1389|0
2014
DSP2833x例程GPIO_output_LED [复制链接]
#include "DSP2833x_Device.h"     // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h"   // DSP2833x Examples Include File
#define          LED1        GpioDataRegs.GPADAT.bit.GPIO0
#define          LED2        GpioDataRegs.GPADAT.bit.GPIO1
#define          LED3        GpioDataRegs.GPADAT.bit.GPIO2
#define          LED4        GpioDataRegs.GPADAT.bit.GPIO3
#define          LED5        GpioDataRegs.GPADAT.bit.GPIO4
void configtestled(void);
void main(void)
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP2833x_SysCtrl.c file.
   InitSysCtrl();
// Step 2. Initalize GPIO:
// This example function is found in the DSP2833x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio();  // Skipped for this example
   InitXintf16Gpio();        //zq
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
   DINT;
// Initialize the PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2833x_PieCtrl.c file.
   InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
   IER = 0x0000;
   IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example.  This is useful for debug purposes.
// The shell ISR routines are found in DSP2833x_DefaultIsr.c.
// This function is found in DSP2833x_PieVect.c.
   InitPieVectTable();
   configtestled();
   //   LED1=1;
  // DELAY_US(10);
  //    LED2=1;
  // DELAY_US(10);
      LED1=0;
   DELAY_US(10);
      LED2=0;
   DELAY_US(10);
lab1-GPIO_output_LED.rar (412.62 KB, 下载次数: 1)
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
