5077|1
290
149
ST推出7美元带stlink的stm8 触摸开发版! [复制链接]
Learn, evaluate and use the STM8 microcontroller with the STM8S-Discovery kit
The STM8S-Discovery kit is the quickest way to explore and demonstrate STM8S105C6T6 functionalities and create your own applications. All
software suites, from the in-circuit debugger to the C compiler with various software libraries are available free of charge. Once programmed,
the MCU module can be separated from the debugger circuit, and be connected inside the designed application. This extremely affordable the
tool can be obtained through ST's e-sampling program, as well as from distributors for a suggested retail price of $7.
The STM8S-Discovery kit, is the cheapest and quickest way to discover the STM8S, to build and debug the application, and to program and use
the device.The STM8S-Discovery is a quick-start evaluation board based on the STM8S105C6T6. It includes the embedded debugger ST-LINK
and one touch-sensing button which help you to discover the STM8 features.Plug STM8S-Discovery into a PC through a standard USB cable, and
run the proposed example. Once the debugger is open, you will see the real-time execution of the code.Numerous applications are available in
order to learn, reuse and modify codes for a fast time to proof-of-concept or demonstration.It will satisfy hobbyists, developers, students and
support teams. Based on examples, you will find STM8S-Discovery indispensable.
据说国内还没有?
此帖出自stm32/stm8论坛
看到最后,我疯了。  详情 回复 发表于 2009-11-24 11:09
1908
看标题我热血沸腾
看到最后,我疯了。
此帖出自stm32/stm8论坛
