6447|3
关于IIC写入EEPROM的问题 [复制链接]
这段程序完成了利用IIC写入EEPROM的任务,先是写入IIC slave的地址,然后写入EEPROM的地址,最后写入data。但是,写入EEPROM的地址这段没看懂,照这样不能写入我要求写入的地址,实际运行中这段程序却是可以完成写入EEPROM的功能的,求大家指教下!代码如下:
void EEPROM_WRITE_WORD(Uint16 address, Uint16 data)
    Uint16 para_temp0, para_temp1, eeprom_waitcount;
        int romaddr=0;
    romaddr = MDB2ROMADDR(address);
    if(romaddr == -1) return;
    address = (Uint16)romaddr;
    eeprom_waitcount = 0;
    while(eeprom_waitcount < 20)
        ServiceDog(); //KickDog();
        eeprom_waitcount++;
        STARTE2PROM();
        para_temp0 = 0x0a0; //;GET read ctrl byte 0xa0
        para_temp1 = EEPROM_WRITE_BYTE(para_temp0);
        if(para_temp1 == 0)
            //;--->>---写地址字节
            para_temp0 = address >> 7;
            EEPROM_WRITE_BYTE(para_temp0 &0xff); //;Write Address to EEPROM
            para_temp0 = ((address << 1) &0xfe);
            WRITEE2PROMAWORD(data); ////;Write DATA to EEPROM
            ENDE2PROM();
            gSysFaultMessage.bit.InvEEpromFault = 0;   //V1.07
            sub_ErrCode_delete(234);
            return ;
    gSysFaultMessage.bit.InvEEpromFault = 1; //V1.07
    error_code = ErrCode_EepromRWErr;
        EepromWriteErr++;
    //;--->>---写地址字节
    WRITEE2PROMAWORD(data); //;Write DATA to EEPROM
    ENDE2PROM();
    return ;
Uint16 EEPROM_WRITE_BYTE(Uint16 data)
    Uint16 para_temp0, para_temp1, para_temp2, para_temp3;
    para_temp0 = (data << 8) &0xff00;
    for(para_temp2 = 0; para_temp2 < 1; para_temp2++)
    //;OUTER LOOP COUNTER
        for(para_temp1 = 0; para_temp1 < 8; para_temp1++)
        //;INNER LOOP COUNTER
            scl_low; //SCL=0
            DELAY_US(TLOW);
            if(para_temp0 &0x8000)
                //;--->>---SDA=1 -------->>
                sda_high;
                EALLOW;
                GpioCtrlRegs.GPBDIR.bit.GPIO32 = 1; // GPIO32 = output
                EDIS;
                sda_high;
            else
                //;--->>---SDA=0 -------->>
                sda_low;
                EALLOW;
                EDIS;
                sda_low;
            DELAY_US(2);
            scl_high; //SCL=1
            DELAY_US(THIGH);
            para_temp0 = para_temp0 << 1;
        scl_low; //SCL=0
        DELAY_US(TFALL);
        EALLOW;
        GpioCtrlRegs.GPBDIR.bit.GPIO32 = 0; // GPIO32 = input
        EDIS;
        DELAY_US(TLOW);
        scl_high; //SCL=1
        DELAY_US(THIGH);
        para_temp3 = GpioDataRegs.GPBDAT.bit.GPIO32; //;ACK BACKUP
        scl_low; //SCL=0
        DELAY_US(TFALL);
        sda_high;
        EALLOW;
        EDIS;
        sda_high;
        DELAY_US(TLOW);
    return (para_temp3);
学习下  详情 回复 发表于 2018-4-28 16:48
没有人出来讨论下吗?
结贴,已经明白了
182
禁止发言
学习下
个人签名嘉立创PCB打样  QQ800058452
