3082|0
245
LA8演示版LCD显示驱动及字符代码 [复制链接]
下列是LCD显示屏驱动程序及字符代码,希望大家指导!
//下列代码是字符代码,由于LA8的空间太小,将字符代码放入到FLASH中,FLASH空间太小。剩余的
//放入程序中。
unsigned short ascchr1[] @0x80={
/*0*/ 0x4c95,
/*1*/ 0x0c00,
/*2*/ 0x4419,
/*3*/ 0x4c09,
/*4*/ 0x0c0c,
/*5*/ 0x480d,
/*6*/ 0x481d,
/*7*/ 0x0c01,
/*8*/ 0x4c1d,
/*9*/ 0x4c0d,
/*A*/ 0x0C1D,
/*B*/ 0x481C,
/*C*/ 0x4015,
/*D*/ 0x4C18,
/*E*/ 0x401D,
/*F*/ 0x001D,
/*G*/ 0x4C29,
/*H*/ 0x0C1C,
/*I*/ 0x6101,
/*J*/ 0x4C00,
/*K*/ 0x3300,
/*L*/ 0x4014,
/*M*/ 0x0E16,
/*N*/ 0x1C16,
/*O*/ 0x4C95,
/*P*/ 0x041D,
/*Q*/ 0x0C0D,
/*R*/ 0x141D,
/*S*/ 0x482D,
/*T*/ 0x2101,
/*U*/ 0x4C14,
/*V*/ 0x2404
unsigned short ascchr2[]={
/*W*/ 0x1C34,
/*X*/ 0x1222,
/*Y*/ 0x2202,
/*Z*/ 0x4221
/**********LCD显示屏清除或全部显示***********
ON_OFF:1清除LCD显示,1:全部显示LCD
void LCDclr(int ON_OFF){
     int i;
    unsigned char *p;
    p = (char *)0x20;
    if(ON_OFF==1){
     for(i = 0; i < 29; i++) {
      *p++ = 0x00;
    if(ON_OFF==0)
       for (i = 0; i < 29; i++){
         *p++ = 0x00;
/********初始化LCD********/
void LCDINI(void){
    unsigned int i;
    unsigned char *p;
    LCDC0_LCDEN = 0;
    LCDC0 = LCDC0_SOURCE_MASK | LCDC0_LCLK0_MASK | LCDC0_DUTY_MASK;
    LCDC1 = LCDC1_FCDEN_MASK;
    LCDSUPPLY = LCDSUPPLY_VSUPPLY0_MASK;
    LCDBCTL = 0;
    LCDPEN0 = 0xFF;
    LCDPEN1 = 0xFF;
    LCDPEN2 = 0xFF;
    LCDPEN3 = 0x1F;
    LCDBPEN0 = 0x80;
    LCDBPEN1 = 0x7F;
    LCDBPEN2 = 0x00;
    LCDBPEN3 = 0x00;
    p = (char *)0x20;
    for (i = 0; i < 29; i++) {
    *p++ = 0x00;
    LCDWF7  = 0x80;
    LCDWF8  = 0x40;
    LCDWF9  = 0x20;
    LCDWF10 = 0x10;
    LCDWF11 = 0x08;
    LCDWF12 = 0x04;
    LCDWF13 = 0x02;
    LCDWF14 = 0x01;
    LCDC0_LCDEN = 1;
   num:从左往右数第num段显示;
   data:显示代码
void LCD_Num(int num,unsigned short data){
  switch(num){
    case 1:
            LCDWF6  = data >> 8;
            LCDWF16 = (data & 0xFF)|0x80;
            break;
    case 2:
            LCDWF5  = data >> 8;
            LCDWF17 = data & 0xFF;
            break;
    case 3:
            LCDWF4  = data >> 8;
            LCDWF18 = data & 0xFF;
            break;
    case 4:
            LCDWF3  = data >> 8;
            LCDWF19 = data & 0xFF;
            break;
    case 5:
            LCDWF2  = data >> 8;
            LCDWF20 = data & 0xFF;
            break;
    case 6:
            LCDWF1  = data >> 8;
            LCDWF21 = data & 0xFF;
            break;
    case 7:
            LCDWF0  = data >> 8;
            LCDWF22 = data & 0xFF;
            break;
    case 8:
            LCDWF28  = data >> 8;
            LCDWF23 = data & 0xFF;
            break;
    case 9:
            LCDWF27  = data >> 8;
            LCDWF24 = data & 0xFF;
            break;
    default:break;
   LCD从高到低依次显示LCD字符
void dpchr(void){
  int i=0,j;
  while(i<36){
     for(j=1;j<10;j++){
        if(i<32) LCD_Num(j,ascchr1);
        else{
          LCD_Num(j,ascchr2[i-32]);
          if (i>36) j=10;
        if(i<10) putch( i+0x30);
        else putch(i+0x37);
        i++;
    putch(10);
    delay(500);
