4534|0
473
利用freescale s08单片机SPI模块读写at93c46 [复制链接]
原文见:http://blog.ednchina.com/bluehacker/228284/message.aspx这个例子是在我做的开发板NSS08Kit-R1上测试通过的,采用的是MC9S08AC16,但是应该可以应用于其他型号的S08单片机上。
@ Nicrosystem Freescale S08 DevKit(NSS08Kit-R1)
@ author:bluehacker<nicrosystem@gmail.com>
@ date:2009-04-08
@AT93C46的驱动
#include "at93c46.h"
#include "derivative.h"
#define AT93C46_CS   PTED_PTED4
void init_spi()
  SPI1C1=0x5c;//CPOL=1,CPHA=1
  SPI1C2=0x00;
  SPI1BR=0x11;//0.5MHZ clock rate
  PTEDD_PTEDD4=1;//output
  AT93C46_CS=1;
unsigned char do_spi(unsigned char dat)  {
    while(!SPI1S_SPTEF);
    SPI1D=dat;
    while(!SPI1S_SPRF);
    return SPI1D;
//等待write或erase操作完成
void wait_finish()
   while(PTED_PTED5==0){
      asm(NOP);
//读保存在at93c46存储器中地址为addr处的数据
unsigned char at93c46_read(unsigned char addr)
  unsigned char cmd[2];
  AT93C46_CS=0;
   cmd[0]=0x06;
  cmd[1]=addr<<1;
  AT93C46_CS=1;
   do_spi(cmd[0]);
  do_spi(cmd[1]);
   cmd[0]=do_spi(0); ;
  AT93C46_CS=0;
  return cmd[0];
//使能写/删除操作
void enable_write(void)
    AT93C46_CS=0;
    cmd[0]=0x02;
    cmd[1]=0x60;
    AT93C46_CS=1;
    do_spi(cmd[0]);
    do_spi(cmd[1]);
     AT93C46_CS=0;
//禁止写/删除操作
void disable_write(void)
    AT93C46_CS=0;
    cmd[0]=0x02;
    cmd[1]=0x00;
    AT93C46_CS=1;
    do_spi(cmd[0]);
    do_spi(cmd[1]);
    AT93C46_CS=0;
//擦除地址为addr的存储单元
void at93c46_erase(unsigned char addr)
  enable_write();
  AT93C46_CS=0;
  cmd[0]=0x03;
  cmd[1]=addr|0x80;
  AT93C46_CS=1;
  do_spi(cmd[0]);
  do_spi(cmd[1]);
  AT93C46_CS=0;
  asm(NOP);
  AT93C46_CS=1;
  wait_finish();
  AT93C46_CS=0;
  disable_write();
//往at93c46 addr地址写数据dat
void at93c46_write(unsigned char addr,unsigned char dat)
  enable_write();
  AT93C46_CS=0;
  cmd[0]=0x02;
  cmd[1]=addr|0x80;
  AT93C46_CS=1;
  do_spi(cmd[0]);
  do_spi(cmd[1]);
  do_spi(dat);
  AT93C46_CS=0;
  asm(NOP);
  AT93C46_CS=1;
  wait_finish();
  AT93C46_CS=0;
  disable_write();
//往at93c46所有存储单元写入dat
void at93c46_writeall(unsigned char dat)
  enable_write();
  AT93C46_CS=0;
  cmd[0]=0x02;
  cmd[1]=0x20;
  AT93C46_CS=1;
  do_spi(cmd[0]);
  do_spi(cmd[1]);
  do_spi(dat);
  AT93C46_CS=0;
  asm(NOP);
  AT93C46_CS=1;
  wait_finish();
  AT93C46_CS=0;
  disable_write();
//擦除at93c46
//erase ALL chip
void at93c46_eraseall(void)
  enable_write();
  AT93C46_CS=0;
  cmd[0]=0x02;
  cmd[1]=0x40;
  AT93C46_CS=1;
  do_spi(cmd[0]);
  do_spi(cmd[1]);
  AT93C46_CS=0;
  AT93C46_CS=1;
  wait_finish();
  AT93C46_CS=0;
  disable_write();
类别:freescale | 编辑 | 删除 | 评论(0) | 阅读(306)
此帖出自NXP MCU论坛
