1698|0
1704
msp430f5529 uart pwm adc [复制链接]
//msp430f5529的串口使用程序使用示例
//--------------------------------------------- uart 头文件 -------------------------------------------------------------//
#ifndef UART_H_
#define UART_H_
#include <msp430f5529.h>
#include "config.h"
//默认为115200
void USCIA0_Init(void);
void USCIA0_SendChar(u8 c);
u8 USCIA0_ReceiveChar(void);
void USCIA0_SendString(u8 *str);
void USCIA1_Init(void);
void USCIA1_SendChar(u8 c);
u8 USCIA1_ReceiveChar(void);
void USCIA1_SendString(u8 *str);
//void Uart1_Send_AF(void);
#endif /* #ifndef USCI_A0_h */
//使用例程
void main(void)
    volatile unsigned int i;
    u8 data;
    dog_Disable();
    UCS_Init();
    //key_Init();
    USCIA0_Init();
    while(1)
        USCIA0_SendChar('A');
        USCIA0_SendString(" luoxn28");
        data = USCIA0_ReceiveChar();
if(data != 0)
        USCIA0_SendChar(data);
        USCIA0_SendChar('\r');USCIA0_SendChar('\n');
        delay(10);
//--------------------------------------------- uart 源文件 -------------------------------------------------------------//
#include "msp430_UART.h"
#if USCIA0_EN >0
*名称:USCIA0_Init
*功能:串口初始化
*入口参数:无
*出口参数:无
*说明:设置为P3.3和P3.4为串口通信端口 3.3-UCA0TXD 3.4-UCA0RXD
  P3SEL |= BIT3+BIT4;                       // P3.3,4 = USCI_A0 TXD/RXD
  UCA0CTL1 |= UCSWRST;                      // **Put state machine in reset**
  UCA0CTL1 |= UCSSEL__ACLK;                     // ACLK
  UCA0BR0 = 34;           // 4MHz 115200
  UCA0BR1 = 0;            // 4MHz 115200
  UCA0MCTL |= UCBRS_6 + UCBRF_0;            // Modulation UCBRSx=1, UCBRFx=0
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  //IE2 |= UCA0RXIE + UCA0TXIE;  // Enable USCI_A0 TX/RX interrupt
  //IE2 |= UCA0RXIE;             // Enable USCI_A0 RX interrupt
  //__bis_SR_register(GIE);      // Enter LPM3 w/ interrupts enabled
//串口0发送字符函数
    UCA0TXBUF=c;
    while(!(UCA0IFG & UCTXIFG));   // USCI_A0 TX buffer ready?
    UCA0IFG &= ~UCTXIFG;
//串口0接收字符函数
    u8 data = 0;
//阻塞式返回值
    while(!(UCA0IFG & UCRXIFG));   // USCI_A0 TX buffer ready?
    UCA0IFG &= ~UCRXIFG;
    data = UCA0RXBUF;
    return data;
//非阻塞式返回值
    if(UCA0IFG & UCRXIFG)
data = UCA0RXBUF;
return data;
//串口0发送字符串函数
    while(*str != '\0')
        USCIA0_SendChar(*str);
        str++;
#endif //#if USCIA0_EN >0
#if USCIA1_EN > 0
*名称:USCIA0_Init
*功能:串口初始化
*入口参数:无
*出口参数:无
*说明:设置为P4.4和P4.5为串口通信端口 4.4-UCA1TXD 4.5-UCA1RXD
//串口1初始化函数
  P4SEL |= BIT4+BIT5;                       // P3.3,4 = USCI_A0 TXD/RXD
  UCA1CTL1 |= UCSWRST;                      // **Put state machine in reset**
  UCA1CTL1 |= UCSSEL__ACLK;                     // ACLK
  UCA1BR0 = 34;           // 4MHz 115200
  UCA1BR1 = 0;            // 4MHz 115200
  UCA1MCTL |= UCBRS_6 + UCBRF_0;            // Modulation UCBRSx=1, UCBRFx=0
  UCA1CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
//串口1发送字符函数
    UCA1TXBUF=c;
    while(!(UCA1IFG & UCTXIFG));   // USCI_A0 TX buffer ready?
