3203|0
9798
24
IKS01A3驱动移植,基于STM32G474RE的LSM6DSO活动状态检测 [复制链接]
使用LSM6DSO的官方标C驱动
https://github.com/STMicroelectronics/STMems_Standard_C_drivers/
工程使用CubeMX生成
传感器静止时输出“Inactivity Detected”
活动时输出“Activity Detected”
/* STMicroelectronics evaluation boards definition
 * Please uncomment ONLY the evaluation boards in use.
 * If a different hardware is used please comment all
 * following target board and redefine yours.
//#define STEVAL_MKI109V3
#define NUCLEO_G474RE_X_NUCLEO_IKS01A2
#if defined(STEVAL_MKI109V3)
/* MKI109V3: Define communication interface */
#define SENSOR_BUS hspi2
/* MKI109V3: Vdd and Vddio power supply values */
#define PWM_3V3 915
#elif defined(NUCLEO_G474RE_X_NUCLEO_IKS01A2)
/* NUCLEO_G474RE_X_NUCLEO_IKS01A2: Define communication interface */
#define SENSOR_BUS hi2c1
#endif
/* Includes ------------------------------------------------------------------*/
#include <string.h>
#include <stdio.h>
#include "main.h"
#include "lsm6dso_reg.h"
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
static uint8_t whoamI, rst;
extern uint8_t tx_buffer[1000];
/* Extern variables ----------------------------------------------------------*/
extern I2C_HandleTypeDef hi2c1;
extern UART_HandleTypeDef hlpuart1;
/* Private functions ---------------------------------------------------------*/
 *   WARNING:
 *   Functions declare in this section are defined at the end of this file
 *   and are strictly related to the hardware platform used.
static int32_t platform_write(void *handle, uint8_t reg, uint8_t *bufp,
                              uint16_t len);
static int32_t platform_read(void *handle, uint8_t reg, uint8_t *bufp,
                             uint16_t len);
static void tx_com( uint8_t *tx_buffer, uint16_t len );
static void platform_init(void);
/* Main Example --------------------------------------------------------------*/
void example_main_activity_lsm6dso(void)
  lsm6dso_ctx_t dev_ctx;
  lsm6dso_pin_int1_route_t int1_route;
   *  Initialize mems driver interface
  dev_ctx.write_reg = platform_write;
  dev_ctx.read_reg = platform_read;
  dev_ctx.handle = &hi2c1;
   * Init test platform
  platform_init();
   *  Check device ID
  lsm6dso_device_id_get(&dev_ctx, &whoamI);
  if (whoamI != LSM6DSO_ID)
    while(1);
   *  Restore default configuration
  lsm6dso_reset_set(&dev_ctx, PROPERTY_ENABLE);
  do {
    lsm6dso_reset_get(&dev_ctx, &rst);
  } while (rst);
   * Disable I3C interface
  lsm6dso_i3c_disable_set(&dev_ctx, LSM6DSO_I3C_DISABLE);
   * Set XL and Gyro Output Data Rate
  lsm6dso_xl_data_rate_set(&dev_ctx, LSM6DSO_XL_ODR_208Hz);
  lsm6dso_gy_data_rate_set(&dev_ctx, LSM6DSO_GY_ODR_104Hz);
   * Set 2g full XL scale and 250 dps full Gyro
  lsm6dso_xl_full_scale_set(&dev_ctx, LSM6DSO_2g);
  lsm6dso_gy_full_scale_set(&dev_ctx, LSM6DSO_250dps);
   * Set duration for Activity detection to 9.62 ms (= 2 * 1 / ODR_XL)
  lsm6dso_wkup_dur_set(&dev_ctx, 0x02);
   * Set duration for Inactivity detection to 4.92 s (= 2 * 512 / ODR_XL)
  lsm6dso_act_sleep_dur_set(&dev_ctx, 0x02);
   * Set Activity/Inactivity threshold to 62.5 mg
  lsm6dso_wkup_threshold_set(&dev_ctx, 0x02);
   * Inactivity configuration: XL to 12.5 in LP, gyro to Power-Down
  lsm6dso_act_mode_set(&dev_ctx, LSM6DSO_XL_12Hz5_GY_PD);
   * Enable interrupt generation on Inactivity INT1 pin
  lsm6dso_pin_int1_route_get(&dev_ctx, &int1_route);
  int1_route.md1_cfg.int1_sleep_change = PROPERTY_ENABLE;
  lsm6dso_pin_int1_route_set(&dev_ctx, &int1_route);
   * Wait Events
  while(1)
    lsm6dso_all_sources_t all_source;
     * Check if Activity/Inactivity events
    lsm6dso_all_sources_get(&dev_ctx, &all_source);
    if (all_source.wake_up_src.sleep_state)
      sprintf((char*)tx_buffer, "Inactivity Detected\r\n");
      tx_com(tx_buffer, strlen((char const*)tx_buffer));
    if (all_source.wake_up_src.wu_ia)
      sprintf((char*)tx_buffer, "Activity Detected\r\n");
 * [url=home.php?mod=space&uid=159083]@brief[/url]  Write generic device register (platform dependent)
 * @param  handle    customizable argument. In this examples is used in
 *                   order to select the correct sensor bus handler.
 * @param  reg       register to write
 * @param  bufp      pointer to data to write in register reg
 * @param  len       number of consecutive register to write
                              uint16_t len)
  if (handle == &hi2c1)
    HAL_I2C_Mem_Write(handle, LSM6DSO_I2C_ADD_H, reg,
                      I2C_MEMADD_SIZE_8BIT, bufp, len, 1000);
#ifdef STEVAL_MKI109V3
  else if (handle == &hspi2)
    HAL_GPIO_WritePin(CS_up_GPIO_Port, CS_up_Pin, GPIO_PIN_RESET);
    HAL_SPI_Transmit(handle, ®, 1, 1000);
    HAL_SPI_Transmit(handle, bufp, len, 1000);
    HAL_GPIO_WritePin(CS_up_GPIO_Port, CS_up_Pin, GPIO_PIN_SET);
#endif
  return 0;
 * @brief  Read generic device register (platform dependent)
 * @param  reg       register to read
 * @param  bufp      pointer to buffer that store the data read
 * @param  len       number of consecutive register to read
                             uint16_t len)
    HAL_I2C_Mem_Read(handle, LSM6DSO_I2C_ADD_H, reg,
    /* Read command */
    reg |= 0x80;
    HAL_SPI_Receive(handle, bufp, len, 1000);
#endif
  return 0;
 * @brief  Write generic device register (platform dependent)
 * @param  tx_buffer     buffer to trasmit
 * @param  len           number of byte to send
void tx_com(uint8_t *tx_buffer, uint16_t len)
  #ifdef NUCLEO_G474RE_X_NUCLEO_IKS01A2
  HAL_UART_Transmit(&hlpuart1, tx_buffer, len, 1000);
  #endif
  CDC_Transmit_FS(tx_buffer, len);
  #endif
 * @brief  platform specific initialization (platform dependent)
  TIM3->CCR1 = PWM_3V3;
  TIM3->CCR2 = PWM_3V3;
  HAL_Delay(1000);
#endif
工程文件:
stm32g474.rar (2.88 MB, 下载次数: 31)
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
