证没有误差的。
如果不用Sleep,你的程序就会顺序执行并结束了。你可以在WIN32或MFC下创建一个线程,在线程里再创建Timer,记住你的Timer Handle要设成全局的,不然又是一下就完了。
另外在这个程序里的定时时间设的也不对,RTX的最小时钟周期是100ns(CLOCK2),所以如果要设一个500us的定时间隔,period应该是5000,而不是500。
RTX的最小定时周期是100us,你设成500相当于50us,当然不执行了。
此帖出自产业风云论坛
Ardence RTX交流与学习!
欢迎各位加入,一起学习交流!
QQ群:2689390
此帖出自产业风云论坛
LZ
此帖出自产业风云论坛
有奖直播 | AI之眼——安森美图像传感器 报名中
直播主题:AI之眼——安森美图像传感器
报名观看直播、直播间提问、填写问卷均有机会获得精美礼品!
