1375|0
3836
金属探测传感器MSP430控制程序 [复制链接]
/**** TI LDC1000 驱动程序
#include "msp430f149.h"
#define LDC1000_CS_L   P3OUT &= ~BIT0  //片选
#define LDC1000_CS_H   P3OUT |= BIT0
#define LDC1000_CLK_L  P3OUT &= ~BIT3  //CLK
#define LDC1000_CLK_H  P3OUT |= BIT3
#define LDC1000_OUT_L  P3OUT &= ~BIT1 //Data Out
#define LDC1000_OUT_H  P3OUT |= BIT1
#define LDC1000_IN     (P3IN&BIT2)   //Data In
void Init_LDC1000_Port()
  P3DIR |= BIT0 + BIT1 + BIT3;  //P3.0,P3.1,P3.3
  P3DIR &= ~BIT2;               //P3.2
  LDC1000_CS_H;
  LDC1000_CLK_L;
  LDC1000_OUT_H;
void LDC1000_WriteData(uchar address, uchar data)
  uchar i = 0;
  uchar temp = 0;
  temp = address;
  LDC1000_CS_L;
  LDC1000_CLK_L;
  for(i=0;i<8;i++)
    LDC1000_CLK_L;
    if(temp&0x80)
      LDC1000_OUT_H;
    else
      LDC1000_OUT_L;
    LDC1000_CLK_H;
    temp = temp<<1;
  temp = data;
  for(i=0;i<8;i++)
    LDC1000_CLK_L;
    if(temp&0x80)
      LDC1000_OUT_H;
    else
      LDC1000_OUT_L;
    LDC1000_CLK_H;
    temp = temp<<1;
  LDC1000_CLK_L;
  LDC1000_CS_H;
uint LDC1000_ReadData(uchar address, unsigned long *f)
  uchar i = 0;
  uchar temp = 0;
  uint rp1 = 0,rp2 = 0;
  uint f1 = 0,f2 = 0;
  unsigned long f3 = 0;
  temp = address;
  temp = temp|0x80;
  LDC1000_CS_L;
  LDC1000_CLK_L;
  for(i=0;i<8;i++)
    LDC1000_CLK_L;
    if(temp&0x80)
      LDC1000_OUT_H;
    else
      LDC1000_OUT_L;
    LDC1000_CLK_H;
    temp = temp<<1;
  LDC1000_OUT_L;
  for(i=0;i<8;i++)
    LDC1000_CLK_L;
    _NOP();
    rp1 |= (LDC1000_IN>>2)<<(7-i);
    LDC1000_CLK_H;
  for(i=0;i<8;i++)
    LDC1000_CLK_L;
    _NOP();
    rp2 |= (LDC1000_IN>>2)<<(7-i);
    LDC1000_CLK_H;
  rp2 = (rp2<<8 )+ rp1;
  for(i=0;i<8;i++)
    LDC1000_CLK_L;
    _NOP();
    f1 |= (LDC1000_IN>>2)<<(7-i);
    LDC1000_CLK_H;
  for(i=0;i<8;i++)
    LDC1000_CLK_L;
    _NOP();
    f2 |= (LDC1000_IN>>2)<<(7-i);
    LDC1000_CLK_H;
  f2 = (f2<<8) + f1;
  for(i=0;i<8;i++)
    LDC1000_CLK_L;
    _NOP();
    f3 |= (LDC1000_IN>>2)<<(7-i);
    LDC1000_CLK_H;
  f3 = (f3<<16) +f2;
  *f = f3;
  LDC1000_CLK_L;
  LDC1000_CS_H;
  return rp2;
void Init_LDC1000_R(void)
  Init_LDC1000_Port();
  LDC1000_WriteData(0x01, 0x0A);   //250k
  LDC1000_WriteData(0x02, 0x3B);   //2.4k
  LDC1000_WriteData(0x03, 241);    //low frequency
  LDC1000_WriteData(0x04, 0x17);   //4V, 6144
  LDC1000_WriteData(0x05, 0x00);   //TBCLK
  LDC1000_WriteData(0x06, 0x50);
  LDC1000_WriteData(0x07, 0xC3);   //50k
  LDC1000_WriteData(0x08, 0x88);
  LDC1000_WriteData(0x09, 0x13);   // 5k
  LDC1000_WriteData(0x0A, 0x04);  //DRDYB mode
  LDC1000_WriteData(0x0B, 0x01);  //Power on
void main()
  WDTCTL = WDTPW + WDTHOLD;
volatile unsigned int i;
  BCSCTL1 &= ~XT2OFF;         //开启高频晶振,XT2=8MHZ
  do
    IFG1 &= ~OFIFG;           // Clear OSCFault flag
    for (i = 0xFF; i > 0; i--);  // Time for flag to set
  while ((IFG1 & OFIFG));
  BCSCTL2 |= SELM1+SELS;   //MCLK=SMCLK=XT2=8MHZ
  P5SEL |= BIT4;
  P5DIR |= BIT4;
  unsigned int rp = 0;
  unsigned long f = 0;
  while(1)
    rp = LCD1000_ReadData(0x21,&f);
