1449|0
3836
基于msp430g2553呼吸灯程序 [复制链接]
#include
void BreathLED()
        P1SEL =BIT6;
        P1DIR = BIT6;
        P1OUT=0;
        TACTL = TASSEL_1 + MC_1  ;
        TACCTL1 =  OUTMOD_3 ;
        TACCTL0 = CCIE;
        CCR0 =12000;
        CCR1 =327;         //0% pwm
        TACTL |=TACLR;
        _EINT();
int main( void )
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  BCSCTL3 |= LFXT1S_2; // Set LFXT1为vol时钟即12kHZ
  BreathLED();
  LPM0;
  return 0;
#pragma vector=TIMER0_A0_VECTOR
__interrupt void CountTimes()
        static int Times;
        Times++;
        switch(Times)
        case 20:
                CCR1=294;
                break;
        case 30:
                CCR1=277;
                break;
        case 40:
                CCR1=262;   //20% PWM
                break;
        case 50:
                CCR1=245;   //20% PWM
                break;
        case 60:
                CCR1=228;   //40% PWM
                break;
        case 80:
                CCR1=196;   //40% PWM
                break;
        case 100:
                CCR1=163;
                break;
        case 120:
                CCR1=131;   //60% PWM
                break;
        case 140:
                CCR1=98;   //60% PWM
                break;
        case 160:
                CCR1=65;    //80% PWM
                break;
        case 180:
                CCR1=32;    //80% PWM
                break;
        case 200:
                CCR1=1;     //100% PWM
                break;
        case 220:
                CCR1=32;    //80% PWM
                break;
        case 240:
                CCR1=65;
                break;
        case 260:
                CCR1=98;   //60% PWM
                break;
        case 280:
                CCR1=131;
                break;
        case 300:
                CCR1=163;
                break;
        case 320:
                CCR1=196;
                break;
        case 340:
                CCR1=228;   //40% PWM
                break;
        case 350:
                CCR1=245;   //40% PWM
                break;
        case 360:
                CCR1=262;
                break;
        case 370:
                CCR1=277;
                break;
        case 380:
                CCR1=294;
                break;
        case 390:
                CCR1=310;
                break;
        case 400:
                CCR1=327;
                Times=0;
                break;
        default:
                break;
