2079|0
3836
MSP432开发板串口调试 [复制链接]
拿到MSP432P401R评估板v1.0(这个请注意一下,目前在德州仪器官网上找到的硬件原理图是v2.0,v1.0的串口所在的引脚是RXD,TXD引脚),先将串口调试好,便于下一步工作的展开。首先,查看TI提供的代码例子,这个例子就在TI的MSPWare代码包内。注释如下:
//  MSP432P401 Demo - eUSCI_A0 UART echo at 9600 baud using BRCLK = 12MHz
// Description: This demo echoes back characters received via a PC serialport.
//  SMCLK/DCO is used as a clock source and the device is put in LPM3
//  Theauto-clock enable feature is used by the eUSCI and SMCLK is turned off
//  when theUART is idle and turned on when a receive edge is detected.
//  Note thatlevel shifter hardware is needed to shift between RS232 and MSP
//  voltagelevels.
//  Theexample code shows proper initialization of registers
//  andinterrupts to receive and transmit data.
//  To testcode in LPM3, disconnect the debugger.
//               MSP432P401
//         --|RST              |
//           |     P1.3/UCA0TXD|----> PC(echo)
//           |     P1.2/UCA0RXD|<---- PC
//   Wei Zhao
//   TexasInstruments Inc.
//   October2015 (updated) | June 2014 (created)
//   Builtwith Code Composer Studio V6.0
从以上信息我们可以看出,此段例程所要做的事情就是将板载串口配置成9600波特率工作的串口,并原样送回我们发送进去的数据。从示意图中我们可以看出,我们只需要一对收发线即可完成本实验。接下来分析其源代码。
#include "msp.h"
int main(void)
  WDTCTL =WDTPW | WDTHOLD;               // Stopwatchdog timer
  CS->KEY= 0x695A;                        //Unlock CS module for register access
  CS->CTL0= 0;                            // Resettuning parameters
  CS->CTL0= CS_CTL0_DCORSEL_3;                   //Set DCO to 12MHz (nominal, center of 8-16MHz range)
                                         //Select ACLK = REFO, SMCLK = MCLK = DCO
  CS->CTL1= CS_CTL1_SELA_2 | CS_CTL1_SELS_3 | CS_CTL1_SELM_3;
  CS->KEY= 0;                             // LockCS module from unintended accesses
  //Configure UART pins
  P1SEL0 |=BIT2 | BIT3;                  // set2-UART pin as second function
__enable_interrupt();
NVIC->ISER[0] = 1 << ((EUSCIA0_IRQn) & 31); // EnableeUSCIA0 interrupt in NVIC module
  //Configure UART
  UCA0CTLW0|= UCSWRST;
  UCA0CTLW0|= UCSSEL__SMCLK;             // PuteUSCI in reset
  // BaudRate calculation
  //12000000/(16*9600) = 78.125
  //Fractional portion = 0.125
  // User'sGuide Table 21-4: UCBRSx = 0x10
  // UCBRFx =int ( (78.125-78)*16) = 2
  UCA0BR0 =78;                           //12000000/16/9600
  UCA0BR1 =0x00;
  UCA0MCTLW= 0x1000 | UCOS16 | 0x0020;    //注意这一行的设定
  UCA0CTLW0&= ~UCSWRST;                  //Initialize eUSCI
  UCA0IE |=UCRXIE;                       // EnableUSCI_A0 RX interrupt
  __sleep();
__no_operation();                      // For debugger
// UART interrupt service routine
void EUSCIA0_IRQHandler(void)
    if(UCA0IFG & UCRXIFG)
     while(!(UCA0IFG&UCTXIFG));
     UCA0TXBUF = UCA0RXBUF;
     __no_operation();
我们首先粗略地研究一下这段测试代码,忽略前半部分关于始终设置的内容,检查我标记的注意行。UCA0MCTLW0寄存器的设定在芯片TechnicalReference Manual的745页,例程中基本是使用默认串口配置。串口通信波特率已经在前面代码中设定为9600。看明白了上述内容,就掌握了这块开发板串口的基本内容,有精力可以继续探索一下芯片手册,尝试串口的其他功能。重要提示,不要使用盗版ghost win7,这样会导致xds110板载调试器的驱动安装失败。