    UCA1IFG &= ~UCTXIFG;
//串口1接收字符函数
    u8 data = 0;
//阻塞式返回值
    while(!(UCA1IFG & UCRXIFG));   // USCI_A0 TX buffer ready?
    UCA1IFG &= ~UCRXIFG;
    data = UCA1RXBUF;
    return data;
//非阻塞式返回值
    if(UCA1IFG & UCRXIFG)
data = UCA1RXBUF;
return data;
//串口1发送字符串函数
    while(*str != '\0')
        USCIA1_SendChar(*str);
        str++;
#endif //#if USCIA1_EN > 0
#include "UART.h"
void UART0_Init(void)
    P3SEL = 0x30;                             // 配置P3.4和P3.5脚为串口的输入输出口
    UCA0CTL1 |= UCSWRST;                      // 复位串口
    UCA0CTL1 |= UCSSEL_1;                     // 选择串口时钟为ACLK(32768HZ)
    UCA0BR0 = 0x03;                           // 设置串口波特率为9600
    UCA0BR1 = 0x00;
    UCA0MCTL = UCBRS_3+UCBRF_0;
    UCA0CTL1 &= ~UCSWRST;                     // 打开串口
    UCA0IE |= UCRXIE;                         // 打开串口接收中断
//PWM的程序示例
//--------------------------------------------- pwm头文件 -------------------------------------------------------------//
#ifndef MSP430_TIMER_H_
#define MSP430_TIMER_H_
#include "config.h"
//---------------------- the config of timerA0 pwm ----------------------
void TimerA0_1_PWM_Init(int num, int period); //P1.2
void TimerA0_2_PWM_Init(int num, int period); //P1.3
void TimerA0_3_PWM_Init(int num, int period); //P1.4
void TimerA0_4_PWM_Init(int num, int period); //P1.5
//---------------------- the config of timerA1 pwm ----------------------
void TimerA1_1_PWM_Init(int num, int period); //P2.0
#define TimerA1_1_SetPWM(num) (TA1CCR1=(num))
void TimerA1_2_PWM_Init(int num, int period); //P2.1
#define TimerA1_2_SetPWM(num) (TA1CCR2=(num))
//---------------------- the config of timerA2 pwm ----------------------
void TimerA2_1_PWM_Init(int num, int period); //P2.4
#define TimerA2_1_SetPWM(num) (TA2CCR1=(num))
void TimerA2_2_PWM_Init(int num, int period); //P2.5
#define TimerA2_2_SetPWM(num) (TA2CCR2=(num))
//---------------------- the config of timerB0 pwm ----------------------
void TimerB0_1_PWM_Init(int num, int period); //P5.7
void TimerB0_2_PWM_Init(int num, int period); //P7.4
void TimerB0_3_PWM_Init(int num, int period); //P7.5
void TimerB0_4_PWM_Init(int num, int period); //P7.6
void TimerB0_5_PWM_Init(int num, int period); //P3.5
void TimerB0_6_PWM_Init(int num, int period); //P3.6
#endif
//--------------------------------------------- pwm源文件 -------------------------------------------------------------//
#include "msp430_timer.h"
//period 周期值,num百分比值, timerA0的period要一样
void TimerA0_1_PWM_Init(int num, int period) //P1.2
P1DIR |= BIT2;
P1SEL |= BIT2;
TA0CCR0 = period;
//TA0CCTL1 = OUTMOD_3;//先低电平后高电平
TA0CCTL1 = OUTMOD_7;//先高电平后低电平
