5134|1
846
3D Analysis of Helical Slow-wave Structures for space TWTs:C [复制链接]
The  major  RF  performances  of  Traveling Wave Tubes (TWTs) are determined by the Slow-wave   Structure   (SWS),   which   is customarily  characterized  by   the    cold
parameters:   phase  velocity  (or   dispersion curve), interaction impedance and attenuation. The conventional procedures for evaluating these parameters make use of either analytical methods,   entailing   several   simplifying approximations,  or experimental approaches that produce results affected by measurement errors. While these methods have proven to be very successful in a number of instances, some
applications require high level of accuracy in particular for the phase velocity (typically in
the range of 0.5%.
3168.rar
201.37 KB, 下载次数: 16
此帖出自PCB设计论坛
谢谢,我现在在做慢波器件,可是有很多问题搞不懂,以前方向是半导体器件,想请教师兄可以从哪些方面入手? 多谢哦!  详情 回复 发表于 2006-12-25 11:42
个人签名生活就是一场真人秀!
Re: 3D Analysis of Helical Slow-wave Structures for space TW
此帖出自PCB设计论坛
直播时间:4月22日(周二)10:00
直播奖励:京东卡、蓝牙温湿度计、定制水杯
