2145|2
【雅特力开发板 AT32F421 测评】2、读一下MCU的型号 [复制链接]
       芯片有唯一的编号,看下文档时边有介绍读CORTEX型号的。就是看看是M0, M1,M4。
       现在试一下:
      首选选择USART的printf例程,读一下例程,我觉得重点是那个重定义的函数在哪里了。我找了老半天,终于找到在at32_board.c里:
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
  * [url=home.php?mod=space&uid=159083]@brief[/url] Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  USART_SendData(AT32_PRINT_UART, ch);
  while ( USART_GetFlagStatus(AT32_PRINT_UART, USART_FLAG_TRAC) == RESET );
  return ch;
 当然还得微库打勾:
以下是程序:直接读地址的内容.
int main(void)
  /* USART1 configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  UART_Print_Init(115200);
  /* Output a message on Hyperterminal using printf function */
  printf("\n\rUSART Printf Example: retarget the C library printf function to the USART\n\r");
	cortex_id = *(uint32_t *)0xE000ED00; //读取 cortex 型号
	if((cortex_id == 0x410FC240) || (cortex_id == 0x410FC241))
    printf("This chip is Cortex-M4.\r\n");
  else
    printf("This chip is Other Device.\r\n");
  while (1)
以下是运得结果:
谢谢分享,期待后续   详情 回复 发表于 2021-4-8 21:46
赞赏
查看全部赞赏
点赞(2) 关注
1942
这也能读?都没有尝试过哈!
7671
谢谢分享,期待后续
默认摸鱼,再摸鱼。2022、9、28
