1758|0
2015
分享C6713的外设URAT实例代码 [复制链接]
C6713的外设URAT实例代码
部分关键函数:
[mw_shl_code=c,true]extern Uint32 UART_open(UartId uart)
        Uint32 ret_data;
        if(uart == 0)
                ret_data = 0x00000000;
                return ret_data;
        if(uart ==1)
                ret_data = 0x00040000;
                return  ret_data;
        ret_data = 0xFFFFFFFF;
        return ret_data;
\*UART_setup()        -UART setup.
\*Parameters:
\*                channel: Channel NO. UART A or UART B.
\*                UartBaud: UART baudrate.
\*                   UartWordLen: UART word length.
\*                 UartStopBits: UART stop bits.
\*                   UartParity:        UART parity.
\*                   UartFifoControl: UART FIFO control.
\*                   UartLoopway: UART loop.
void UART_setup(Uint32 channel,
                                                        Uint16 UartBaud,
                                                        Uint8 UartWordLen,
                                                        Uint8 UartStopBits,
                                                        Uint8 UartParity,
                                                        Uint8 UartFifoControl,
                                                        Uint8 UartLoopway)
        Uint8 baudratel,baudrateh,uartdata;
        /* Set clock divisor as "1" */
        UART_rset(channel,UART_LCR,0xBF);
        UART_rset(channel,UART_EFR,0x10);
        UART_rset(channel,UART_LCR,0x00);
        UART_rset(channel,UART_MCR,0x00);
        /* Set baudrate. */
        UART_rset(channel,UART_LCR,0x80);
        baudratel = (UartBaud & 0x00ff);
        UART_rset(channel,UART_DLL,baudratel);
        baudrateh = (UartBaud & 0xff00) >> 8;
        UART_rset(channel,UART_DLH,baudrateh);
        /* Set word length. */
        uartdata = UartWordLen + UartStopBits + UartParity;
        UART_rset(channel,UART_LCR,uartdata);
        /* Set FIFO parameters. */
        UART_rset(channel,UART_FCR,FIFO_rreset);
        UART_rset(channel,UART_FCR,UartFifoControl);
        UART_rset(channel,UART_MCR,UartLoopway);
        //UART_rset(channel,UART_IER,0x01);// added 2005.4.26
\*UART_receive_single()        -UART serial data receiving function.
\*Parameters:
\*                rec_dada_add: Start Add for storing reveived data.
\*Return: 0,Finish Receiveng.
                  1,Data not ready.
                  0xFFFF,Port error.
                  2,Interrupt timeout.
Uint16 UART_receive_single(Uint32 channel)
        Uint16 revdata;
        revdata = UART_rget(channel,UART_RHR);
        return(revdata&0xFF);
\*UART_send_single()        -Send a set of data.
\*Parameters:
\*                send_data: To be sent data.
\*Return: No.
void UART_send_single(Uint32 channel,Uint8 send_data)
        Uint16 lsrdata;
        do
        lsrdata = UART_rget(channel,UART_LSR);
        while((lsrdata & 0x40) != 0x40);
        UART_rset(channel,UART_THR,send_data);
\*UART_send()                -Send data function.
\*Parameters:
\*                length:        Data buffer length.
\*                send_data_add: To be sent data start address.
void UART_send(Uint32 channel,Uint16 BaudRate,Uint16 length,Uint8 *send_data)
        Uint16 i;
        for(i=0;i         {
                UART_send_single(channel,*send_data++);
                DEC6713_wait((BaudRate/baud_38k4)*2026);
                //DEC6713_wait(8065);
\* UART_IntSetup() - Setup UART interrupt. *\
\* Parameters:
\* Returns:
void UART_IntSetup(Uint32 channel,Uint8 UartIntn)
        UART_rset(channel,UART_IER,UartIntn);
        UART_rset(channel,UART_MCR,0x49);
}[/mw_shl_code]
