4867|0
64
轨对轨 兼容替换AD,TI,圣邦威全系列 [复制链接]
高精密  低功耗 运算放大器,轨对轨,兼容替换AD,TI ,圣邦威,等国内外大品牌运放
替换TI芯片 完美替换TPS61088  30瓦大功率同步升压芯片
同脚位完美替换 TPS54540 36V 5A大电流同步降压芯片
直接替换 TI原型号TPS54531 36V 5A大电流同步降压芯片
TPS54340 TPS54331 40V 3.5A同步降压芯片 完美替换
完美替换 TPS54331 脚位全兼容TPS54340 40V 3.5A高效同步降压芯片
脚位全兼容完美替换 TI全系列完美替换
完美替换TI TPS54231 TPS5403 TPS5405 TPS5402 脚位全兼容
脚位全兼容完美替换 圣邦威全系列完美替换
完美替换兼容圣邦威产品:
SGM722 SGM721 SGM522  SGM521 SGM524 SGM324 SGM358 SGM622 SGM624 SGM321 SGM8551  SGM8552等等
完美替换兼容TI产品:
IGBT:FAN3100 UCC27517A  IR4427 UCC27524A
DCDC芯片:TPS61088 TPS54540 TPS54531 LM14030  TPS54231 TPS5403 TPS5405 TPS5402
替换8592运放 8592替代运放
高精度运放直接替换S邦微8592
高精度轨对轨运放8592  高精度运算放大器
替代兼容产品:
圣邦微电子: SGM8551,SGM8552,SGM8554,SGM8581,SGM8582,SGM8584
ADI:         AD8551,AD8552,AD8554
3PEAK(思瑞浦):TP5551,TP5552,TP5554,TP5591,TP5592,TP5594
替代兼容产品:
TI:           OPA2335,OPA335,OPA334,OPA2334
Linear Technology:   LTC2051,LTC20252,LTC2050
替代兼容产品:
ADI:      AD8538,AD8539
MAXIM:     MAX9617,MAX9618,MAX9619,MAX9620,MAX4236A
Linear Technology:  LTC2054,LTC20255
替代兼容产品:
3PEAK(思瑞浦):    TP5531,TP5532,TP5534
TI:             OPA330,OPA2330,OPA4330
ST:              OP1ZHA,OP2ZHA,OP4ZHA,TSZ121,TSZ122,TSZ124
替代兼容产品:
圣邦微电子:SGM8521 SGM8522 SGM8524
Microchip: MCP6041  MCP6042  MCP6044  MCP6043
思瑞浦:   TP1511,TP1511U,TP1221(5V 应用)TP1512,TP1222(5V 应用)TP1514,TP1224(5V 应用)TP1511N
替代兼容产品:
圣邦微电子:SGM8531 SGM8532 SGM8534
Microchip:MCP6241R MCP6241 MCP6241U MCP6242  MCP6244
安森美:  NCS20091  NCS20092  NCS20094
替代兼容产品:
德州仪器:LMV321 OPA348 LMV358 OPA2348 LMV324 OPA4348
ADI:    AD8541  AD8542  AD8544
意法半导体: LMV321  LMV358  LMV324
思瑞浦:TP321 LMV321A TP1541 LMV321TP TP1541A TP358 LMV358A TP1542 LMV358TP TP1542A TP324 LMV324A TP1544 LMV324TP TP1544A TP1543
圣邦微电子: SGM321 SGM8541 SGM358 SGM8542 SGM324 SGM8544 SGM8543
Microchip: MCP6001 MCP6001R MCP6001U MCP6401 MCP6401R MCP6401U MCP6002 MCP6402 MCP6004 MCP6404
罗姆:LMR321  LMR358  LMR324
替代兼容产品:
德州仪器:TLV314 TLV341 TLV341A TLV2314 TLV342 TLV342A TLV4314  TLV342S
圣邦微电子:SGM8621  SGM8622  SGM8624  SGM8623
Microchip:MCP601 MCP601R MCP6L1R MCP602 MCP6L2 MCP604 MCP6L4 MCP603 MCP603R
思瑞浦: TP1561 TP2431 TP1562 TP2432 TP1564 TP2434 TP1561N
Intesil:ISL28113  ISL28213  ISL28413
RENESAS:HA1630Q4
替代兼容产品:
德州仪器:OPA374 LMV821-N TLV2361 LMV710 OPA2374 LMV822-N TLV2362 LMV712 OPA4374 LMV824-N
圣邦微电子:SGM8631  SGM8632  SGM8634  SGM8633
Microchip:MCP6491  MCP6492  MCP6494
思瑞浦:TP2421  TP2422  TP2424
