3122|2
New head job opportunity for you [复制链接]
Here are some new job opportunities for you from EMC China,if it's fit for you .Plz touch me,thanks for your support!
Christina(028)86701200 QQ:1106525264
Principal Software QA Engineer - USD/Chengdu
Responsibilities
  • Obtaining testing requirements, and generating test plan
  • Improving test coverage, efficiency and SW quality
  • The Design, Development and optimize new or existing testing tools and methodology.
  • The ability to analyze complex technical problems, propose design modifications and the implementation of comprehensive solutions
  • The ability and knowledge to implement code modifications across a range of Host Operating Systems
  • Participate in reviews of product feature requirements, functional specs and design documents, provide consultancy to development team in aspects of SW reliability, availability, scalability, security, interoperability, installability and Serviceability
  • Lead test plan design and implementation
  • Lead test tool design and test methodology deployment
  • Possess the technical understanding to work directly , promote team technical competence enhancement
  • Offer changes/suggestions to processes and products
  • Validate the tests and tools on multiple operating systems
  • Install and configure necessary software and hardware
Requirements
  • BS/MS CS, CSE, EE or Related Discipline
  • Knowledge of build environments, development tools compilation and debugging techniques under Linux, UNIX and Microsoft Platforms.
  • 8 to 12 years Software development experience
  • Extensive PERL development experience
  • Experience with object oriented software design
  • C, C++, Java, HTML,CGI development experience
  • Experience working in software development teams under source control project environments
  • Demonstrated ability to perform well in a fast paced and challenging environment
  • Demonstrated understanding of test automation methodologies and principles
  • Ability to lead projects and small teams
  • Strong analytical and problem solving skills
  • Strong written and verbal communication skills, including documenting and communicating technical information
  • Desirable to have experience in setting up and defining Hardware/Software Test/Configurations and knowledge of its importance to the development of software test scripts and QA testing.
Senior Software Quality Engineer
Job Description
The individual would be joining a test development and planning team that is responsible for designing and implementing functional tests and planning test cycles for features implemented by the USD (Unified Storage Division) engineering organization. The candidate has to be able to understand USD products, architecture and how different features may affect each other; develop test strategies at the group and cross-functional levels, and drive their implementation through technical leadership of cross-functional test development teams. The candidate should have the technical understanding to work directly with software developers to influence design changes to improve quality and testability of the software. The candidate would also write and automate tests and plan test configurations. There is a potential to develop enhancements, modifications, and corrections to existing test methodologies and processes.
Responsibilities
-       Participate in reviews of product features requirements, functional specs and design documents; identify missing testability features and drive their implementation by working closely with feature developers and leads
-       Responsible for architecting test strategy at group and cross-functional levels for features and groups of features, and/or release
-       Responsible for working with feature test leads from other test organizations to identify and ensure comprehensive and resource-effective implementation of the feature test strategy
-       Responsible for Designing, writing and automating new tests; may be asked to update existing tests (automated and/or manual)
-       Configure and execute manual and automated tests in accordance with testing methodologies while using a variety of tools / test harnesses.
-       Work closely with developers from conception to completion of features.
-       Actively lead teams of test development and test engineers, and/or individual engineers
-       Offer changes/suggestions to processes and products
-       Represent the group at various meetings
-       Proactively identify problems and propose solutions
此帖出自Linux开发论坛
BZ你说的是月薪????、  详情 回复 发表于 2012-3-22 12:50
354
税后能给2万8吗
此帖出自Linux开发论坛
849
回复 沙发 青叶漂零 的帖子
BZ你说的是月薪????、
此帖出自Linux开发论坛
个人签名只有想不到,没有做不到。
