4037|0
565
【GD32L233C-START评测】5、Flash读写——使用内部Flash存储数据 [复制链接]
相关文章:
【GD32L233C-START评测】1、优点与缺点都很明显的GD32L233C-START(开箱)
【GD32L233C-START评测】2、非阻塞方式点灯,blink,blink,blink……
【GD32L233C-START评测】3、pwm实现呼吸灯
【GD32L233C-START评测】4、串口不定长数据接收
1、关于GD32 Flash
GD32 flash官方称为FMC。
2、关于GD32L233CCT6 flash
本次使用的GD32L233CCT6 flash大小为256k;
 可以看出,分为64页,从0-63页,每页大小为4kb;
手册上说,支持32位整字和16位半字编程,但是库函数只有整字编程。
3、代码实现
#define FLASH_PAGE_SIZE  		   		 	0x1000 //4k
void FlashWrite(uint16_t len,uint8_t  *data,uint32_t addr_start)
	uint16_t i=0;
	uint32_t temp=0;
	uint32_t addr=addr_start;
	fmc_state_enum  fmc_state=FMC_READY;
	fmc_unlock();
	for(i=0;i<len/4;i++)
		temp = (data[0]<<0)+(data[1]<<8)+(data[2]<<16)+(data[3]<<24);
		fmc_state=fmc_word_program(addr, temp);
		if(fmc_state!=FMC_READY)
			return;
		fmc_flag_clear(FMC_FLAG_END | FMC_FLAG_WPERR | FMC_FLAG_PGAERR | FMC_FLAG_PGERR);
		data += 4;
		addr += 4;
	if((len % 4)==3)
		temp = (data[0]<<0)+(data[1]<<8)+(data[2]<<16);
		temp = temp | 0xff000000;
		fmc_state=fmc_word_program(addr,temp);
	else
		if((len % 4)==2)
			temp = (data[0]<<0)+(data[1]<<8);
			temp = temp | 0xffff0000;
		else
			if((len % 4)==1)
				temp = (data[0]<<0);
				temp = temp |  0xffffff00 ;
	fmc_lock();
void FlashRead(uint16_t len,uint8_t *outdata,uint32_t addr_start)
	uint32_t addr;
	uint16_t i;
	addr = addr_start;
	for(i=0;i<len;i++)
		*outdata = *(uint8_t*) addr;
		addr = addr + 1;
		outdata++;
void FlashErase(uint32_t start, uint32_t end)
	uint32_t EraseCounter;
	  /* unlock the flash program/erase controller */
    fmc_unlock();
    /* clear all pending flags */
    /* erase the flash pages */
    while(start < end)
		EraseCounter = start/FLASH_PAGE_SIZE;
        fmc_state=fmc_page_erase(EraseCounter*FLASH_PAGE_SIZE);
			return;
		start += FLASH_PAGE_SIZE;
    /* lock the main FMC after the erase operation */
    fmc_lock();
4、读写测试
使用最后一页(0x0803E000-0x0803 FFFF),测试读写。
#define APP_DATA_SATRT_ADDR  		   		 	0x0803E000 //4k
#define TEST_DATA_LEN    11
uint8_t WriteData[TEST_DATA_LEN]={1,2,3,4,5,6,7,8,9,10,11};
uint8_t  ReadData[TEST_DATA_LEN]={0,0,0,0,0,0,0,0,0,0 ,0};
void FlashTest(void)
	FlashErase(APP_DATA_SATRT_ADDR, APP_DATA_SATRT_ADDR+FLASH_PAGE_SIZE);
	FlashWrite(TEST_DATA_LEN,WriteData,APP_DATA_SATRT_ADDR);
	FlashRead(TEST_DATA_LEN,ReadData, APP_DATA_SATRT_ADDR);
	printf("Write Data[");
	for(uint8_t i=0;i<TEST_DATA_LEN;i++)
		printf(" %d",WriteData[i]);
	printf("]\r\n");
	printf("Read Data[");
		printf(" %d",ReadData[i]);
	printf("]\r\n");
5、实验现象
 可以发现,写入的和读出的数据是一样的。
此帖出自GD32 MCU论坛
个人签名stm32/LoRa物联网:304350312
推荐帖子
常用网络命令
常用网络命令 计算机网络的主要优点是能够实 ...
各大公司IC类免费样品申请
TPS2000系列数字存储示波器 详细资料申请 http://digital.ni.com/worldwide/china.nsf/sb/Download?OpenDocument&node=162000_zh ...
ucosii在STM32中的移植
10740
液晶1602 显示汉字研究
液晶1602显示字符研究 1602是一款最常用也是最便宜的液晶显示屏。最多可以显示两行标准字符,每行最多可以显示16个字符。 1602 ...
电容的安秒积和电感的伏秒积
  《电工学》或者《电路分析》教材中,对电容的定义是这样的,如图(01),满足图(01)式的电路元件,就是电容。式中i和u都是时间 ...
邀您参加Microchip在线研讨会——为您的IoT传感器设计节能型解决方案
Microchip将于6月29日(周二)举办题为《为您的IoT传感器设计节能型解决方案》的在线研讨会。 543966 在设计电池供电 ...
浅谈驱动芯片的绝缘安规标准
众所周知,各个行业各个领域都有其需要遵循的标准规范,一般会对其产品需要达到的使用条件提出各方面的要求。诸如电机驱动、光伏 ...
【HC32F4A0开发板测评】+I2S语音播放测试
本帖最后由 jinglixixi 于 2023-2-22 09:20 编辑 在HC32F4A0开发板上,为进行音频播放配置了I2S音频电路,所用的芯片为WM8731 ...
超声片/超声换能器/压电陶瓷片驱动波形
超声片/超声换能器/压电陶瓷片驱动波形必须用正弦波 才有良好的效果,比如电声转换效率、波形失真度、功率衰减等;很多负载必须 ...
MicroPython ESP32S3 蓝牙 每包字节大小问题求助
求助各位大佬 我用2块ESP32S3开发板(MicroPython 1.22),1块服务端1块客户端,蓝牙通信已经成功,也交换了MTU,但服务端每 ...