TA0CCR1 = num;
TA0CTL |= TASSEL_2 + MC_1;//以SMCLK为时钟源,工作在up模式 SMCLK 1MHz
TA0CTL |= TACLR;     //将计时器A0清零
//TA1CCTL0=CCIE;     //定时器A1的捕获比较器0开启CCIFG位中断
//TA1CCTL1=CCIE;     //捕获比较器1开启中断
void TimerA0_2_PWM_Init(int num, int period) //P1.3
P1DIR |= BIT3;
P1SEL |= BIT3;
TA0CCR0 = period;
//TA0CCTL2 = OUTMOD_3;//先低电平后高电平
TA0CCTL2 = OUTMOD_7;//先高电平后低电平
TA0CCR2 = num;
void TimerA0_3_PWM_Init(int num, int period) //P1.4
P1DIR |= BIT4;
P1SEL |= BIT4;
TA0CCR0 = period;
//TA0CCTL3 = OUTMOD_3;//先低电平后高电平
TA0CCTL3 = OUTMOD_7;//先高电平后低电平
TA0CCR3 = num;
void TimerA0_4_PWM_Init(int num, int period) //P1.5
P1DIR |= BIT5;
P1SEL |= BIT5;
TA0CCR0 = period;
//TA0CCTL4 = OUTMOD_3;//先低电平后高电平
TA0CCTL4 = OUTMOD_7;//先高电平后低电平
TA0CCR4 = num;
//period 周期值,num百分比值, timerA1的period要一样
void TimerA1_1_PWM_Init(int num, int period) //P2.0
P2DIR |= BIT0;
P2SEL |= BIT0;
TA1CCR0 = period;
//TA1CCTL1 = OUTMOD_3;//先低电平后高电平
TA1CCTL1 = OUTMOD_7;//先高电平后低电平
TA1CCR1 = num;
TA1CTL |= TASSEL_2 + MC_1;//以SMCLK为时钟源,工作在up模式 SMCLK 1MHz
TA1CTL |= TACLR;     //将计时器A0清零
void TimerA1_2_PWM_Init(int num, int period) //P2.1
P2DIR |= BIT1;
P2SEL |= BIT1;
TA1CCR0 = period;
//TA1CCTL2 = OUTMOD_3;//先低电平后高电平
TA1CCTL2 = OUTMOD_7;//先高电平后低电平
TA1CCR2 = num;
//period 周期值,num百分比值, timerA2的period要一样
void TimerA2_1_PWM_Init(int num, int period) //P2.4
P2DIR |= BIT4;
P2SEL |= BIT4;
TA2CCR0 = period;
//TA2CCTL1 = OUTMOD_3;//先低电平后高电平
TA2CCTL1 = OUTMOD_7;//先高电平后低电平
TA2CCR1 = num;
TA2CTL |= TASSEL_2 + MC_1;//以SMCLK为时钟源,工作在up模式 SMCLK 1MHz
TA2CTL |= TACLR;     //将计时器A0清零
void TimerA2_2_PWM_Init(int num, int period) //P2.5
P2DIR |= BIT5;
P2SEL |= BIT5;
TA2CCR0 = period;
//TA2CCTL2 = OUTMOD_3;//先低电平后高电平
TA2CCTL2 = OUTMOD_7;//先高电平后低电平
TA2CCR2 = num;
//period 周期值,num百分比值, timerB0的period要一样
void TimerB0_1_PWM_Init(int num, int period) //P5.7
P5DIR |= BIT7;
P5SEL |= BIT7;
TB0CCR0 = period;
//TB0CCTL1 = OUTMOD_3;//先低电平后高电平
TB0CCTL1 = OUTMOD_7;//先高电平后低电平
TB0CCR1 = num;
TB0CTL |= TASSEL_2 + MC_1;//以SMCLK为时钟源,工作在up模式 SMCLK 1MHz
TB0CTL |= TACLR;     //将计时器A0清零
void TimerB0_2_PWM_Init(int num, int period) //P7.4
P7DIR |= BIT4;
P7SEL |= BIT4;
TB0CCR0 = period;
//TB0CCTL2 = OUTMOD_3;//先低电平后高电平
TB0CCTL2 = OUTMOD_7;//先高电平后低电平
TB0CCR2 = num;
void TimerB0_3_PWM_Init(int num, int period) //P7.5
P7DIR |= BIT5;
P7SEL |= BIT5;
TB0CCR0 = period;
//TB0CCTL3 = OUTMOD_3;//先低电平后高电平
TB0CCTL3 = OUTMOD_7;//先高电平后低电平
TB0CCR3 = num;
void TimerB0_4_PWM_Init(int num, int period) //P7.6
P7DIR |= BIT6;
P7SEL |= BIT6;
TB0CCR0 = period;
//TB0CCTL4 = OUTMOD_3;//先低电平后高电平
TB0CCTL4 = OUTMOD_7;//先高电平后低电平
TB0CCR4 = num;
void TimerB0_5_PWM_Init(int num, int period) //P3.5
