3117|9
1673
求高手指点程序错误 [复制链接]
//晶振12MHZ
功能:
1.外中断INT1,M1启动,延时3秒后,M2也启动
2.定时器T0,每50ms发送一次脉冲//
#include
#define uchar unsigned char
#define uint unsigned int
unsigned char data SendBuffer[]={};
sbit P0_0 = P0^0;
sbit P0_1 = P0^1;
sbit P0_2 = P0^2;
sbit P0_3 = P0^3;
sbit ST = P0^4;
sbit P0_5 = P0^5;
sbit P0_6 = P0^6;
sbit P0_7 = P0^7;
sbit P1_0 = P1^0;
sbit P1_1 = P1^1;
sbit P1_2 = P1^2;
sbit P1_3 = P1^3;
sbit P1_4 = P1^4;
sbit P1_5 = P1^5;
sbit P1_6 = P1^6;
sbit P1_7 = P1^7;
sbit P2_0 = P2^0;
sbit P2_1 = P2^1;
sbit P2_2 = P2^2;
sbit P2_3 = P2^3;
sbit CS = P2^4;
sbit SK = P2^5;
sbit DI = P2^6;
sbit DO = P2^7;
sbit P3_0 = P3^0;
sbit P3_1 = P3^1;
sbit P3_2 = P3^2;
sbit P3_3 = P3^3;
sbit P3_4 = P3^4;
sbit P3_5 = P3^5;
sbit P3_6 = P3^6;
sbit P3_7 = P3^7;
uint count=0;
void delay(uint delaytime)
uint j=0;
for(;delaytime>0;delaytime--)
  {for(j=0;j<125;j++)
void service_int1()interrupt 2 using 2
  if(P3_3==0)
  delay(50);
  if(P3_3==0)
{P1_2=1;P1_0=1;delay(30000);P1_6=1;}
void time0() interrupt 1
  TH0=(65536-50000)/256;
  TL0=(65536-50000)%256;
  ST=0;
  ST=1;
void main()
  uint i;
  TMOD=0X11;
  TH0=(65535-50000)/256;
  TL0=(65535-50000)%256;
  ET0=1;
  TR0=1;
  EA=1;
  IP=0X04;
  IE=0X84;
  for(;;)
  i=0;
  for(i=0;i<4;i++)
   P1=0X7F;
   P0_1=i%2;
   P0_0=(i/2)%2;
   if(P2_1==0)
   delay(50);
   if(P2_1==0)
   if(P0_0==0&P0_1==0){P1_4=1;P1_1=1;}
   else if(P0_0==0&P0_1==1){P1_5=1;P1_4=1;P1_1=1;P1_3=1;}
   else if(P0_1==0&P0_1==0){P1_5=1;P1_4=1;P1_1=1;P1_3=1;P1_6=1;}
   else if(P0_1==0&P0_1==1){P1_5=1;P1_3=1;}
   break;
   if(P2_2==0)
   delay(50);
   if(P2_2==0)
   if(P0_0==0&P0_1==0){P1_0=1;}
   else if(P0_0==0&P0_1==1){P1_0=1;P1_2=1;}
   else if(P0_1==0&P0_1==0){P1_6=1;P1_0=1;P1_2=1;}
   else if(P0_1==0&P0_1==1){P1_2=1;}
   break;
   if(P2_3==0)
   delay(50);
   if(P2_3==0)
   if(P0_0==0&P0_1==1){P1_6=1;P1_4=1;P1_1=1;P1_2=1;}
   else if(P0_0==1&P0_1==0){P1_1=1;P1_4=1;delay(30000);P1_5=1;P1_3=1;}
   break;
   if(P2_0==0)
   delay(50);
   if(P2_0==0)
   if(P0_0==0&P0_1==1){P1_6=1;P1_5=1;P1_0=1;P1_3=1;}
   else if(P0_0==1&P0_1==0){P1_2=1;delay(30000);P1_0=1;}
   break;
此帖出自单片机论坛
建议用PROTUS仿真或软件仿真下,  详情 回复 发表于 2009-9-15 10:57
255
这样估计大家都很难看懂
若提问的角度合适的话 大家都能帮你解决
此帖出自单片机论坛
个人签名每天进步一点点
440
弄个附件上来,这样谁能看懂啊
此帖出自单片机论坛
1673
回复 沙发 hanker510 的帖子
版主指点下,我就是想问问这个程序能不能实现这2个功能:1.有外中断INT1响应时,M1启动,延时3秒后,M2也启动
[ 本帖最后由 simonprince 于 2009-9-14 12:42 编辑 ]
此帖出自单片机论坛
846
楼主,你声明sbit P0_0 = P0^0;这么多干什么,一个#include都有了。发个电路,程序稍微注释些,其他人很容易看你的程序了。
此帖出自单片机论坛
356
谢谢楼主,支持支持,学习学习
此帖出自单片机论坛
196
閺屻儳婀呴張顒€绗橀崗銊╁劥鐠併劏顔戦敍宀冾嚞閻ц缍�閹存牞鈧拷濞夈劌鍞�
此帖出自单片机论坛
1673
此帖出自单片机论坛
2770
裸片初长成(中级)
这个问题不难
此帖出自单片机论坛
1673
回复 7楼 ptwang 的帖子
此帖出自单片机论坛
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
