1379|0
3836
MSP430单片机存储器结构总结 [复制链接]
      FLASH型的MSP430单片机都带有信息存储器SegmengA及SegmentB,SegmengA及SegmentB各有128字,SegmentB的地址是:0x01000h到0x107F,SegmentA的地址是:0x01080h到0x010FFh。程序被写入MSP430之后,程序通过SegmengA及SegmentB就可以保存不掉电数据。注意:每次程序烧写到MSP430时,SegmengA及SegmentB都会被擦除!
      接下来贴出本文的程序代码,以及程序写入信息存储器之后的FLASH数据:
[cpp] view plain copy
#include
void WriteSegment_256 (char index,char *value,char size);
char ReadSegment_256(char index);
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop watchdog timer
  FCTL2 = FWKEY + FSSEL0 + FN0;             // MCLK/2 for Flash Timing Generator
  char str1[3]={0xAA,0xBB,0xCC};
  WriteSegment_256(0,str1,3);
  for(char i=0;i<255;i++)
    _NOP();
  char str2[3]={0xBB,0xAA,0xCC};
  WriteSegment_256(0,str2,3);
#define SegmentStart 0x01000  //Segment = 0x01000~0x010FF
#define SegmentSize 255 //SegmentA + SegmentB = 256
//读取片内存储的数据
  char *flash_ptr = ((char *) SegmentStart) + index;
  return *flash_ptr;
//把数组写入数据到片内FLASH,必须先全部擦除再写入
//参数index:保存数组的位置
//参数value:数组的指针
//参数size:数组的大小
  char buffer[SegmentSize],i=0;
  char *flash_ptr = (char *) SegmentStart;
  //先读取原FLASH数组
  for(i=0;i     buffer[i]=ReadSegment_256(i);
  //擦除FLASH,必须
  FCTL1 = FWKEY + ERASE;                    // Set Erase bit
  FCTL3 = FWKEY;                            // Clear Lock bit
  *flash_ptr = 0;                           // Dummy write to erase Flash segment
  //把整个数组都写入FLASH
  FCTL1 = FWKEY + WRT;                      // Set WRT bit for write operation
  for(i=0;i     buffer[index+i]=value[i];
  for(i=0; i     *(flash_ptr++) = buffer[i];
  FCTL1 = FWKEY;                            // Clear WRT bit
  FCTL3 = FWKEY + LOCK;                     // Set LOCK bit
