3358|0
在使用 arria 10 时遇到烧写问题 [复制链接]
使用的芯片是 10AS016E3F27,用 JTAG 烧写 sof 文件时碰到一个问题
当 msel 设置为 ps (000/001)模式时,烧写正常
当 msel 设置为 as (011)模式时,烧写失败,错误 ID:209014,
Error(209014): CONF_DONE pin failed to go high in device 1. Make sure all communication cables are securely connected, select a different device, check the power on the target system, or make sure all nCE pins are connected to GND. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
按照资料,msel 设置应该不会影响到 JTAG 烧写的,
ps 模式下,下载链检测到 2 个设备,10AS016E 和 SOCVHPS,
as 模式下,下载链检测到 1 个设备,10AS016E,
as 模式下,虽然烧写失败,但是 FPGA 指示灯按照逻辑正常工作了,
有没有人有所了解的,谢谢
此帖出自FPGA/CPLD论坛
