msp430g2553与1602引脚连接情况
* PIN1 --> 地
* PIN2 --> VCC(一定要接+5V)
* PIN3 -->仿真时悬空,实际电路 2K电阻-->地 (电阻可以是500-2k的,改变电阻可以改变字符显示的亮度,电阻接不好会导致什么都不显示)
* PIN4 --> RS --> P1.6
* PIN5 --> R/W --> GND
* PIN6 --> EN --> P1.7
* PIN7 --> D0不接
* PIN8 --> D1不接
* PIN9 --> D2不接
* PIN10 --> D3不接
* PIN11 --> D4 --> P2.4
* PIN12 --> D5 --> P2.5
* PIN13 --> D6 --> P2.6
* PIN14 --> D7 --> P2.7
* PIN15 --> VCC
* PIN16 --> 地
*msp430g2553与按键引脚连接情况
*k1-->p1.2
*k2-->p1.3
*k3-->p2.1
*k4-->p1.1
说明:本人用的时矩阵键盘,若用独立按键要接入电阻
代码如下:
#include
#include
#include
#define LCD_EN_PORT P1OUT //以下2个要设为同一个口
#define LCD_EN_DDR P1DIR
#define LCD_RS_PORT P1OUT //以下2个要设为同一个口
#define LCD_RS_DDR P1DIR
#define LCD_DATA_PORT P2OUT //以下3个要设为同一个口
#define LCD_DATA_DDR P2DIR //一定要用高4位
#define LCD_RS BIT6
#define LCD_EN BIT7
#define LCD_DATA BIT7|BIT6|BIT5|BIT4 //4位数据线连接模式
//函数声明
void LCD_init(void);
void LCD_init_first(void);
void LCD_en_write1(void); //上升沿使能
void LCD_en_write2(void); //下降沿使能
void LCD_write_command(unsigned char command);
void LCD_write_data(unsigned char data);
void LCD_set_xy (unsigned char x, unsigned char y);
void LCD_write_string(unsigned char X,unsigned char Y, unsigned char *s);
void LCD_write_char(unsigned char X,unsigned char Y, unsigned char data);
void display_HMS(unsigned char add,unsigned char date);
void delay_1ms(void);
void delay_nus(unsigned int n);
void delay_nms(unsigned int n);
void SetTime();
void SetMode();
void CalledByTimerA();
unsigned char LCDBuf1[]={"Hello world"};//第一行要显示的内容
unsigned char LCDBuf2[]={"10:30:00"}; //第二行要显示的内容
unsigned char shi1,fen1,miao1,aa,shi2,fen2,miao2;
unsigned char miao=0;
unsigned char fen=30;
unsigned char shi=10;
unsigned char aa=0;//计数器
int set_flag=0;//时间设置标志
int time_flag=0;//选择
void main()//主函数
WDTCTL = WDTPW + WDTHOLD; // 关闭看门狗
LCD_init_first();
LCD_init();
delay_nms(100);
BCSCTL3 |= LFXT1S_2; // Set LFXT1为vol时钟即12kHZ
CCTL0|= CCIE; //设置捕获/比较控制寄存器,CCIE=0x0010,使能捕获比较中断
CCR0 =182; //设置捕获/比较寄存器,初始值为12000,对于ACLK时钟频率为12khz的频率,相当于1s
TA0CTL = TASSEL_1 +TACLR+MC_1;
P1DIR|=BIT0;//P1.0为led,显示按键起作用
P1OUT|=BIT0+BIT3;//P1IN低电平跳转
P1REN|=BIT2+BIT3+BIT1;//上拉电阻,缺了好像不能用
P2REN|=BIT1;
LCD_write_string(0,0," Mode ");
delay_nms(10);
LCD_write_string(0,1,"k1(up) k2(down) ");
SetMode();
LCD_write_string(0,0," ");
delay_nms(10);
LCD_write_string(0,1," ");
delay_nms(10);
LCD_write_string(0,0,LCDBuf1);
delay_nms(10);
LCD_write_string(0,1,LCDBuf2);
_EINT(); //使能中断,这是一个C编译器支持的内部过程。
set_flag=0;
while(1)
P1OUT&=~BIT0;
SetTime();
P1OUT=BIT0+BIT3;
K1-进入设置现在的时间。
K2-设置小时。
K3-设置分钟。
K4-确认完成设置。
void SetTime()
if(!(P1IN&BIT2))
delay_nms(10);
// P1OUT&=~BIT0;
set_flag=1;
TA0CTL&=0xffcf;//停止模式
else if(!(P1IN&BIT3) && set_flag)
delay_nms(50);
shi=(shi+1)%24;
display_HMS(0x40,shi);
LCD_write_command(0x80+0x41);
// P1OUT&=~BIT0;
else if (!(P2IN&BIT1) && set_flag)
delay_nms(50);
// P1OUT&=~BIT0;
fen=(fen+1)%60;
display_HMS(0x43,fen);
LCD_write_command(0x80+0x44);
