3451|6
发我的一个历程 [复制链接]
结合很多人的经验,总算把串口发送一个u,然后返回一个helloworld这个程序弄懂了。
话不多说,贴程序。
//   MSP430G2xx3 Demo - USCI_A0, Ultra-Low Pwr UART 9600 String, 32kHz ACLK
//   Description: This program demonstrates a full-duplex 9600-baud UART using
//   USCI_A0 and a 32kHz crystal.  The program will wait in LPM3, and will
//   respond to a received 'u' character using 8N1 protocol. The response will
//   be the string 'Hello World'.
//   ACLK = BRCLK = LFXT1 = 32768Hz, MCLK = SMCLK = DCO ~1.2MHz
//   Baud rate divider with 32768Hz XTAL @9600 = 32768Hz/9600 = 3.41
//* An external watch crystal is required on XIN XOUT for ACLK *//
//                MSP430G2xx3
//         /|\|              XIN|-
//          | |                 | 32kHz
//          --|RST          XOUT|-
//            |     P1.2/UCA0TXD|------------>
//            |                 | 9600 - 8N1
//            |     P1.1/UCA0RXD|<------------
//   D. Dang
//   Texas Instruments Inc.
//   February 2011
//   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
#include  "msp430g2553.h"
const char string1[] = { "Hello World\r\n" };
unsigned int i;
void main(void)
  WDTCTL = WDTPW + WDTHOLD;
    BCSCTL1 = CALBC1_1MHZ; // Set DCO
    DCOCTL = CALDCO_1MHZ;
    P1SEL = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
    P1SEL2 = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
    UCA0CTL1 |= UCSSEL_2; // 选择SMCLK作为频率源
    UCA0BR0 = 104; // 1MHz 9600
    UCA0BR1 = 0; // 1MHz 9600
    UCA0MCTL = UCBRS0; // Modulation UCBRSx = 1
    UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
    IE2 |= UCA0RXIE; // Enable USCI_A0 RX interrupt
     for(;;)
    __bis_SR_register(LPM0_bits + GIE);
#pragma vector=USCIAB0TX_VECTOR
__interrupt void USCI0TX_ISR(void)
  UCA0TXBUF = string1[i++];                 // TX next character
  if (i == sizeof string1 - 1)              // TX over?
    IE2 &= ~UCA0TXIE;                       // Disable USCI_A0 TX interrupt
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
  if (UCA0RXBUF == 'u')                     // 'u' received?
    i = 0;
    IE2 |= UCA0TXIE;                        // Enable USCI_A0 TX interrupt
这个程序是调试完成成功的。保证绝对正确。如果不正确,肯定是你外部的毛病了。   详情 回复 发表于 2024-4-12 22:04
这个程序是本人调试完成成功的。保证绝对正确。如果不正确,肯定是你外部的毛病了。
3251
多谢分享
个人签名为江山踏坏了乌骓马,为社稷拉断了宝雕弓。
506
你这程序本身没问题啊  但是不是很规范啊
bioger 发表于 2018-1-17 14:26
你这程序本身没问题啊  但是不是很规范啊
写的规范的都敝帚自珍,只能我这种三脚猫出来给大家演示了。
WDTCTL = WDTPW + WDTHOLD;这个是什么意思,没有注释看不懂
97
【直播时间】5月28日(周三)上午10:00
