1653|13
大佬救救我 [复制链接]
#include "reg52.h"
#include "lcd1602.h"
#include "delay.h"
#include "HCSR04.h"
#include "eeprom.h"
#include "key.h"
sbit beep = P3^7;    //蜂鸣器控制脚
bit flag_timer = 0;    //定时时间到标志位
bit flag_beep = 0;    //报警标志位
short Dis_up = 50;    //距离上限 默认50cm
void EEPROM_Read(void)          //读EEPROM中保存的数据
 Dis_up = byte_read(0x2000+1)*256+byte_read(0x2000+2);  //读取距离上限数据
void EEPROM_Write(void)     //写数据进eepROM
 SectorErase(0x2000);     //擦除扇区
 byte_write(0x2000+0,12);      //存储标志位
 byte_write(0x2000+1,Dis_up/256);  //存数据  Dis_up不是八位的数据 可能会大于256 所以分为成高低八位存储
 byte_write(0x2000+2,Dis_up%256); //存数据
void EEPROM_Check(void)     //检测 是不是第一次使用芯片或者芯片是否正常
 if(byte_read(0x2000+0)!=12)
  EEPROM_Write();     //写数据进EEPROM
 else
  EEPROM_Read();     //读数据从EEPROM
* 函数: void Timer0Init(void)
* 描述: 定时器1初始化函数
* 参数: none.
* 返回: none.
* 备注:定时2ms 12MHz
void Timer1Init(void) //2毫秒@12MHz
 TMOD &= 0x0F;  //设置定时器模式
 TMOD |= 0x10;  //设置定时器模式
 TL1 = 0xCD;   //设置定时初值
 TH1 = 0xF8;   //设置定时初值
 TF1 = 0;   //清除TF1标志
 TR1 = 1;   //定时器1开始计时
 ET1 = 1;   //开始计数
 EA = 1;    //开总中断
void main(void)
 unsigned char var = 0;
 unsigned int Fdistance,Ldistance,Rdistance;
 EEPROM_Check();       //读取EEPROM
 Timer1Init();       //2毫秒@12MHz
 HCSR04_Init();
 Lcd1602_Init();         //LCD1602液晶初始化
 Lcd1602_String(0,0,"    F:          ");
 Lcd1602_String(0,1,"L:      R:      ");
 while(1)
    if(flag_timer==1)      //600毫秒赋一次值 flag_timer是标志位
   flag_timer = 0;      //清除标志  等待下一次600ms
   if(HCSR04_Count(&Fdistance)==0)  //测距 将距离值传递给distance
    Lcd1602_Write_Com(0x80+6);
    Lcd1602_Write_Data(Fdistance%1000/100+0x30);
    Lcd1602_Write_Data(Fdistance%1000%100/10+0x30);
    Lcd1602_Write_Data(Fdistance%1000%100%10+0x30);
    Lcd1602_Write_Data('c');
    Lcd1602_Write_Data('m');
   else
    Lcd1602_Write_Data('-');
   if(HCSR04_Count1(&Ldistance)==0)  //测距 将距离值传递给distance
    Lcd1602_Write_Com(0xc0+2);
    Lcd1602_Write_Data(Ldistance%1000/100+0x30);
    Lcd1602_Write_Data(Ldistance%1000%100/10+0x30);
    Lcd1602_Write_Data(Ldistance%1000%100%10+0x30);
   else
    Lcd1602_Write_Com(0xC0+2);
   if(HCSR04_Count2(&Rdistance)==0)  //测距 将距离值传递给distance
    Lcd1602_Write_Com(0xc0+10);
    Lcd1602_Write_Data(Rdistance%1000/100+0x30);
    Lcd1602_Write_Data(Rdistance%1000%100/10+0x30);
    Lcd1602_Write_Data(Rdistance%1000%100%10+0x30);
   else
    Lcd1602_Write_Com(0xC0+10);
  KEY_Set();
  if(Fdistance<Dis_up||Ldistance<Dis_up||Rdistance<Dis_up) //当前距离小于上限
   var++;
   if(var>5)      //为了防止误差多次判断距离是否超限
    var = 0;
    flag_beep = 1;    //开报警标志 执行报警程序在定时器中断
  else
   var = 0;
   flag_beep = 0;     //关报警标志位
//定时器1中断服务函数
void tm1_isr() interrupt 3 using 1
 static unsigned int cnt=0,cnt1;
  TF1 = 0;
 TL1 = 0x30;    //设置定时初值
 if(cnt++ >= 300)     //2ms*300 =600ms
  cnt = 0;
  flag_timer = 1;   //600ms到 赋值标志为1  600ms赋一次 600ms不是必须的  可以自己修改
 if(cnt1++>=200)   //2ms*200 =400ms
  cnt1 = 0;
  if(flag_beep==1)  //报警标志位打开
   beep = ~ beep;  //蜂鸣器控制脚取反 400ms取反一次 产生滴滴滴 响声 而不是一直长鸣
  else
   beep = 1;    //高电平关闭报警
一直是这个错误,请问 怎么解决
此帖出自51单片机论坛
还是要先巩固C基础再上马   详情 回复 发表于 2023-2-27 10:18
3230
missing function prototype 缺少delay.c这个文件的byte_read函数原型。
此帖出自51单片机论坛
该怎么弄,就给一段代码,该如何接下来的操作,我刚学 是个小白  详情 回复 发表于 2023-2-18 22:27
7059
你们delay.c没有帖出来呀?是不是学习别人的代码,是不是没有考完过来。
此帖出自51单片机论坛
lugl4313820 发表于 2023-2-18 22:00 你们delay.c没有帖出来呀?是不是学习别人的代码,是不是没有考完过来。
对,就是别人的代码,我想做个超声波预测,请问该怎么建立工程,
此帖出自51单片机论坛
你别急,看看keil如何新建工程,去学学郭天祥10天学会单片机的教程。  详情 回复 发表于 2023-2-19 07:05
tagetage 发表于 2023-2-18 22:00 missing function prototype 缺少delay.c这个文件的byte_read函数原型。
此帖出自51单片机论坛
4942
把编译器报错去百度下哟
此帖出自51单片机论坛
百度上搜不出来啊,大佬,救命  详情 回复 发表于 2023-2-18 23:09
吾妻思萌 发表于 2023-2-18 22:59 把编译器报错去百度下哟
百度上搜不出来啊,大佬,救命
此帖出自51单片机论坛
7059
必胜客 发表于 2023-2-18 22:26 对,就是别人的代码,我想做个超声波预测,请问该怎么建立工程,
此帖出自51单片机论坛
好的,谢谢  详情 回复 发表于 2023-2-19 13:27
189
代码都考过来了,不会建立工程?不太可能吧!代码能看懂吧。
此帖出自51单片机论坛
真不会,新手小白,简单的新建工程还是会的 ,复杂的就不会了,就比如这个,是真的一点头绪没有  详情 回复 发表于 2023-2-19 13:26
shuangchafeng 发表于 2023-2-19 11:16 代码都考过来了,不会建立工程?不太可能吧!代码能看懂吧。
此帖出自51单片机论坛
lugl4313820 发表于 2023-2-19 07:05 你别急,看看keil如何新建工程,去学学郭天祥10天学会单片机的教程。
好的,谢谢
此帖出自51单片机论坛
4942
调试还有一个方法 你先吧代码复制一份砍一半试试 通过分步多次调试看看程序编译到哪行就不行了,就能定位到啦~
此帖出自51单片机论坛
26
看一看
此帖出自51单片机论坛
7671
还是要先巩固C基础再上马
此帖出自51单片机论坛
默认摸鱼,再摸鱼。2022、9、28
