1373|0
数显-双锁存(数显共阴,段 与 位共用 端口P0口) [复制链接]
*   2数显-双锁存(数显共阴,段 与 位共用 端口P0口)  *
#include
#define uchar unsigned char
#define uint unsigned int
    sbit led1=P1^0;
        sbit dula=P2^6;
        sbit wela=P2^7;
        uint num;
        uchar code table[]={
        0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
        0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
        void delayms(uint x)
           uchar i;
           while(x--)for(i=110;i>0;i--);
void main()
     wela=1;
         P0=0xc0;wela=0;
         while(1)
            for(num=0;num<16;num++)
                   dula=1;
                   P0=table[num];
                   dula=0;
                   P0=0xff;
                   wela=1;
                   P0=0xf0;
                   wela=0;
                   delayms(500);
此帖出自51单片机论坛
