5745|1
362
STC单片机PWM的实现方法与原理 [复制链接]
昨晚给师弟讲课的内容,利用stc的一款单片机提供的pwm实现变频输出。程序将变频pwm输出到led上作测试。
#include
sfr   CCON   = 0xD8;
sfr   CMOD   = 0xD9;
sfr   CL     = 0xE9;
sfr   CH     = 0xF9;
sfr   CCAP0L = 0xEA;
sfr   CCAP0H = 0xFA;
sfr   CCAPM0 = 0xDA;
sfr   CCAPM1 = 0xDB;
sbit  CR   = 0xDE;
sbit  led   = P2^0;
unsigned char duty = 0x80;
unsigned int fre = 0xffff;
void timer0_int (void) interrupt 1 using 1
TH0 = fre >> 8;
TL0 = fre & 0xff;
led = ~led;
void timer0_init(void)
    TMOD &= 0xf0; /* Set timer 0 */
TMOD |= 0x1; /* mode 1 */
TH0 = 0xff;
TL0 = 0xff;
TR0 = 1; /* Enable timer 0 */
ET0 = 1; /* Enable timer 0 interrupt */
void pwm_init(void)
    CMOD = 0x4;  // Use timer0
    CL = 0x0;
    CH = 0x0;
    CCAP0H = duty;    //Duty Cycle
    CCAPM0 = 0x42;   // PWM mode
    CR = 1;   //Start PCA Timer.
void soft_delay(unsigned int _1ms)
unsigned int tmp;
while(_1ms--!=0) {
  for(tmp=0;tmp<144;tmp++);
void check_key(void)
unsigned char key1,key2;
key1 = P1 & 0xf;
soft_delay(20);
key2 = P1 & 0xf;
if(key1 == key2 && key1 != 0xf){
  if(key1 == 0xe)
   duty += 16;
  else if(key1 == 0xd)
   duty -= 16;
  else if(key1 == 0xb)
   fre += 0xff;
  else if(key1 == 0x7)
   fre -= 0xff;
  while((P1 & 0xf) != 0xf);
void main (void)
pwm_init();
timer0_init();
EA = 1;
while(1){
  CCAP0H = duty;
  check_key();
此帖出自单片机论坛
STC12C5410AD芯片的PWM有中断吗?  详情 回复 发表于 2011-1-19 18:55
点赞 关注(1)
52
回复 楼主 yuandayuan6999 的帖子
此帖出自单片机论坛
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
