5105|3
关于sppc中的warning [复制链接]
Warning (12020): Port "address_b" on the entity instantiation of "cpu_traceram_lpm_dram_bdp_component" is connected to a signal of width 17. The formal width of the signal in the module is 7.  Extra bits will be ignored.
Warning (12020): Port "jdo" on the entity instantiation of "the_cpu_nios2_oci_itrace" is connected to a signal of width 38. The formal width of the signal in the module is 16.  Extra bits will be ignored.
Warning (12020): Port "dbrk" on the entity instantiation of "cpu_nios2_oci_dbrk_hit3_match_single" is connected to a signal of width 78. The formal width of the signal in the module is 71.  Extra bits will be ignored.
Warning (12020): Port "dbrk" on the entity instantiation of "cpu_nios2_oci_dbrk_hit2_match_single" is connected to a signal of width 78. The formal width of the signal in the module is 71.  Extra bits will be ignored.
Warning (12020): Port "dbrka" on the entity instantiation of "cpu_nios2_oci_dbrk_hit2_match_paired" is connected to a signal of width 78. The formal width of the signal in the module is 71.  Extra bits will be ignored.
此帖出自FPGA/CPLD论坛
SOSO真是负责啊,感觉每个贴都看过,辛苦啦,soso真是好人啦  详情 回复 发表于 2009-7-20 22:16
那位大侠帮忙解释一下这些warning是怎么回事?怎么解决
此帖出自FPGA/CPLD论坛
129
位宽不匹配?
检查下位宽。
此帖出自FPGA/CPLD论坛
244
此帖出自FPGA/CPLD论坛
