8416|5
2130
团购STM8S-Discovery开发板(7美金绝对超值)带触摸键+仿真器 [复制链接]
建议大家团购STM8S-Discovery开发板(绝对超值)
Learn, evaluate and use the STM8 microcontroller with the STM8S-Discovery kit
The STM8S-Discovery kit is the quickest way to explore and demonstrate STM8S105C6T6 functionalities and create your own applications. All
software suites, from the in-circuit debugger to the C compiler with various software libraries are available free of charge. Once programmed,
the MCU module can be separated from the debugger circuit, and be connected inside the designed application. This extremely affordable the
tool can be obtained through ST's e-sampling program, as well as from distributors for a suggested retail price of $7. More
(原文件名:stm8s_discovery.jpg)
The STM8S-Discovery kit, is the cheapest and quickest way to discover the STM8S, to build and debug the application, and to program and use
the device.The STM8S-Discovery is a quick-start evaluation board based on the STM8S105C6T6. It includes the embedded debugger ST-LINK
and one touch-sensing button which help you to discover the STM8 features.Plug STM8S-Discovery into a PC through a standard USB cable, and
run the proposed example. Once the debugger is open, you will see the real-time execution of the code.Numerous applications are available in
order to learn, reuse and modify codes for a fast time to proof-of-concept or demonstration.It will satisfy hobbyists, developers, students and
support teams. Based on examples, you will find STM8S-Discovery indispensable.
大家看到了。只要6.65美金。但是邮费比较贵。因此建议一起团购。支持的说下啊。
如果不知道这个是啥东西。可以搜下“ST推出7美元带stlink的stm8 触摸开发版”
也就是说这个开发板集成仿真器。还可以当成仿真器使用啊。平时一个stlink仿真器就不是这个价
STM8S-DISCOVERY评估板用户指南 UM0817+User+Manual+STM8S-DISCOVERY.pdf (325.39 KB, 下载次数: 152)
功能简介:
■ STM8S105C6T6 microcontroller, 32 KB Flash, 2 KB RAM, 1 KB EEPROM
■ Powered by USB cable between PC and STM8S-DISCOVERY
■ Selectable power of 5 V or 3.3 V
■ Touch Sensing button, TS1
■ User LED, LD1
■ Extension header for all I/Os
■ Wrapping area for users own application
■ Embedded ST-LINK for STM8S
■ USB interface for programming and debugging
■ SWIM debug support
The STM8S-Discovery kit, is the cheapest and quickest way to discover the STM8S, to build and debug the application, and to program and use the device.
The STM8S-Discovery is a quick-start evaluation board based on the STM8S105C6T6. It includes the embedded debugger ST-LINK and one touch-sensing button which help you to discover the STM8 features.
Plug STM8S-Discovery into a PC through a standard USB cable, and run the proposed example. Once the debugger is open, you will see the real-time execution of the code.
Numerous applications are available in order to learn, reuse and modify codes for a fast time to proof-of-concept or demonstration.
It will satisfy hobbyists, developers, students and support teams. Based on examples, you will find STM8S-Discovery indispensable.
Download software tools
STMicroelectronics provides a free software package for STM8S-Discovery. The tool is supported by IDE from ST (STVD) and C compilers from Cosmic and Raisonance.
Set-up your environment in three steps:
        Install your C compiler:
                  download free Cosmic 16K C compiler
                  download free Raisonance 16K C compiler
        Install ST MCU Toolset composed of  ST Visual Develop (STVD) IDE and ST Visual Programmer (STVP) programming interface in a single. Free download.
        Install your application development package. Download document and software.
Features and benefits
STM8S105C microcontroller
                Uses the most common STM8S reference, with 32 Kbytes of Flash, E²Data and 48 pins
        Self powered by USB cable between PC and STM8S-Discovery                 Immediate plug-and-play demonstration
        Selectable power supply voltage: 5 V or 3.3 V for your application                 Adapts the demo to the future application environment
        Embedded STLink for the STM8S
- USB interface for programming and debugging                 Non-intrusive debug with the in-circuit debugger present on STM8S-Discovery
        SWIM debug support                 Detach the debugger to run the application
Single wire interface is always available for software upgrade
        Touch sensing interface                 Many demonstrations are available ready to use or constructed from
        Wrapping area for user’s own application                 Extend the Demo with our suggested hardware
Documentation & Downloads for STM8S-DISCOVERY
Please click here to access the Documentation & downloads page
[ 本帖最后由 leang521 于 2009-11-30 13:34 编辑 ]
此帖出自stm32/stm8论坛
学习学习学习  详情 回复 发表于 2009-12-6 21:11
管理员
回复 楼主 leang521 的帖子
大家什么想法?
邮费多少钱?
此帖出自stm32/stm8论坛
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
加油!在电子行业默默贡献自己的力量!:)
2130
刚在思蜕盟坛子上看到他们也组织团购。不过价格是99,闷黑啊。大家积极点呗
回SOSO,邮费多少我也不知。先看看有多少人愿意要吧。
[ 本帖最后由 leang521 于 2009-11-30 13:37 编辑 ]
此帖出自stm32/stm8论坛
我要
此帖出自stm32/stm8论坛
2130
呵呵。等了好久。还是只有一个人。鉴于此。我决定自己买了。团购活动取消
此帖出自stm32/stm8论坛
272
学习学习学习
此帖出自stm32/stm8论坛
