1651|0
3836
dsp DM642用定时器点亮LED 源程序 [复制链接]
单片机源程序如下:
// TI File $Revision: /main/1 $
// Checkin $Date: September 21, 2007   08:58:44 $
// FILE:    Example_2833xLedBlink.c
// TITLE:   DSP2833x eZdsp LED Blink Getting Started Program.
// ASSUMPTIONS:
//    This program requires the DSP2833x header files.
//    As supplied, this project is configured for "boot to SARAM"
//    operation.  The 2833x Boot Mode table is shown below.
//    For information on configuring the boot mode of an eZdsp,
//    please refer to the documentation included with the eZdsp,
//       $Boot_Table:
//         GPIO87   GPIO86     GPIO85   GPIO84
//          XA15     XA14       XA13     XA12
//           PU       PU         PU       PU
//            1        1          1        1    Jump to Flash
//            1        1          1        0    SCI-A boot
//            1        1          0        1    SPI-A boot
//            1        1          0        0    I2C-A boot
//            1        0          1        1    eCAN-A boot
//            1        0          1        0    McBSP-A boot
//            1        0          0        1    Jump to XINTF x16
//            1        0          0        0    Jump to XINTF x32
//            0        1          1        1    Jump to OTP
//            0        1          1        0    Parallel GPIO I/O boot
//            0        1          0        1    Parallel XINTF boot
//            0        1          0        0    Jump to SARAM            <- "boot to SARAM"
//            0        0          1        1    Branch to check boot mode
//            0        0          1        0    Boot to flash, bypass ADC cal
//            0        0          0        1    Boot to SARAM, bypass ADC cal
//            0        0          0        0    Boot to SCI-A, bypass ADC cal
//                                              Boot_Table_End$
// DESCRIPTION:
//    This example configures CPU Timer0 for a 500 msec period, and toggles the GPIO32
//    LED on the 2833x eZdsp once per interrupt. For testing purposes, this example
//    also increments a counter each time the timer asserts an interrupt.
//       Watch Variables:
//          CpuTimer0.InterruptCount
//       Monitor the GPIO32 LED blink on (for 500 msec) and off (for 500 msec) on the 2833x eZdsp.
// $TI Release: DSP2833x Header Files V1.10 $
// $Release Date: February 15, 2008 $
#include "DSP2833x_Device.h"     // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h"   // DSP2833x Examples Include File
// Prototype statements for functions found within this file.
interrupt void cpu_timer0_isr(void);
unsigned int Count,Flag;
void main(void)
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP2833x_SysCtrl.c file.
   InitSysCtrl();
// Step 2. Initalize GPIO:
// This example function is found in the DSP2833x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio();  // Skipped for this example
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
   DINT;
// Initialize the PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2833x_PieCtrl.c file.
   InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
   IER = 0x0000;
   IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example.  This is useful for debug purposes.
// The shell ISR routines are found in DSP2833x_DefaultIsr.c.
// This function is found in DSP2833x_PieVect.c.
   InitPieVectTable();
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
   EALLOW;  // This is needed to write to EALLOW protected registers
   PieVectTable.TINT0 = &cpu_timer0_isr;
   Count = 0;                                        //初始化变量
   Flag=0;
   EDIS;    // This is needed to disable write to EALLOW protected registers
// Step 4. Initialize the Device Peripheral. This function can be
//         found in DSP2833x_CpuTimers.c
   InitCpuTimers();   // For this example, only initialize the Cpu Timers
#if (CPU_FRQ_150MHZ)
// Configure CPU-Timer 0 to interrupt every 500 milliseconds:
// 150MHz CPU Freq, 50 millisecond Period (in uSeconds)
   ConfigCpuTimer(&CpuTimer0, 150, 500000);
#endif
#if (CPU_FRQ_100MHZ)
// 100MHz CPU Freq, 50 millisecond Period (in uSeconds)
   ConfigCpuTimer(&CpuTimer0, 100, 500000);
#endif
// To ensure precise timing, use write-only instructions to write to the entire register. Therefore, if any
// of the configuration bits are changed in ConfigCpuTimer and InitCpuTimers (in DSP2833x_CpuTimers.h), the
// below settings must also be updated.
   CpuTimer0Regs.TCR.all = 0x4001; // Use write-only instruction to set TSS bit = 0
// Step 5. User specific code, enable interrupts:
// Configure GPIO0-3 as a GPIO output pin
   EALLOW;
   GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 0;
   GpioCtrlRegs.GPADIR.bit.GPIO0 = 1;
   GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 0;
   GpioCtrlRegs.GPADIR.bit.GPIO1 = 1;
   GpioCtrlRegs.GPAMUX1.bit.GPIO2 = 0;
   GpioCtrlRegs.GPADIR.bit.GPIO2 = 1;
   GpioCtrlRegs.GPAMUX1.bit.GPIO3 = 0;
   GpioCtrlRegs.GPADIR.bit.GPIO3 = 1;
   EDIS;
// Enable CPU INT1 which is connected to CPU-Timer 0:
   IER |= M_INT1;
// Enable TINT0 in the PIE: Group 1 interrupt 7
   PieCtrlRegs.PIEIER1.bit.INTx7 = 1;
// Enable global Interrupts and higher priority real-time debug events:
   EINT;   // Enable Global interrupt INTM
   ERTM;   // Enable Global realtime interrupt DBGM
// Step 6. IDLE loop. Just sit and loop forever (optional):
   for(;;);
   CpuTimer0.InterruptCount++;
   GpioDataRegs.GPATOGGLE.bit.GPIO0 = 1; // Toggle GPIO0 once per 500 milliseconds
   GpioDataRegs.GPATOGGLE.bit.GPIO1 = 1; // Toggle GPIO1 once per 500 milliseconds
   GpioDataRegs.GPATOGGLE.bit.GPIO2 = 1; // Toggle GPIO2 once per 500 milliseconds
   GpioDataRegs.GPATOGGLE.bit.GPIO3 = 1; // Toggle GPIO3 once per 500 milliseconds
   // Acknowledge this interrupt to receive more interrupts from group 1
   PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
// No more.
