1329|0
3836
MSP430F5529 生成PWM波 with CCS [复制链接]
用FPGA可以得到更完美的波形,不过如果只是提供一个CLK波的话F5529LP就完全可以做到
#include  unsigned int temp; int main(void) {         WDTCTL = WDTPW | WDTHOLD;
//关闭看门狗         //Initialize    P1DIR |= BIT0;     P1OUT |= BIT0;
P1SEL |= BIT2;
//从P1.2输出        P1DIR |= BIT2;
//初始化定时器        TA0CTL |= TASSEL_2 + ID_0 ;
TA0CCTL1 = OUTMOD_7;
TA0CCR0 = /*Period*/;
//Change me        TA0CCR1 = /*Duty*/;
//Change me     __delay_cycles(2000);
__bis_SR_register(LPM4_bits + GIE);    return 0;}
