3358|0
热招进行中- LSI 上海研发中心 [复制链接]
Please submit your Resume to China.Recruiting@lsi.com
1)  Analog Design Engineer
DESCRIPTION OF DUTIES IN ADDITION TO THOSE IN JOB DESCRIPTION:
-Design high speed analog and mixed-signal integrated circuits within custom chips for the hard disk drive industry
-Work directly with customers to determine system requirements, write specifications and guide customers in the use of pre-amplifier products
-Use high speed electronic characterization equipment to evaluate and debug the functionality of the design once the part is fabricated in silicon
-Provide technical leadership through all phases of product development including test, yield, characterization, reliability analysis, qualification and release to manufacturing
PREFERRED EXPERIENCE:
LSI's Storage Peripherals Group is looking for an experienced custom analog IC designer to join the pre-amplifier design team. At LSI we are committed to innovation and industry leadership. We develop advanced high-speed magneto electronic read/write IC architectures as the basis for our products.
Design team members define, create and modify high-speed custom integrated circuits for hard disk drive (HDD) products using leading edge CMOS and SiGe BiCMOS technologies. Team members support the entire product life cycle beginning with design and moving through test, qualification, release to production and ramp to volume.
-Degree in Electrical Engineering (or related field), MS required, Ph.D. preferred
-Minimum three to five years experience in discrete, transistor level analog circuit design
-Experience with analog and mixed signal IC product design, integration and verification is required
-Strong physical layout knowledge and parasitic component understanding essential
-Process and device physics knowledge critical
-Proven skills using electronic measurement equipment in a lab environment
-Expertise in applied magnetism and recording a strong plus
2) Senior Design Verification Engineer
-Will include working within a Product Development Team to develop reusable block-level and ASIC test benches using HVL.
-Develop new ASIC verification environments to support ASIC development.
-Maintain existing ASIC verification environments.
-Review RTL architectural and implementation specifications.
-Create stimulus drivers, monitors, dataflow models, and test plans to verify function and performance of advanced multiprotocol networking ASICs.
-Define and develop application tests required to verify ASICs meet functional and performance goals.
-Define and implement functional coverage plans.
-Define and implement code coverage plans.
-Develop testing and regression methodologies for new verification flow.
-Coordinate test plan implementation and regressions with remote team.
-Incorporate reusability into all aspects of the verification environment.
-Develop/maintain/enhance environment tools/scripts/makefiles.
-Minimum of 4-6 years ASIC Verification experience in a product development environment
-Proven ASIC Design Verification skills
-Fluent in Verilog for design verification
-Experience with Specman or System Verilog
-Knowledge of data and telecommunication networking(TDM/IP/ATM/Ethernet)
-Experience with one or more scripting languages: awk, Perl, python
-Superior debugging skills for large ASIC designs
-Strong written and verbal communication skills
-Adaptable to evolving customer requirement
-Desired: Past experience in a lead position giving guidance to other engineers; Experience with C/C++
Education/Certifications
Required Degree: BS
Preferred Degree: MS
Preferred Major: Electrical Engineering or related discipline
[ 本帖最后由 ChinaRecruiting 于 2009-4-13 17:20 编辑 ]
此帖出自求职招聘论坛
