3494|0
265
ADI Parallel Port SDRAM Controller Reference Design [复制链接]
Introduction The ADI parallel port SDRAM controller reference design connects SDRAM to the parallel port of an Analog Devices Incorporated (ADI)
ADSP-2126x Sharc DSP device and is implemented in Altera® FPGAs and CPLDs.
Altera supplies the reference design as Verilog HDL source code. The reference design includes a testbench that allows you to test the Verilog HDL source code.
The purpose of this reference design is to demonstrate that Altera devices provide a low cost SDRAM interface for ADI Sharc DSP devices.
an334.pdf
752.77 KB, 下载次数: 21
此帖出自FPGA/CPLD论坛
有奖直播 | AI之眼——安森美图像传感器 报名中
直播主题:AI之眼——安森美图像传感器
报名观看直播、直播间提问、填写问卷均有机会获得精美礼品!
