2552|0
2015
有关TI CCS5.3编译器输出Hex文件 [复制链接]
      1.工程属性 (Alt+Enter) 界面如下图:
      2.  在TI的安装目录中寻找:D:\TI\ccsv5\tools\compiler\msp430_4.1.2\bin\hex430.exe  用命令提示符打开
      一下是获取的命令参数:
General Options:
  --byte,-byte                 Output as bytes rather than target addressing
  --exclude,-exclude=section   Exclude section from hex conversion
  --fill,-fill=val             Specify fill value
  --help,-options,-h           Display help
  --image,-image               Select image mode
  --linkerfill,-linkerfill     Include linker fill sections in images
  --map,-map=file              Specify map file name
  --memwidth,-memwidth=width   Specify memory width
  --olength,-olength=num       Number of data items per line of hex output
  --order,-order=LS,MS         Specify data ordering (endianness)
  --outfile,-o=file            Specify output file names
  --quiet,-quiet,-q            Quiet Operation
  --romwidth,-romwidth=width   Specify rom width
  --zero,-zero,-z              Zero based addressing
Diagnostics Options:
  --diag_error=id              Treat diagnostic as error
  --diag_remark=id             Treat diagnostic as remark
  --diag_suppress=id           Suppress diagnostic
  --diag_warning=id            Treat diagnostic as warning
  --diag_wrap[=on,off]         Wrap diagnostic messages (argument optional,
                                defaults to: on)
  --display_error_number       Emit diagnostic identifier numbers
  --emit_warnings_as_errors,-pdew
                               Treat warnings as errors
  --issue_remarks              Issue remarks
  --no_warnings                Suppress warnings
  --set_error_limit=count      Set error limit to
Output Format Options:
  --ascii,-a                   Output ASCII hex format
  --intel,-i                   Output Intel hex format
  --motorola,-m[=1,2,3]        Output Motorola S hex format
  --tektronix,-x               Output Extended Tektronix hex format
  --ti_tagged,-t               Output TI-Tagged hex format
  --ti_txt                     Output TI-TXT hex format
Load Image Options:
  --load_image                 Output Load Image Object format
  --section_name_prefix=string Prefix for load image object sections
复制代码
      例如:
      -i "1.out" -o "2.hex"  -order MS  -romwidth 16
      -i 表示hex格式的文件,
      -ti_txt 表示生成TI-TXT hex格式。
