另外,在如下代码中,我用分号屏蔽的那些全局变量是什么作用,我不屏蔽的话,要报错。这个段拷贝汇编代码是代码搬移必须用到的
; FILE: DSP28xxx_SectionCopy_nonBIOS.asm
; DESCRIPTION: Provides functionality for copying intialized sections from
; flash to ram at runtime before entering the _c_int00 startup
; routine
; Author: Tim Love
; Release Date: March 2008
.ref _c_int00
.global copy_sections
;.global _cinit_loadstart, _cinit_runstart, _cinit_size
;.global _const_loadstart, _const_runstart, _const_size
;.global _econst_loadstart, _econst_runstart, _econst_size
;.global _pinit_loadstart, _pinit_runstart, _pinit_size
;.global _switch_loadstart, _switch_runstart, _switch_size
.global _text_loadstart, _text_runstart, _text_size
* Function: copy_sections
* Description: Copies initialized sections from flash to ram
.sect "copysections"
copy_sections:
;MOVL XAR5,#_cinit_size ; Store Section Size in XAR5
;MOVL ACC,@XAR5 ; Move Section Size to ACC
;MOVL XAR6,#_cinit_loadstart ; Store Load Starting Address in XAR6
;MOVL XAR7,#_cinit_runstart ; Store Run Address in XAR7
;LCR copy ; Branch to Copy
;MOVL XAR5,#_const_size ; Store Section Size in XAR5
;MOVL XAR6,#_const_loadstart ; Store Load Starting Address in XAR6
;MOVL XAR7,#_const_runstart ; Store Run Address in XAR7
;MOVL XAR5,#_econst_size ; Store Section Size in XAR5
;MOVL XAR6,#_econst_loadstart ; Store Load Starting Address in XAR6
;MOVL XAR7,#_econst_runstart ; Store Run Address in XAR7
;MOVL XAR5,#_pinit_size ; Store Section Size in XAR5
;MOVL XAR6,#_pinit_loadstart ; Store Load Starting Address in XAR6
;MOVL XAR7,#_pinit_runstart ; Store Run Address in XAR7
;MOVL XAR5,#_switch_size ; Store Section Size in XAR5
;MOVL XAR6,#_switch_loadstart ; Store Load Starting Address in XAR6
;MOVL XAR7,#_switch_runstart ; Store Run Address in XAR7
MOVL XAR5,#_text_size ; Store Section Size in XAR5
MOVL XAR6,#_text_loadstart ; Store Load Starting Address in XAR6
MOVL XAR7,#_text_runstart ; Store Run Address in XAR7
LB _c_int00 ; Branch to start of boot.asm in RTS library
copy:
B return,EQ ; Return if ACC is Zero (No section to copy)
SUBB ACC,#1
RPT AL ; Copy Section From Load Address to
|| PWRITE *XAR7, *XAR6++ ; Run Address
