6370|5
UCOS+ads [复制链接]
 我在移植ucos时遇到一些汇编方面的问题解决不了,我用的是S3C2410A开发板,开发环境是ADS1.2,移植步骤主要是在ucos官网上下了UCOSV2.8源码,同时下载了arm_ucos-110移植范例(针对S3C2410X),但是在编译的时候遇到了一些问题。Warning : C2873W: implicit return in non-void function
consol.c line 147
consol.c line 193
C:\Micrium\SOFTWARE\uCOS-II\ucosfors3c2410\src\src\consol.c: 2 warnings, 0 errors, 0 serious errors
Warning : C2206W: Undefined macro 'SDT' in #if - treated as 0
frmwrk.c line 148
Warning : C2207W: inventing 'extern int MMU_SetAsyncBusMode();'
frmwrk.c line 337
Warning : C2207W: inventing 'extern int MMU_SetFastBusMode();'
frmwrk.c line 339
Warning : C2207W: inventing 'extern int MMU_Init();'
frmwrk.c line 479
C:\Micrium\SOFTWARE\uCOS-II\ucosfors3c2410\src\src\frmwrk.c: 4 warnings, 0 errors, 0 serious errors
Warning : A1313W: Missing END directive at end of file
S3c2410x.a line 2
    included by GET/INCLUDE directive from "C:\Micrium\SOFTWARE\uCOS-II\ucosfors3c2410\src\src\init.s", line 96
    2 00000000
memcfg.a line 2
    included by GET/INCLUDE directive from "C:\Micrium\SOFTWARE\uCOS-II\ucosfors3c2410\src\src\init.s", line 97
    2 00000000
Error   : A1150E: Bad symbol
init.s line 224
  224 00000054     ldr r0,=REFRESH
init.s line 234
  234 00000070     ldr r0,=CLKCON                  ; enter STOP mode.
init.s line 243
  243 00000080     ldr r0,=REFRESH                 ; exit from SDRAM self refresh mode.
init.s line 252
  252 00000088     ldr r0,=REFRESH
init.s line 261
  261 000000a0     ldr     r1,=MISCCR
init.s line 266
  266 000000ac     ldr r0,=CLKCON
init.s line 275
  275 000000b4     ldr     r1,=MISCCR
init.s line 282
  282 000000c4     ldr    r1,=BWSCON               ; BWSCON Address
init.s line 294
  294 000000e4     ldr r1,=GSTATUS3                ; GSTATUS3 has the start address just after POWER_OFF wake-up
init.s line 313
  313 000001a4         ldr    r0,=WTCON            ; watch dog disable
init.s line 317
  317 000001ac         ldr    r0,=INTMSK
init.s line 321
  321 000001b4         ldr    r0,=INTSUBMSK
init.s line 326
  326 000001bc         ldr    r0,=LOCKTIME
init.s line 332
  332 000001c4             ldr    r0,=MPLLCON
init.s line 338
  338 000001cc         ldr    r1,=GSTATUS2
init.s line 349
  349 000001dc         ldr    r1,=BWSCON           ; BWSCON Address
init.s line 443
  443 000002e0         DCD (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28))
init.s line 444
  444 000002e4         DCD ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC))   ;GCS0
init.s line 445
  445 000002e8         DCD ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC))   ;GCS1
init.s line 446
  446 000002ec         DCD ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC))   ;GCS2
init.s line 447
  447 000002f0         DCD ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC))   ;GCS3
init.s line 448
  448 000002f4         DCD ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC))   ;GCS4
init.s line 449
  449 000002f8         DCD ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC))   ;GCS5
init.s line 450
  450 000002fc         DCD ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN))    ;GCS6
init.s line 451
  451 00000300         DCD ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN))    ;GCS7
init.s line 452
  452 00000304         DCD ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT)
26 Errors, 2 Warnings
Warning : C2207W: inventing 'extern int OSStartHighRdy();'
os_core.c line 788
C:\Micrium\SOFTWARE\uCOS-II\ucosfors3c2410\src\uCOS-II\os_core.c: 1 warning, 0 errors, 0 serious errors
请高手指教
Missing END directive at end of file 这不是说的非常明白了,文件尾缺少END指令  详情 回复 发表于 2009-10-18 19:52
2131
至上芯片
Re: [求助] UCOS+ads
这都是警告啊!
看看这个OSStartHighRdy();' 函数
赞赏
查看全部赞赏
个人签名处处留心皆学问!
主要是这些错误解决不了,那些警告我都解决了
init.s line 224
init.s line 234
init.s line 243
init.s line 252
init.s line 261
init.s line 266
init.s line 275
init.s line 282
init.s line 294
init.s line 313
init.s line 317
init.s line 321
init.s line 326
init.s line 332
init.s line 338
init.s line 349
init.s line 443
init.s line 444
init.s line 445
init.s line 446
init.s line 447
init.s line 448
init.s line 449
init.s line 450
init.s line 451
init.s line 452
os_core.c line 788
2131
至上芯片
Re: [求助] UCOS+ads
init.s中用到了REFRESH  CLKCON 等等你都有声明吗?
2410的例子有好多的!当你解决了问题也学到了东西
赞赏
查看全部赞赏
个人签名处处留心皆学问!
Re: [求助] UCOS+ads
请问上面这个警告是什么引起的?我现在移植也遇到了。
26
