1491|0
3836
MSP430F5529 生成PWM波 with CCS [复制链接]
大概就是通过时钟来产生某个确定频率的PWM波
用FPGA可以得到更完美的波形,不过如果只是提供一个CLK波的话F5529LP就完全可以做到
#include
unsigned int temp;
int main(void) {
        WDTCTL = WDTPW | WDTHOLD;                                          //关闭看门狗
        //Initialize
    P1DIR |= BIT0;
    P1OUT |= BIT0;
        P1SEL |= BIT2;        //从P1.2输出
        P1DIR |= BIT2;
        //初始化定时器
        TA0CTL |= TASSEL_2 + ID_0 ;
        TA0CCTL1 = OUTMOD_7;
        TA0CCR0 = /*Period*/; //Change me
        TA0CCR1 = /*Duty*/;   //Change me
    __delay_cycles(2000);
    __bis_SR_register(LPM4_bits + GIE);
    return 0;
