2400|1
2015
MSP430F149-红外接收 [复制链接]
用MSP430(F149)做红外接收比发送更为简单,我采用的红外传感器是HS0038B,这个原件在接收到38K红外时输出低电平,否则输出高电平,因此,我们就可以从这点开始编写程序了,由于HS0038B的电路图很多,我这里就不贴出来了,下面是具体的代码:
[cpp] view plain copy
#include
#include "delay.h"
static unsigned short addr = 0x00;
static unsigned char ir_rx_buf[256];
static unsigned char ir_rx_w_offset = 0;
static unsigned char ir_rx_r_offset = 0;
void ir_tx_open(){
  P2DIR |= BIT2 | BIT3;//P2.2, P2.3输出
  P2SEL |= BIT3; //P2.2:IO P2.3:TA0
  P2SEL &= ~BIT2; //
  P2OUT &= ~(BIT2 | BIT3);
  //38K->P2.3
  CCR0 = (int)(26.3*8 + 0.5);
  CCTL1 = OUTMOD_6;
  CCR1 = (int)(13.15*8 + 0.5);
  TACTL = TASSEL_2 + MC_1;
void ir_set_addr(unsigned char addr){
  addr = (unsigned char)(0xff&addr);
static void ir_start(){
  P2OUT |= BIT2;
  delay_us(9000);
  P2OUT &= ~BIT2;
  delay_us(4500);
static void ir_next(){
  P2OUT |= BIT2;
  delay_us(9000);
  P2OUT &= ~BIT2;
  delay_us(2250);
static void ir_send_byte(unsigned char c){
  unsigned char i;
  for(i = 0; i != 8; ++i){
    P2OUT |= BIT2;
    delay_us(560);
    P2OUT &= ~BIT2;
    if(c&0x01){
      delay_us(1685);
    else{
      delay_us(565);
    c >>= 1;
static void ir_end(){
  P2OUT |= BIT2;
  delay_us(300);
  P2OUT &= ~BIT2;
void ir_put_char(unsigned char c){
  ir_start();
  ir_send_byte(addr);
  ir_send_byte(~addr);
  ir_send_byte(c);
  ir_send_byte(~c);
  ir_end();
void ir_put_string(char* str){
  if(*str != '\0')
    ir_start();
  else
    return;
  while(1){
    ir_send_byte(addr);
    ir_send_byte(*str);
    ir_send_byte(~(*str));
    ++str;
    if(*str != '\0'){
      ir_next();
    else{
      ir_end();
void ir_put_array(unsigned char* array, unsigned int length){
  unsigned int i;
  ir_start();
  for(i = 0; i != length; ++i){
    ir_send_byte(addr);
    ir_send_byte(array[i]);
    if(i < length-1){
      ir_next();
    else{
      ir_end();
void ir_tx_close(){
  P2SEL &- ~BIT3;
  P2DIR |= BIT3;
  P2OUT &= ~BIT3;
  TACTL = TACLR;
void ir_rx_open(){
  P2SEL &= ~BIT0; //I/O
  P2DIR &= ~BIT0; //Input
  P2IES |= BIT0;  //High->Low
  P2IE  |= BIT0;  //Enable interrupt
void ir_rx_close(){
  P2IE  &= ~BIT0;  //Disable interrupt
unsigned char ir_get(){
  while(ir_rx_r_offset == ir_rx_w_offset);
  return ir_rx_buf[ir_rx_r_offset++];
#pragma vector=PORT2_VECTOR
__interrupt void port2_handler(){
  static unsigned char ir_code[4];
  unsigned char i, j;
  unsigned short time;
  if(P2IFG&BIT0){
    P2IE &= ~BIT0;
    P2IFG &= ~BIT0;
    _EINT();
    time_start(9500);
    while(!time_out() && !(P2IN&BIT0));
    time = time_end();
    if(!time_out() && time > 8500){
      time_start(5000);
      while(!time_out() && (P2IN&BIT0));
      time = time_end();
      if(!time_out() && time > 4000){
        for(i = 0; i != 4; ++i){
          for(j = 0; j != 8; ++j){
            while(!(P2IN&BIT0));//等待高电平
            time_start(2000);   //计时高电平
            time = time_end();
            ir_code[i] >>= 1;
            if(!time_out() && time > 1500){
              //uart_put(0x03);
              ir_code[i] |= 0x80;
            else{
              //uart_put(0x04);
              ir_code[i] &= 0x7f;
        if(ir_code[0] == addr && (0xff == ir_code[0] + ir_code[1])){
          if(0xff == ir_code[2] + ir_code[3]){
            ir_rx_buf[ir_rx_w_offset++] = ir_code[2];
    P2IE |= BIT0;;
包含整理后的红外发送和接收,放在这里做个记录,有什么疑问欢迎留言讨论。
nice  详情 回复 发表于 2018-3-19 13:22
24
nice
