2832|0
2606
IR的AUIrS4426S用于混合动力车,感兴趣的朋友可以看看 [复制链接]
International Rectifier has introduced the AUIRS4426S dual channel low-side driver IC for use in automotive applications including hybrid power train drives, direct fuel injection and DC-DC converter applications.
Available in an 8-lead SOIC package, the automotive-qualified AUIRS4426S is a rugged low-voltage high speed power MOSFET and IGBT driver that features matched propagation delay for both channels to help simplify design.
“With its ruggedized monolithic construction, the AUIRS4426S is particularly well suited to HEV applications that require a rugged and flexible solution,” said Marzak Li, product marketing manager, IR’s Automotive Products Business Unit.
The AUIRS4426S features a gate drive supply range from 6V to 20V, CMOS Schmitt-triggered inputs, outputs out-of-phase with inputs, and input logic is active low.
The device is qualified according to AEC-Q100 standards, features an environmentally friendly, lead-free and RoHS compliant bill of materials, and is part of IR’s automotive quality initiative targeting zero defects.
Specifications
Package
Topology
Voffset
Io+ & Io- (typ)
ton & toff (typ)
Supply voltage
AUIRS4426S
SOIC-8
Dual low side driver
25V
2.3 & 3.3A
70ns & 65ns
6-20V
Availability and Pricing
Pricing for the AUIRS4426S begins at US $0.51 each in 100,000-unit quantities. Production orders are available immediately. The automotive-qualified device is lead-free and RoHS compliant. Prices are subject to change.
www.irf.com
此帖出自模拟电子论坛
个人签名工程 = 数学+物理+经济