安森美:NCS2003 NCS2003A NCS20032  NCS20034
意法半导体:TSV91x TSV91xA TSV91x TSV91xA TSV91x TSV91xA
替代兼容产品:
德州仪器:LMV721 TLV316 LMV722 TLV2316 TLV4316
圣邦微电子:SGM721  SGM722  SGM724  SGM723
ADI:  AD8691  AD8692  AD8694
Microchip: MCP6291 MCP6291R MCP6492  MCP6494  MCP6493 MCP6495
思瑞浦: TP2411  TP2412  TP2414
RENESAS: HA1630Q6
中广芯源专业电源方案,运算放大器,马达驱动,大功率MOS 等系统服务商,小家电电源方案,工业辅助电源方案,智能LED调光电源驱动IC,功率:30W以内,有针对性的方案提供产品特色降低系统成本,提高设计灵活性。
12V降压5V  2A SOT23-6小封装同步降压IC  12V降压5V 3A小封装大大电流DC-DC升压
升压解决方案:
5-35V输入升压8-100V各种升压解决方案 大功率300W
40-80V输入升压45-300V升压解决方案
3.7V升12V   UPS 11.5V升压24V   1.5A      12V升24V  3-5A
3V升5V 200ma无电感无肖特基升压芯片
3.7V升5V 1A  3.7V升5V 2.3A 同步升压 开关频率500KHZ
2.5-5.5V升5-100V 外置mos  3V升5V最大3A
2-24V升压6-40V   12W以内应用   开关频率400KHZ
降压解决方案:
8-80V降压5V 1A 12V 500MA 高压降压
15-100V降压12V 2A 5V 1A 大功率高压降压降压方案
26-100V降压5V 1.5A 12V  800ma
7-100V降压5V 1.2A 12V 800ma 纯进口
40-400V交流转直流降压5V 9V 12V 100MA
AC220V转5V 2A 12V 1.5A大功率降压方案
4.5-80V转5V 1.2a  12V 500ma
4.5-55V恒压转5V 1-2A
4.75-30V恒压恒流转3.3V 2.5A  5V 2A  开关频率450KHZ
8-40V转5V 10A 12V 4A  高压大电流降压方案
4.5-80V转5V 3-5A 12V  2A  外置mos 高压大电流降压方案
4.5-52V转5V 4A  12V 2-3A 高压大电流降压方案
另外本公司提供各种DC-DC晶圆颗粒,协助客户封装生产。
M*P1484 dc-dc晶圆 1482电源IC晶圆 A*P2576 2596晶圆
431基准源芯片晶圆 A*P4310晶圆 A*P2952晶圆 4329晶圆 1117晶圆
升压IC晶圆 降压IC晶圆 432晶圆 各种DC-DC晶圆
1 220V降压12V/24V输出功率更大以适应更高功率的应用
2 非隔离电路无需变压器,外围电路更简单
3 节约外围元件成本
4 完全集成的缓启动电路降低了器件的应力及输出电压过冲
5 外部电路实现精确的限流编程
6 更宽的占空比实现更高的输出功率,同时可以使用更小尺寸的输入滤波电容
7 输入欠压(UV)检测可以防止关机时输出的不良波动
8 输入过压(OV)关断电路提高了对输入浪涌的耐受力
9 具有输出短路保护,开路保护功能
MC34119 小功率音频放大器
NE592 视频放大器OP07-CP精密运算放大器 TI[DATA] OP07-DP 精密运算放大器 TI[
NE5532 高速低噪声双运算放大器 TI   双运放 NE5534 高速低噪声单运算放大器 TI   单运放 OPA602  高速高精度运放(无OPA2602) OPA604单  OPA2604双   低噪声运放
OPA132单  OPA2132双  OPA4132四  高速低噪运放
OPA227 OPA2227 OPA4227  OPA228 OPA2228 OPA4228 高精度低噪声运放
AD844:60MHz、2000V/us单芯片运算放大器 高带宽、非常快速的大信号响应特性
常用的压控放大器:AD603  VCA810  VCA820 AD603:低噪声 电压控制增益运放 90MHz带宽 VCA810:35MHz高增益可调节范围宽带压控放大器
25mV/dB(-40dB~40dB)
此内容由EEWORLD论坛网友mk0007原创,如需转载或用于商业用途需征得作者同意并注明出处
VCA820:150MHz增益可调运放(-20~+20dB)
OK122   带宽150KHZ 低噪声运放
OK222   带宽1MHZ 低噪声 低静态电流
OK358   带宽1MHZ双运放
OK324  带宽1MHZ 四通道运放
OK522  带宽3.6MHZ   低噪声双运放
OK622  带宽6.5MHZ 低噪声运放
OK722  带宽 10MHZ  低噪声双运放
OK8041  8042低静态功耗 单通道和双通道运放
OK8051  8052 带宽250MHZ 高速运放 单双通道
OK8551  8552 8554 高精密 零温漂 单通道 双通道运放
猜你喜欢
ADI &文晔 探索季第一站,邀您在活动帖跟帖,ADI资深工程师将与您一道寻求解决之道! ...
春晚,最出圈当属穿着棉马甲跳秧歌的机器人”秧Bot”。
转手绢、飞手绢、变换队形,精准度和稳定性甚至超越人类,这背后少不了电机控制技术。
