5979|4
459
37
Xilinx ISE 12 出补丁了 [复制链接]
AR #35331 - ISE Design Suite 12 - Shortcuts and desktop icons are not created when language is set to anything other than English or Japanese
My language localization is set to a language other than English or Japanese. After installation, my desktop icons and shortcuts were not created, and the following error occurs:
"Failed to create link xxx.lnk to xxx.xxx"
How can I create the shortcuts and desktop icons?
Solution
Localization settings of English and Japanese are the only supported languages. Any other language setting is not supported and can cause issues with other Xilinx ISE Design Suite tools.
To install the shortcuts and desktop icons, download the following patch and place it into your installed Xilinx directory. Xilinx recommends that you backup your "libwiclient.dll" file prior to dropping the new patch file so that you can revert back if needed. After applying the patch, run shortcutSetup.bat from the Xilinx ISE Design Suite in the common/bin/nt(64) location.
For the patch, download and unzip the file (see the readme file for more information).
Patch: ftp://ftp.xilinx.com/pub/swhelp/ise12_updates/ar35331.zip
此帖出自FPGA/CPLD论坛
ISE 10.1是我用到现在最稳定的。比8.1,和9.1都要好。 ISE 12 是专门为Virtex-6和spartan-6定制的,所以要用这两种片子就只能使用ISE 12,不想跟进也么办法呀。  详情 回复 发表于 2010-9-15 12:55
103
ISE12出来了?:Q 11还没整明白了
此帖出自FPGA/CPLD论坛
3138
裸片初长成(初级)
 看见v12出才两天就来打补丁?这Xilinx也忒猴急了,说明有“办事不牢”之嫌!感觉ISE每次升级都至少要等到出sp2才算稳定。
此帖出自FPGA/CPLD论坛
6892
建议大家ISE能用就行,不要不断跟进!
此帖出自FPGA/CPLD论坛
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
此帖出自FPGA/CPLD论坛