P3DIR |= BIT5;
P3SEL |= BIT5;
TB0CCR0 = period;
//TB0CCTL5 = OUTMOD_3;//先低电平后高电平
TB0CCTL5 = OUTMOD_7;//先高电平后低电平
TB0CCR5 = num;
void TimerB0_6_PWM_Init(int num, int period) //P3.6
P3DIR |= BIT6;
P3SEL |= BIT6;
TB0CCR0 = period;
//TB0CCTL6 = OUTMOD_3;//先低电平后高电平
TB0CCTL6 = OUTMOD_7;//先高电平后低电平
TB0CCR6 = num;
//msp430f5529的ADC使用示例 单通道连续转换模式和多通道连续转化模式
//--------------------------------------------- ADC12头文件 -------------------------------------------------------------//
#ifndef MSP430_ADC_H_
#define MSP430_ADC_H_
#include "msp430f5529.h"
#include "config.h"
#define ADC_CH1_SEL P6SEL
#define ADC_CH2_SEL P6SEL
#define ADC_CH3_SEL P6SEL
#define ADC_CH4_SEL P6SEL
#define ADC12_CH1 BIT4
#define ADC12_CH2 BIT5
#define ADC12_CH3 BIT6
#define ADC12_CH4 BIT7
void ADC12_Init(void);
void ADC12_GetValue(void);
void ADC12_Disable(void);
void ADC12_Enable(void);
#endif
//单个通道的连续转换 A5 P6.5
    WHEEL_PORT_DIR |= WHEEL_ENABLE;
    WHEEL_PORT_OUT |= WHEEL_ENABLE;                    // Enable wheel
    ADC12CTL0 = ADC12SHT02 + ADC12ON;                  // Sampling time, ADC12 on
    ADC12CTL1 = ADC12SHP;                              // Use sampling timer
    ADC12MCTL0 = ADC12INCH_5;                          // Use A5 (wheel) as input
    ADC12CTL0 |= ADC12ENC;                             // Enable conversions
    ADC_CH2_SEL |= ADC12_CH2;                      // P6.5 ADC option select (A5)
//--------------------------------------------- ADC12源文件 -------------------------------------------------------------//
//file: msp430_adc.c
#include "msp430_adc.h"
#define WHEEL_PORT_DIR P8DIR
#define WHEEL_PORT_OUT P8OUT
#define WHEEL_ENABLE  BIT0
u16 ADC_Value[4];
u16 ADC_ValueOld = 0;
* 说明:ADC12初始化,4通道扫描,A4,A5,A6,A7
ADC_CH2_SEL |= (ADC12_CH1 + ADC12_CH2 + ADC12_CH3 + ADC12_CH4);   // P6.5 ADC option select (A5)
    ADC12CTL0 = ADC12SHT02 + ADC12ON + ADC12MSC;       // Sampling time, ADC12 on
  //ADC12MSC 1:当前转换模式不是单通道单次转换
    ADC12CTL1 = ADC12SHP + ADC12CONSEQ_3;              // Use sampling timer
 //ADC12SHP 使用采样定时器输出作采集、转换信号 SAMPCON
 //重复采样序列
ADC12CTL1 |= ADC12CSTARTADD3;//起始采样通道
    ADC12MCTL4 = ADC12INCH_4;
ADC12MCTL5 = ADC12INCH_5;
ADC12MCTL6 = ADC12INCH_6;
ADC12MCTL7 = ADC12INCH_7 + ADC12EOS;               // 结束采样通道
* 说明:得到4个通道的扫描返回值,放到全局变量ADC_Value[4]中
    //measure ADC value
    ADC12IE = ADC12IE7;                                    // Enable interrupt
    ADC12CTL0 |= ADC12SC;                              // Start sampling/conversion
    __bis_SR_register(LPM0_bits + GIE);                // LPM0, ADC12_ISR will force exit
    ADC12IE = 0x00;                                    // Disable interrupt
