2589|0
Coyote,Wolf v1.2,Wolf v1.4,Phoenix这几种platform有什么具体的区别吗?? [复制链接]
在看文档时发现什么有这样的定义:Edit file \PLATFORM\SMDK2440A\smdk2440a.bat to select the target platform you are working on, setting the variables according with the following table:
Platform Settings
Coyote
                 set COYOTE=1
                 set WOLF=
                 set WOLF_REV_1_4=
                 set LCD_CLAA057VA01=
                 set LCD_TS40WD2B_03=
                 set PHOENIX=
Wolf v1.2
                          set COYOTE=
                          set WOLF=1
                          set WOLF_REV_1_4=
                          set PHOENIX=
Wolf v1.4
                           set COYOTE=
                           set WOLF=1
                           set WOLF_REV_1_4=1
                           set PHOENIX=
Wolf v1.2 with
CLAA057VA01 display
(5.7”)
                        set COYOTE=
                        set WOLF=1
                        set WOLF_REV_1_4=
                        set LCD_CLAA057VA01=1
                        set PHOENIX=
Wolf v1.4 with
TS40WD2B-03 (4.0”)
or Chilin LR043HC211
(4.3”) display
                set COYOTE=
                set WOLF=1
                set WOLF_REV_1_4=1
                set LCD_TS40WD2B_03=1
                set PHOENIX=
Phoenix
                set COYOTE=
                set WOLF=
                set WOLF_REV_1_4=
                set PHOENIX=1
