3240|5
关于WIFI驱动的问题 [复制链接]
我在WIFI加载的时候,在走到NdisReadConfiguration这个函数时,NdisReadConfiguration调用失败,谁知道是什么原因呀?
我把嵌入式板块的wifi所有帖子都看完,不信搞不懂。哈哈哈。  详情 回复 发表于 2010-6-4 14:07
LZ,你看看函数的返回值、或用GetLastError()
看不到代码,如果能知道原因,可真是神奇!
84
早上好,/////////////////////////////////////////////////////////////////////////////
NDIS_STATUS SDNdisGetSDDeviceHandle(PMRVDRV_ADAPTER pAdapter)
    NDIS_STATUS status;                       // intermediate status
    NDIS_HANDLE configHandle;
    NDIS_STRING activePathKey = NDIS_STRING_CONST("Active");//ActivePath
    PNDIS_CONFIGURATION_PARAMETER pConfigParm;
       // open a handle to our configuration in the registry
    NdisOpenConfiguration(&status,
                          &configHandle,
                          pAdapter->ConfigurationHandle);
    if (!NDIS_SUCCESS(status)) {
        DBGPRINT(DBG_LOAD | DBG_ERROR,
            (L"SDNdis: NdisOpenConfiguration failed (0x%08X)\n",
                   status));
        return status;
        // read the ActivePath key set by the NDIS loader driver
    NdisReadConfiguration(&status,
                          &pConfigParm,
                          configHandle,
                          &activePathKey,
                          NdisParameterString);
                if(NDIS_STATUS_RESOURCES == status)
                                RETAILMSG(1, (L"***!!!!!!!!!!!!!!!NdisReadConfiguration  NDIS_STATUS_RESOURCES\r\n"));
            (L"SDNdis: Failed to get active path key (0x%08X)\n",
                   status));
             // close our registry configuration
        NdisCloseConfiguration(configHandle);
        return status;
    if (NdisParameterString != pConfigParm->ParameterType) {
            (L"SDNdis: PARAMETER TYPE NOT STRING!!!\n"));
        return status;
    if (pConfigParm->ParameterData.StringData.Length > sizeof(pAdapter->ActivePath)) {
            (L"SDNdis: Active path too long!\n"));
        return NDIS_STATUS_FAILURE;
        // copy the counted string over
    memcpy(pAdapter->ActivePath,
           pConfigParm->ParameterData.StringData.Buffer,
           pConfigParm->ParameterData.StringData.Length);
  if ( pConfigParm->ParameterData.StringData.Length == 0 )
        DBGPRINT(DBG_LOAD | DBG_WARNING,
            (L"SDNdis: Active path str length is 0, perhaps no card!\n"));
    }else{
            (L"SDNdis: Active path str == %s\n",pConfigParm->ParameterData.StringData.Buffer));
    DBGPRINT(DBG_LOAD | DBG_LOAD,
            (L"SDNdis: Active Path Retrieved: %s \n",pAdapter->ActivePath));
        // now get the device handle
    pAdapter->hDevice = SDGetDeviceHandle((DWORD)pAdapter->ActivePath, NULL);
    return NDIS_STATUS_SUCCESS;
这个函数走到NdisReadConfiguration时失败,请问这是什么原因呀?谢谢 !
67
关注一下,WIFI在不久的将来也要整
79
请问高手,WIFI的原理是什么?
78
