4430|1
105
LT7911D:Type-C to 2 port MIPI CSI/DSI, support 3D with Audio and PD Controller [复制链接]
1. Description
The LT7911D is a high performance DP1.2 to MIPI®DSI/CSI chip for VR/Smart phone/Display application.
For DP1.2 input, LT7911D can be configured as 1,2,4 lane, also support lane swap function. Adaptive equalization makes it suitable for long cable application and the maximum bandwidth is up to 21.6Gbps.
For MIPI®DSI/CSI output, LT7911D features configurable single-port or dual-port or MIPI®DSI/CSI with 1 high-speed clock lane and 1~4 high-speed data lanes operating at maximum 1.5Gb/s/lane, which can support a total bandwidth of up to 12Gbps. LT7911D supports burst mode DSI video data transferring, also support flexible video data mapping path.
With sophisticated MCU and the Embedded  Flash, LT7911D support EDID buffer, DP/eDP input  detection and determine to enter into power saving mode automatically. When the receiver of LT7911D locks the input signal, MCU can read the recovered timing parameters by MSA registers to match the ASSR. The DPCD registers are accessible via system I2C when debugging the full link training. Once the fast link training used, system time will save at least 400ms.
2. Features
• Type-C
• DP/eDP Receiver
• Single/Dual-Port MIPI® DSI/CSI Transmitter
• Miscellaneous
3. Applications
• Mobile system
• VR
需要芯片资料及技术支持联系陈S-13724376200 Q-3001603283
105
欢迎大家一起来学习探讨,提供技术支持
