2242|0
3836
DSP28035的SPWM程序 [复制链接]
#include "DSP28x_Project.h"
#include "HK_all_include.h"
extern Uint16 RamfuncsLoadSize;
void InitLED(void);
//Uint16 Error;
//Uint16 Tmp = 0;
void main(void)
   InitSysCtrl();
   DINT;
   InitPieCtrl();
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
   memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (Uint32)&RamfuncsLoadSize);
   //InitLED();        //LED初始化
   //SCI_Init();
   //open_uart_debug();
  // printf("\r\n\r\nDSP is ready!\r\n");
    //softResetIIC_BUS();         //软件复位IIC从设备
           //InitI2C_Gpio();             //io 初始化为IIC
           //I2CA_Init();                //HW IIC初始化,100KHz
           //Timer0_init();
           //ADC_Config();
           //LigntVal = 0x71;//BIT6到BIT4为亮度调节,BIT0是  1 开启/0关闭
           //TM1650_Send(CMD_SEG,LigntVal);   //8级亮度,开启显示
           //TM1650_Send(DIG1,SEG7Table[0]);  //GID1
           //TM1650_Send(DIG2,SEG7Table[0]);  //GID2
           //TM1650_Send(DIG3,SEG7Table[0]);  //GID3
           //TM1650_Send(DIG4,SEG7Table[0]);  //GID4
   //        Running.showNum = PWM7BLED.PWMstep;
           //Running.showNum = AdcResult.ADCRESULT2;
   //        Running.showhex[0]=SEGHexBLK;
   //        Running.showhex[1]=SEGHexBLK;
   //        Running.showhex[2]=SEGHexBLK;
   //        Running.showhex[3]=SEGHexBLK;
           //InitEPwm7();         //初始化PWM7外设功能以及GPIO41作为PWM7B引脚输出
           //PWM7BLED.dutyDir = LEDUP;
           EALLOW;
           SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;
           EDIS;
   InitEPWM_AQ_DB();
   EALLOW;
   SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;
   EDIS;
   PieCtrlRegs.PIECTRL.bit.ENPIE = 1;          // Enable the PIE block
   EINT;                                      // Enable Global interrupt INTM
   ERTM;
           while(1)
                   asm ( " NOP" );
                   /*if(timer0Base.Mark_Para.Status_Bits.OnemsdFlag == 1)
                                       timer0Base.Mark_Para.Status_Bits.OnemsdFlag = 0;
                                           if(timer0Base.msCounter >= 1000)   //ms
                                                   timer0Base.msCounter = 0;
                                                   if(k >= 400)
        k = 0;
                                                             EPwm1Regs.CMPA.half.CMPA = TonC[k];
                                                             EPwm1Regs.CMPB = TonC[k];
                                                             k++;
                       // AdcRegs.ADCSOCFRC1.all = 0X000F; //软件触发AD 的 SOC0--SOC3采样
                       //ChangePWMDutyCycle();//改变占空比,进而改变PWM输出,控制D400
                    // EPwm1Regs.CMPA.half.CMPA = 500;
                    // EPwm2Regs.CMPA.half.CMPA = 500;
                    // EPwm3Regs.CMPA.half.CMPA = 500;
                   //SegScanTask(&Running);  //数码管、三色LED、按键操作函数------关键函数
                   //handleScanKeyforPWM_LED(&Running);//PWM例程的扫描按键处理函数
/*void InitLED()
        EALLOW;
        D400MUX = 0;   //GPIO功能
        D400DIR = 1;   //输出
        D401MUX = 0;
        D401DIR = 1;
        D402MUX = 0;
        D402DIR = 1;
        RGB_R_MUX = 0;
        RGB_R_DIR = 1;
        RGB_G_MUX = 0;
        RGB_G_DIR = 1;
        RGB_B_MUX = 0;
    RGB_B_DIR = 1;
    EDIS;