    //return ADC_Value;
    ADC12CTL0 &= ~ADC12ENC;                            // Disable conversions
    ADC12CTL0 &= ~ADC12ON;                             // ADC12 off
    ADC12CTL0 |= ADC12ON;                              // ADC12 on
* 说明:4个通道的扫描返回值,更新全局变量ADC_Value[4]中
#pragma vector = ADC12_VECTOR
__interrupt void ADC12_ISR(void)
    switch (__even_in_range(ADC12IV, ADC12IV_ADC12IFG15))
        // Vector  ADC12IV_NONE:  No interrupt
        case  ADC12IV_NONE:
            break;
        // Vector  ADC12IV_ADC12OVIFG:  ADC overflow
        case  ADC12IV_ADC12OVIFG:
            break;
        // Vector  ADC12IV_ADC12TOVIFG:  ADC timing overflow
        case  ADC12IV_ADC12TOVIFG:
            break;
        // Vector  ADC12IV_ADC12IFG0: ADC12IFG0:
        case  ADC12IV_ADC12IFG0:
            break;
        // Vector  ADC12IV_ADC12IFG1:  ADC12IFG1
        case  ADC12IV_ADC12IFG1:
            break;
        // Vector ADC12IV_ADC12IFG2:  ADC12IFG2
        case ADC12IV_ADC12IFG2:
            break;
        // Vector ADC12IV_ADC12IFG3:  ADC12IFG3
        case ADC12IV_ADC12IFG3:
            break;
        // Vector ADC12IV_ADC12IFG4:  ADC12IFG4
        case ADC12IV_ADC12IFG4:
            break;
        // Vector ADC12IV_ADC12IFG5:  ADC12IFG5
        case ADC12IV_ADC12IFG5:
            break;
        // Vector ADC12IV_ADC12IFG6:  ADC12IFG6
        case ADC12IV_ADC12IFG6:
            break;
        // Vector ADC12IV_ADC12IFG7:  ADC12IFG7
        case ADC12IV_ADC12IFG7:
ADC_Value[0] = ADC12MEM4;                  // ADC12MEM = A0 > 0.5AVcc?
ADC_Value[1] = ADC12MEM5;
ADC_Value[2] = ADC12MEM6;
ADC_Value[3] = ADC12MEM7;
//LED_On(BIT2);
            __bic_SR_register_on_exit(LPM0_bits);      // Exit active CPU
            break;
        // Vector ADC12IV_ADC12IFG8:  ADC12IFG8
        case ADC12IV_ADC12IFG8:
            break;
        // Vector ADC12IV_ADC12IFG9:  ADC12IFG9
        case ADC12IV_ADC12IFG9:
            break;
        // Vector ADC12IV_ADC12IFG10:  ADC12IFG10
        case ADC12IV_ADC12IFG10:
            break;
        // Vector ADC12IV_ADC12IFG11:  ADC12IFG11
        case ADC12IV_ADC12IFG11:
            break;
        // Vector ADC12IV_ADC12IFG12:  ADC12IFG12
        case ADC12IV_ADC12IFG12:
            break;
        // Vector ADC12IV_ADC12IFG13:  ADC12IFG13
        case ADC12IV_ADC12IFG13:
            break;
        // Vector ADC12IV_ADC12IFG14:  ADC12IFG14
        case ADC12IV_ADC12IFG14:
            break;
        // Vector ADC12IV_ADC12IFG15:  ADC12IFG15
        case ADC12IV_ADC12IFG15:
            break;
        default:
            break;
