3597|0
265
Altera参考设计-AN 505: 3GPP LTE Turbo Reference Design [复制链接]
The Altera® 3GPP LTE Turbo Reference Design demonstrates using Turbo codes for encoding with trellis termination support, and forward error correction (FEC) decoding with early termination support. The reference design is suitable for 3GPP long term evolution (LTE) channel card or baseband modem applications compatible with the 3GPP Technical Specification (reference 1).
Turbo codes were first proposed by Berrou (and others) in 1993 (reference 2). Since its introduction, turbo code has become the coding technique of choice in many communication and storage systems due to its near Shannon limit error correction capability. These applications include 3GPP, consultative committee for space application (CCSDS) telemetry channel coding, worldwide interoperability for microwave access (WiMAX), and 3GPP LTE, which require throughputs in the range from two to several hundred Mbps.
an505.pdf
387.57 KB, 下载次数: 16
此帖出自FPGA/CPLD论坛
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
