678|0
152
瑞芯微VS-RK3288板卡 Linux 修改BOOTDELAY介绍 [复制链接]
uboot进入kernel中间的延时时间可以通过BOOTDELAY这个宏来控制。修改uboot/common/Kconfig文件
config BOOTDELAY
        int "delay in seconds before automatically booting"
        default 0
        depends on AUTOBOOT
        help
          Delay before automatically running bootcmd;
          set to 0 to autoboot with no delay, but you can stop it by key input.
          set to -1 to disable autoboot.
          set to -2 to autoboot with no delay and not check for abort
          See doc/README.autoboot for details.
default 0 表示不延时,1表示延时1s。
个人签名笑一笑,没有什么过不了
