4512|0
1782
至上芯片
IEC 2006年7月中旬颁布的新标准目录 [复制链接]
【来源:CESI】【作者:编译:童晓明】【时间: 2006-8-4 8:51:32】【点击: 28】
标准号
颁布时间
中文名称
分类编码
IEC 60749-26
18 July 2006
Semiconductor devices - Mechanical and climatic test methods - Part 26: Electrostatic discharge (ESD) sensitivity testing - Human body model (HBM)
半导体器件---机械和气候试验方法---第26部分:静电放电(ESD)敏感性试验---人体模拟(HBM)
31.080.01
IEC 60749-27
18 July 2006
Semiconductor devices - Mechanical and climatic test methods - Part 27: Electrostatic discharge (ESD) sensitivity testing - Machine model (MM)
半导体器件---机械和气候试验方法---第27部分:静电放电(ESD)敏感性试验---机械模拟(MM)
31.080.01
IEC 60749-35
18 July 2006
Semiconductor devices - Mechanical and climatic test methods - Part 35: Acoustic microscopy for plastic encapsulated electronic components
半导体器件---机械和气候试验方法---第35部分:塑封电子器件的超声显微检查方法
31.080.01
IEC 62373
18 July 2006
Bias-temperature stability test for metal-oxide, semiconductor, field-effect transistors (MOSFET)
金属氧化物、半导体、场效应晶体管(MOSFET)的偏温稳定性试验
31.080.
IEC 60099-4
17 July 2006
Surge arresters - Part 4: Metal-oxide surge arresters without gaps for a.c. systems
电涌制动器---第4部分:a.c.系无缝金属氧化物的电涌制动器
29.120.50
29.240.10
CISPR16-1-2-am2
17 July 2006
Specification for radio disturbance and immunity measuring apparatus and methods - Part 1-2: Radio disturbance and immunity measuring apparatus - Ancillary equipment - Conducted disturbances
无线电干扰和防干扰测试仪及方法的规范---第1-2部分:无线电干扰和防干扰测量仪---辅助设备---传导的干扰
33.100.10 33.100.20
CISPR16-1-2-am2
17 July 2006
Amendment 2 - Specification for radio disturbance and immunity measuring apparatus and methods - Part 1-2: Radio disturbance and immunity measuring apparatus - Ancillary equipment - Conducted disturbances
修改2---无线电干扰和防干扰测试仪及方法的规范---第1-2部分:无线电干扰和防干扰测量仪---辅助设备---传导的干扰
33.100.10
33.100.20
IEC 61755-2-1
17 July 2006
Fibre optic connector optical interfaces - Part 2-1: Optical interface standard single mode non-angled physically contacting fibres
光纤连接器界面—第2-1部分:光学界面标准单模非成角物理接触光纤
33.180.20
IEC 61352
17 July 2006
Mnemonics and symbols for integrated circuits
综合电路用记忆和符号
01.080.40
31.200.
IEC 61000-6-3
17 July 2006
Electromagnetic compatibility (EMC) - Part 6-3: Generic standards - Emission standard for residential, commercial and light-industrial environments
电磁兼容(EMC) ---第6-3部分:总标准---住宅、商用和灯光工业环境
33.100.10
IEC 61734
17 July 2006
Application of symbols for binary logic and analogue elements
二进位逻辑和类似原理的符号的应用
01.080.30
CISPR 16-2-3
17 July 2006
Specification for radio disturbance and immunity measuring apparatus and methods - Part 2-3: Methods of measurement of disturbances and immunity - Radiated disturbance measurements
无线电干扰和防干扰测试仪及方法规范---第2-3部分:干扰和防干扰测量方法---辐射干扰测量
33.100.10
33.100.20
IEC 60191-2-am15
17 July 2006
Amendment 15 - Mechanical standardization of semiconductor devices - Part 2: Dimensions
修改15---半导体器件的机械标准化---第2部分:尺寸
31.080.01
IEC 60191-2-am14
17 July 2006
Amendment 14 - Mechanical standardization of semiconductor devices - Part 2: Dimensions
修改14---半导体器件的机械标准化---第2部分:尺寸
31.080.01
IEC 60191-2-am13
17 July 2006
Amendment 13 - Mechanical standardization of semiconductor devices - Part 2: Dimensions
修改13---半导体器件的机械标准化---第2部分:尺寸
31.080.01
CISPR 16-SER
17 July 2006
Specification for radio disturbance and immunity measuring apparatus and methods - ALL PARTS
无线电干扰和防干扰测量仪和方法规范---所有部分
33.100.10 33.100.20
IEC 61755-3-2
12 July 2006
Fibre optic connector optical interfaces - Part 3-2: Optical interface, 2,5 mm and 1,25 mm diameter cylindrical full zirconia ferrules for 8 degrees angled-PC single mode fibres
光纤连接器光学接口---第3-2部分:8度角-PC单模光纤的光学接口,2,5 mm 和 1,25 mm直径圆柱形全氧化锆环
33.180.20
IEC 61755-3-1
12 July 2006
Fibre optic connector optical interfaces - Part 3-1: Optical interface, 2,5 mm and 1,25 mm diameter cylindrical full zirconia PC ferrule, single mode fibre
光纤连接器光学接口---第3-1部分:光学接口,2,5 mm 和 1,25 mm直径圆柱形全氧化锆PC环,单模光纤
33.180.20
ISO/IEC 9594-10
11 July 2006
Information technology - Open Systems Interconnection - The Directory: Use of systems management for administration of the Directory
信息技术---开放系统互连---地址录:地址录管理用的系统管理的使用
35.100.70
IEC 61282-9
11 July 2006
Fibre optic communication system design guides - Part 9: Guidance on polarization mode dispersion measurements and theory
光纤通讯系统设计指南---第9部分:偏振模式离差测量和理论指南
33.180.01
IEC 61391-1
11 July 2006
Ultrasonics - Pulse-echo scanners - Part 1: Techniques for calibrating spatial measurement systems and measurement of system point-spread function response
超音波学---脉冲反射扫描仪---第1部分:系统点传播功能响应的校准空间测量系统和测量技术
17.140.50
此帖出自模拟电子论坛
