3136|0
58
Android编译环境(2) - 手工编译C模块 ZT [复制链接]
上一篇中(即《Android编译环境(1) - 编译Native Chelloworld模块》),我们试用了通过标准的Android.mk文件来编译C模块,下面我们来试试如何直接运用gcc命令行来编译,从而了解Android编译环境的细节。
Android编译环境提供了”showcommands”选项来显示编译命令行,我们可以通过打开这个选项来查看一些编译时的细节。当然,在这之前要把上一篇中的helloworld模块clean:
# make clean-helloworld
上面的“make clean-$(LOCAL_MODULE)”Android编译环境提供的make clean的方式。
接下来使用showcommands选项重新编译helloworld:
# make helloworld showcommands
build/core/product_config.mk:229: WARNING: adding test OTA key
target thumb C: helloworld <= development/hello/hello.c
prebuilt/linux-x86/toolchain/arm-eabi-4.2.1/bin/arm-eabi-gcc
-I system/core/include
-I hardware/libhardware/include
-I hardware/ril/include
-I dalvik/libnativehelper/include
-I frameworks/base/include
-I external/skia/include
-I out/target/product/generic/obj/include
-I bionic/libc/arch-arm/include
-I bionic/libc/include
-I bionic/libstdc++/include
-I bionic/libc/kernel/common
-I bionic/libc/kernel/arch-arm
-I bionic/libm/include
-I bionic/libm/include/arch/arm
-I bionic/libthread_db/include
-I development/hello
-I out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates
-c
-fno-exceptions -Wno-multichar -march=armv5te -mtune=xscale -msoft-float -fpic -mthumb-interwork -ffunction-sections -funwind-tables -fstack-protector -D__ARM_ARCH_5__ -D__ARM_ARCH_5T__ -D__ARM_ARCH_5E__ -D__ARM_ARCH_5TE__ -include system/core/include/arch/linux-arm/AndroidConfig.h -DANDROID -fmessage-length=0 -W -Wall -Wno-unused -DSK_RELEASE -DNDEBUG -O2 -g -Wstrict-aliasing=2 -finline-functions -fno-inline-functions-called-once -fgcse-after-reload -frerun-cse-after-loop -frename-registers -DNDEBUG -UDEBUG -mthumb -Os -fomit-frame-pointer -fno-strict-aliasing -finline-limit=64
-MD -o out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates/hello.o development/hello/hello.c
target Executable: helloworld (out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates/LINKED/helloworld)
prebuilt/linux-x86/toolchain/arm-eabi-4.2.1/bin/arm-eabi-g++ -nostdlib -Bdynamic -Wl,-T,build/core/armelf.x -Wl,-dynamic-linker,/system/bin/linker -Wl,--gc-sections -Wl,-z,nocopyreloc -o out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates/LINKED/helloworld -Lout/target/product/generic/obj/lib -Wl,-rpath-link=out/target/product/generic/obj/lib -lc -lstdc++ -lm
out/target/product/generic/obj/lib/crtbegin_dynamic.o
-Wl,--no-undefined prebuilt/linux-x86/toolchain/arm-eabi-4.2.1/bin/../lib/gcc/arm-eabi/4.2.1/interwork/libgcc.a out/target/product/generic/obj/lib/crtend_android.o
target Non-prelinked: helloworld (out/target/product/generic/symbols/system/bin/helloworld)
out/host/linux-x86/bin/acp -fpt out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates/LINKED/helloworld out/target/product/generic/symbols/system/bin/helloworld
target Strip: helloworld (out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates/helloworld)
out/host/linux-x86/bin/soslim --strip --shady --quiet out/target/product/generic/symbols/system/bin/helloworld --outfile out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates/helloworld
Install: out/target/product/generic/system/bin/helloworld
out/host/linux-x86/bin/acp -fpt out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates/helloworld out/target/product/generic/system/bin/helloworld
从上面的命令行可以看到,Android编译环境所用的交叉编译工具链是prebuilt/linux-x86/toolchain/arm-eabi-4.2.1/bin/arm-eabi-gcc-I-L参数指定了所用的C库头文件和动态库文件路径分别是bionic/libc/include out/target/product/generic/obj/lib,其他还包括很多编译选项以及-D所定义的预编译宏。
我们可以利用上面的编译命令,稍加简化来手工编译helloworld程序。先手工删除上次编译得到的helloworld程序:
# rm out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates/hello.o
# rm out/target/product/generic/system/bin/helloworld
再用gcc编译,生成目标文件:
# prebuilt/linux-x86/toolchain/arm-eabi-4.2.1/bin/arm-eabi-gcc -I bionic/libc/arch-arm/include -I bionic/libc/include -I bionic/libc/kernel/common
-I bionic/libc/kernel/arch-arm -c
Android.mk编译参数比较,上面主要减少了不必要的-I参数。
接下来生成可执行文件:
# prebuilt/linux-x86/toolchain/arm-eabi-4.2.1/bin/arm-eabi-gcc -nostdlib -Bdynamic -Wl,-T,build/core/armelf.x -Wl,-dynamic-linker,/system/bin/linker -Wl,--gc-sections -Wl,-z,nocopyreloc -o out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates/LINKED/helloworld -Lout/target/product/generic/obj/lib -Wl,-rpath-link=out/target/product/generic/obj/lib -lc -lm
out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates/hello.o out/target/product/generic/obj/lib/crtbegin_dynamic.o -Wl,--no-undefined ./prebuilt/linux-x86/toolchain/arm-eabi-4.2.1/bin/../lib/gcc/arm-eabi/4.2.1/interwork/libgcc.a out/target/product/generic/obj/lib/crtend_android.o
这里值得留意的是参数“-Wl,-dynamic-linker,/system/bin/linker”,它指定了Android专用的动态链接器/system/bin/linker,而不是通常所用的ld.so
生成的可执行程序可用filereadelf命令来查看一下:
# file out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates/LINKED/helloworld
out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates/LINKED/helloworld: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), not stripped
readelf -d out/target/product/generic/obj/EXECUTABLES/helloworld_intermediates/LINKED/helloworld |grep NEEDED
0x00000001 (NEEDED)
Shared library: [libc.so]
0x00000001 (NEEDED)
Shared library: [libm.so]
这是ARM格式的动态链接可执行文件,运行时需要libc.solibm.so。“not stripped”表示它还没被STRIP嵌入式系统中为节省空间通常将编译完成的可执行文件或动态库进行STRIP,即去掉其中多余的符号表信息。在前面“make helloworld showcommands”命令的最后我们也可以看到,Android编译环境中使用了out/host/linux-x86/bin/soslim工具进行STRIP
有关Android Toolchain的其他一些内容可参考:Android ToolchainBionic Libc
站长推荐上一条 2/8 下一条
快来报名!
