4449|0
TRACO电源(1W-22000W) [复制链接]
TRACO POWER是一家总部在瑞士苏黎世的公司。其电源产品以其安全性和可靠性著称于世,已成为电源供应方面的领导厂商。主要专注于研发和生产高质量的直流转直流、交流转直流电源模块。该产品已广泛应用于邮电通讯、信息网络、铁道系统、交通控制、电力系统、医疗设备、工业控制 等领域。
> 瑞士以质量闻名于世,Traco工厂提供3年质保
> 工厂通过ISO9000认证
> 所有产品符合无铅标准
> 符合欧洲安全标准
> 模块工作温度-40—+85C
> 产品范围广,1-22000W
> 大量库存,量产货期8-10周或更短
TOL 10-05     TES 2N-1221     TPM 30515C     TEN 8-2411     TMR 2412
TOL 10-12     TES 2N-1222     TPM 40105C     TEN 8-2412     TMR 2421
TOL 10-24     TES 2N-1223     TPM 40112C     TEN 8-2413     TMR 2422
TOL 15-05     TES 2N-2410     TPM 40124C     TEN 8-2421     TMR 2423
TOL 15-12     TES 2N-2411     TOM 12105     TEN 8-2422     TMR 4810
TOL 15-24     TES 2N-2412     TOM 12112     TEN 8-2423     TMR 4811
TOL 30-05     TES 2N-2413     TOM 12115     TEN 8-4810     TMR 4812
TOL 30-12     TES 2N-2421     TOM 12124     TEN 8-4811     TMR 4821
TOL 30-24     TES 2N-2422     TOM 12212     TEN 8-4812     TMR 4822
TOL 50-05     TES 2N-2423     TOM 12215     TEN 8-4813     TMR 4823
TOL 50-12     TES 2N-4810     TOM 24105     TEN 8-4821     TYL 05-05S30
TOL 50-24F     TES 2N-4811     TOM 24112     TEN 8-4822     TYL 05-12S12
TOL 75-05     TES 2N-4812     TOM 24115     TEN 8-4823     TYL 05-15S10
TOL 75-12     TES 2N-4813     TOM 24124     TEN 8-2410WI     TYL 05-05W08
TOL 75-24F     TES 2N-4821     TXL 025-3.3S     TEN 8-2411WI     TYL 05-12W06
TOL 100-05     TES 2N-4822     TXL 025-05S     TEN 8-2412WI     TYL 05-15W05
TOL 100-12     TES 2N-4823     TXL 025-12S     TEN 8-2413WI     THI 0511
TOL100-24F     TEL 2-0510     TXL 025-15S     TEN 8-2421WI     THI 0512
TOL100-48     TEL 2-0511     TXL 025-24S     TEN 8-2422WI     THI 0513
TOL150-05     TEL 2-0512     TXL 025-48S     TEN 8-2423WI     THI 0520
TOL150-12     TEL 2-0513     TXL 035-3.3S     TEN 8-4810WI     THI 0521
TOL150-24F     TEL 2-0521     TXL 035-05S     TEN 8-4811WI     THI 0522
TOL150-48     TEL 2-0522     TXL 035-12S     TEN 8-4812WI     TEN-HS3
TOL300-12     TEL 2-0523     TXL 035-15S     TEN 8-4813WI     TMS06105
TOL300-24     TEL 2-1210     TXL 035-24S     TEN 8-4821WI     TZL 060-2412
TOL300-48     TEL 2-1211     TXL 035-48S     TEN 8-4822WI     TZL 060-2424
TOL10-MC     TEL 2-1212     TXL 050-05S     TEN 8-4823WI     TZL 060-4812
TOL15-MC     TEL 2-1213     TXL 060-3.3S     TOS 06-05SM     TZL 060-4824
TOL30-MC     TEL 2-1221     TXL 060-05S     TOS 06-12SM     TZL 100-2412
TOL50-MC     TEL 2-1222     TXL 060-12S     TOS 10-05SM     TZL 100-2424
TOL75-MC     TEL 2-1223     TXL 060-15S     TOS 10-12SM     TZL 100-4812
TOL100-MC     TEL 2-2410     TXL 060-24S     TOS 16-05SM     TZL 100-4824
TOL150-MC     TEL 2-2411     TXL 070-12S     TOS 16-12SM     TZL 150-2412
TOL300-MC     TEL 2-2412     TXL 070-15S     TOS 06-05SIL     TZL 150-2424
TOL-C31     TEL 2-2413     TXL 070-24S     TOS 06-12SIL     TZL 150-4812
TOL-C41     TEL 2-2421     TXL 070-48S     TOS 10-05SIL     TZL 150-4824
TOL-C42     TEL 2-2422     TXL 100-3.3S     TOS 10-12SIL     TZL 300-4812
TOL-C61     TEL 2-2423     TXL 100-05S     TOS 16-05SIL     TZL 300-4824
TOL-C62     TEL 2-4810     TXL 100-12S     TOS 16-12SIL     TME0515S
TOL-C71     TEL 2-4811     TXL 100-15S     TSI 10N-0510     TES 2N-0510
TOL-C81     TEL 2-4812     TXL 100-24S     TSI 10N-1211     TES 2N-0511
TOF 10-05S     TEL 2-4813     TXL 100-48S     TSI 10N-2410     TES 2N-0512
TOF 10-12S     TEL 2-4821     TXL 120-12S     TSI 10N-2411     TES 2N-0513
TOF 10-15S     TEL 2-4822     TXL 120-15S     TSI 10N-0510D     TES 2N-0521
TOF 10-24S     TEL 2-4823     TXL 120-24S     TSI 10N-1211D     TMH 0505S
TOF 15-05S     TEM 2-0511     TXL 120-48S     TSI 10N-2410D     TMH 0512S
TOF 15-12S     TEM 2-0512     TXL 150-05S     TSI 10N-2411D     TMH 0515S
TOF 15-15S     TEM 2-0521     TXL 150-12S     THD 10-1209     TMH 0505D
TOF 15-24S     TEM 2-0522     TXL 150-24S     THD 10-1210     TMH 0512D
TOF 30-05S     TEM 2-1211     TXL 150-48S     THD 10-1211     TMH 0515D
TOF 30-12S     TEM 2-1212     TXL 220-12S     THD 10-1212     TMH 1205S
TOF 30-15S     TEM 2-1221     TXL 220-24S     THD 10-1222     TMH 1212S
TOF 30-24S     TEM 2-1222     TXL 220-48S     THD 10-1223     TMH 1215S
TOF 50-05S     TEM 2-2411     TXL 300-24S     THD 10-2409     TMH 1205D
TOF 50-12S     TEM 2-2412     TXL 300-48S     THD 10-2410     TMH 1212D
TOF 50-15S     TEM 2-2421     TXL 600-24S     THD 10-2411     TMH 1215D
TOF 50-24F     TEM 2-2422     TXL 600-48S     THD 10-2412     THI 1211
TOF 75-05S     TEM 3-0511     TXL 035-0512D     THD 10-2422     THI 1212
TOF 75-12S     TEM 3-0512     TXL 035-0524D     THD 10-2423     THI 1213
TOF 75-15S     TEM 3-0521     TXL 035-1212D     THD 10-4809     THI 1220
TOF 75-24F     TEM 3-0522     TXL 035-1515D
中国代理及技术支持中心
西安浩南电子科技有限公司
刘彦成
13720726368
TEL:029-88231631  88231651
FAX:029-88231651
地址:西安市高新区太白南路181号A座工业写字楼C318室
邮编:710065
网址::http://www.haonpower.com
邮箱:lyc@haonpower.com
