5378|1
ros控制小车运行编程 [复制链接]
1、 roscore
2、 sudo chmod a+rw /dev/ttyACM0
3、 rosrun rosserial_python serial_node.py /dev/ttyACM0
4、 rosrun turtlesim turtle_teleop_key
代码:::
#include
#include
#include
//定义五中运动状态
#define STOP      0
#define FORWARD   1
#define BACKWARD  2
#define TURNLEFT  3
#define TURNRIGHT 4
//定义需要用到的引脚
int leftMotor1 = 4;
int leftMotor2 = 5;
int rightMotor1 = 6;
int rightMotor2 = 7;
//x轴方向的速度
double lin_vel = 0.0;
//y轴方向的速度
double ang_vel = 0.0;
//定义接受的键
int cmd_ctrl = 0;
//注册ROS节点
ros::NodeHandle nh;
//回调函数
void messageCb(constgeometry_msgs::Twist& vel) {
lin_vel = vel.linear.x;
ang_vel = vel.angular.z;
cmd_ctrl = 1 * lin_vel + 3 * ang_vel;
//设置订阅的消息类型和发布的主题
ros::Subscribersub("/turtle1/cmd_vel", messageCb);
void setup() {
  //put your setup code here, to run once:
  //设置控制电机的引脚为输出状态
pinMode(leftMotor1, OUTPUT);
pinMode(leftMotor2, OUTPUT);
pinMode(rightMotor1, OUTPUT);
pinMode(rightMotor2, OUTPUT);
nh.initNode();
nh.subscribe(sub);
void loop() {
  //put your main code here, to run repeatedly:
nh.spinOnce();
switch(cmd_ctrl)
     case 2:
       motorRun(4);
       delay(2000);//每个命令执行2s
       motorRun(5);
       break;
      case -2:
        motorRun(3);
        motorRun(5);
        break;
      case 6:
        motorRun(1);
         motorRun(5);
        break;
      case -6:
        motorRun(2);
         motorRun(5);
        break;
     default:
       motorRun(5);
       break;
   cmd_ctrl = 0;
//运动控制函数
void motorRun(int cmd)
switch(cmd){
   case FORWARD:
     digitalWrite(leftMotor1, LOW);
     digitalWrite(leftMotor2, HIGH);
     digitalWrite(rightMotor1, LOW);
     digitalWrite(rightMotor2, HIGH);
     break;
    case BACKWARD:
     digitalWrite(leftMotor1, HIGH);
     digitalWrite(leftMotor2, LOW);
     digitalWrite(rightMotor1, HIGH);
     digitalWrite(rightMotor2, LOW);
     break;
    case TURNLEFT:
     break;
    case TURNRIGHT:
     break;
    default:
此内容由EEWORLD论坛网友fiveFeng原创,如需转载或用于商业用途需征得作者同意并注明出处
好精致的代码啊????  详情 回复 发表于 2018-5-28 11:27
1903
好精致的代码啊????