else if (!(P1IN&BIT1)&& set_flag)
delay_nms(10);
// P1OUT&=~BIT0;
set_flag=0;
else
// P1OUT=BIT0+BIT3;
K1-模式1,时间
K2-模式2,倒计时
K3-确定
void SetMode()
while(1)
if(!(P1IN&BIT2))
time_flag=1;
else if(!(P1IN&BIT3))
time_flag=2;
if(time_flag!=0 &&!(P2IN&BIT1))
break;
LCD_write_command(0x0c); //显示开,关光标,不闪烁
显示时分秒
unsigned char shi,ge;
shi=date/10;
ge=date%10;
LCD_write_command(add+0x80);
LCD_write_data(0x30+shi);
LCD_write_data(0x30+ge);
LCD1602液晶初始化函数
void LCD_init_first(void) //LCD1602液晶初始化函数(热启动)
delay_nms(500);
LCD_DATA_DDR|=LCD_DATA; //数据口方向为输出
LCD_EN_DDR|=LCD_EN; //设置EN方向为输出
LCD_RS_DDR|=LCD_RS; //设置RS方向为输出
delay_nms(50);
LCD_write_command(0x30);
delay_nms(50);
delay_nms(5);
delay_nms(500);
void LCD_init(void)
delay_nms(500);
delay_nms(500);
LCD_write_command(0x28); //4位数据接口
delay_nms(50);
delay_nms(50);
delay_nms(50);
LCD_en_write2();
delay_nms(50);
delay_nms(500);
LCD_write_command(0x01); //清屏
LCD_write_command(0x06); //设定输入方式,增量不移位
delay_nms(50);
液晶使能上升沿
LCD_EN_PORT&=~LCD_EN;
delay_nus(10);
LCD_EN_PORT|=LCD_EN;
液晶使能下降沿
delay_nus(10);
写指令函数
delay_nus(16);
P2SEL=0x00;
LCD_RS_PORT&=~LCD_RS; //RS=0
LCD_en_write1();
LCD_DATA_PORT&=0X0f; //清高四位
LCD_DATA_PORT|=command&0xf0; //写高四位
delay_nus(16);
LCD_en_write2();
command=command<<4; //低四位移到高四位
LCD_en_write1();
LCD_DATA_PORT&=0x0f; //清高四位
LCD_DATA_PORT|=command&0xf0; //写低四位
LCD_en_write2();
写数据函数
delay_nus(16);
P2SEL=0x00;
LCD_RS_PORT|=LCD_RS; //RS=1
LCD_en_write1(); //E上升沿
LCD_DATA_PORT|=data&0xf0; //写高四位
delay_nus(16);
LCD_en_write2();
data=data<<4; //低四位移到高四位
LCD_en_write1();
LCD_DATA_PORT|=data&0xf0; //写低四位
LCD_en_write2();
写地址函数
void LCD_set_xy( unsigned char x, unsigned char y )
unsigned char address;
if (y == 0) address = 0x80 + x;
else address = 0xc0 + x;
LCD_write_command( address);
LCD在任意位置写字符串,列x=0~15,行y=0,1
void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s)
LCD_set_xy( X, Y ); //写地址
while (*s) //写显示字符
LCD_write_data( *s );
s++;
LCD在任意位置写字符,列x=0~15,行y=0,1
void LCD_write_char(unsigned char X,unsigned char Y,unsigned char data)
LCD_write_data( data);
1us延时函数
void delay_1us(void)
asm("nop");
N us延时函数
unsigned int i;
for (i=0;i
delay_1us();
1ms延时函数
unsigned int i;
for (i=0;i<1140;i++);
N ms延时函数
unsigned int i=0;
for (i=0;i
delay_1ms();
中断响应函数 模式一
if(aa>=60)//一秒到了
aa=0;//清0
miao++;
if(miao>=60)//一分了
miao=0;
fen++;
if(fen>=60)
fen=0;
shi++;
LCD_write_command(0x80+0x45);//在分秒之间显示":"
LCD_write_data(':') ;
if(shi>=24)
shi=0;
display_HMS(0x43,shi);
LCD_write_command(0x80+0x42);//在时分之间显示":"
display_HMS(0x46,miao);
LCD_write_command(0x87);
LCD_write_command(0x84);
中断响应函数 模式二
void CalledByTimerAForCountDown()
if(aa>=60)
aa=0;
if(miao<=0)
if(fen<=0)
if(shi<=0)
else
shi--;
fen=59;
miao=59;
else
fen--;
miao=59;
else
miao--;
定时器中断
#pragma vector=TIMER0_A0_VECTOR
__interrupt void Timer_A(void)
aa++;
if(time_flag==1)
CalledByTimerA();
else if(time_flag==2)
CalledByTimerAForCountDown();
