2967|2
4*4键盘程序 [复制链接]
4*4键盘程序
有0~9 确定以及删除 递增 递减键
这个怎么弄啊,紧急,谢谢各位了。
此帖出自单片机论坛
#include #include #include extern viod start_timer2(void); unsigned char scankey; bit timerout=0; bit keypress; #define kr0 p1_0 #define kr1 p1_1 #define kr2 p1_2 #define kr3 p1_3 #define kc0 p1_4 #define kc1 p1_5 #define kc2 p1_6 #define kc3 p1_7 #define kbd_port p1 #define kbd_val_vaild 0x80 #define fsm_wait_press 0x01 #define fsm_wait_relese 0x04 #define fsm_verfy1 0x02 #define fsm_verfy2 0x03 #define fsm_init 0x00 main() {     unsigned char fsm_key=0;     unsigned char kbd_col;     unsigned char kbd_row;     unsigned char key_val;     ie=0x40;     start_timer2();     ea=1;     while(1)     {          if(timerout)              {                  timerout=0;                  switch(fsm_key)                      {                           case fsm_init: kr0=1;kr1=1;kr2=1;kr3=1;fsm_key=fsm_wait_press;break;//行全部置1                           case fsm_wait_press:                                                 if(keypress)//如果有键按下keypress=1,否则为0                                                    {                                                         key_val=0;返回值清0                                                         if(kc0) {kc0=1;kbd_col=1;}                                                    else if(kc1) {kc1=1;kbd_col=2;}                                                    else if(kc2) {kc2=1;kbd_col=3;}                                                    else if(kc3) {kc3=1;kbd_col=4;}//行全部置1,检测列,如果该列读到1,证明该列有键被按下                                                          else   {fsm_key=fsm_init;}                                                    kbd_row=kbd_port;                                                    kbd_row>>=4;                                                    if(kbd_row)                                                       {                                                         if(kr0) {kbd_row=0;fsm_key=fsm_verfy1;}//有键按下的列置1,检测行,如果该行读到1,证明该行有键被按下                                                    else if(kr1) {kbd_row=4;fsm_key=fsm_verfy1;}                                                    else if(kr2) {kbd_row=8;fsm_key=fsm_verfy1;}                                                    else if(kr3) {kbd_row=12;fsm_key=fsm_verfy1;}                                                    else {fsm_key=fsm_init;}                                                     }  break;        case fsm_verfy1: switch(kbd_row)                                                 {                                                      case 0: if(kr0) fsm_key=fsm_verfy2;        else fsm_key=fsm_init; break;                                                      case 4: if(kr1) fsm_key=fsm_verfy2;        else fsm_key=fsm_init; break;                                                      case 8: if(kr0) fsm_key=fsm_verfy2;        else fsm_key=fsm_init; break;                                                     case 12: if(kr1) fsm_key=fsm_verfy2;        else fsm_key=fsm_init; break;                                                      default:        fsm_key=fsm_init; break;                                                  }   break;                           case fsm_verfy2: switch(kbd_row)                                                 {                                                      case 0: if(kr0) key_val=(kbd_row+kbd_col)|kbd_val_vaild; break;                                                      case 4: if(kr1) key_val=(kbd_row+kbd_col)|kbd_val_vaild; break;                                                      case 8: if(kr0) key_val=(kbd_row+kbd_col)|kbd_val_vaild; break;                                                     case 12: if(kr1) key_val=(kbd_row+kbd_col)|kbd_val_vaild; break;                                                     default: break;                                                  }  kr0=1;kr1=1;kr2=1;kr3=1;fsm_key=fsm_wait_relese; break;                                      case fsm_wait_relese:  if(!keypress){fsm_key=fsm_init;}break;                                        default:        fsm_key=fsm_init; break;                       }              }      } } void timer2() interrupt 5 {     TF2=0;     Timerout=1;     scankey=kbd_port;     if(scankey&0x0f){ keypress=1;}                 else{ keypress=0;} }  详情 回复 发表于 2010-3-16 17:29
2771
裸片初长成(中级)
那也是13个键啊,你用74C922,16个按键对应一个16进制键值,根据键值写代码即可
此帖出自单片机论坛
1673
#include
#include
#include <./atmel/at89s52.h>
bit timerout=0;
bit keypress;
#define kr0 p1_0
#define kr1 p1_1
#define kr2 p1_2
#define kr3 p1_3
#define kc0 p1_4
#define kc1 p1_5
#define kc2 p1_6
#define kc3 p1_7
#define kbd_port p1
main()
    ie=0x40;
    start_timer2();
    ea=1;
    while(1)
         if(timerout)
                 timerout=0;
                 switch(fsm_key)
                                                        key_val=0;返回值清0
                                                   kbd_row=kbd_port;
                                                   kbd_row>>=4;
                                                   if(kbd_row)
                                                 }   break;
                                                    default: break;
    TF2=0;
    Timerout=1;
    scankey=kbd_port;
                else{ keypress=0;}
此帖出自单片机论坛
个人签名要把目标订的实现起来辛苦一点!
